Supercharger stuff (MILVs+AA+BPC)
05-23-2018, 09:35 AM | #155 | |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
No one has done this before? Run meth and a smaller pulley?
05-23-2018, 01:20 PM | #156 | |
Rep 1,413
See you, space cowboy.
Supercharged |
05-23-2018, 09:07 PM | #157 | |
152
Rep 177
Think F20C, it has a mild torque output but still manage to be pretty quick in real world because of the 9000rpm rev limit.
130i manual | ESS Supercharged | Custom remap
Birds B1 Suspension set | Vorshlag Camber plate | Quaife Limited slip differential | M3 Chassis parts |
05-24-2018, 07:40 AM | #158 |
Rep 1,402
Yeah but auto not manual.
I drive and auto shifts below 5000rpm 99% of my driving. 1% 5k to 6k. I could probably count on my fingers and toes how many times I have ever seen over 6.5k. More TQ from 2k to 5.5k is still a pretty wide range. But this idea/concept is not for everyone. I just like using/feeling boost all the time and not just when i wind it out, 9k that's impressive. But then again I'm an old fart. |
05-25-2018, 08:05 PM | #160 | |
152
Rep 177
However I do have doubt whether the Supercharger will work well with mid-range usability in mind as by design, boost level on the Vortech SC raise somewhat in linear or almost slight parabolic fashion and pulley size will not change that; you will always make max boost at red line and much less in mid-range compared to turbo or root-type supercharger, doesn't sound well when mated with automatic gearbox? Also... I can't be the only one who thinks N54/55's character is right up your alley?
05-26-2018, 07:24 AM | #161 | |
Rep 1,402
We have 2- '07 328xi, my son a coupe 5 speed, me a sedan auto. We like the stealth sleeper approach. Yeah it will be the same centrifugal SC boost curve. Same max boost psi just at 6k instead of 7k. This will shift the whole boost curve to the left and increase boost 1-2psi in the lower rpm area. Do we have a documented boost curve anywhere? 2k to 7k? Easy enough to do, just video boost gauge and tach. |
05-26-2018, 07:52 AM | #162 |
Rep 552
I've had turbo cars before, I think SC work similar where the full boost engages at full throttle. You can rev all the way to redline w/out hitting Max boost at half throttle. If you want to avoid running at full boost above 6k why not just train your right foot. The benefit of running to redline once awhile is to help avoid carbon build up in the motor.
Noir883.00 |
05-26-2018, 12:57 PM | #163 |
Slow.
3782
Rep 7,152
Shifting early I think you will be slower vs winding out the gears. Gearing and all that stuff.
It is rare for a car to be faster shifting below red line. Unless there is a massive drop off of power in the higher rpms. |
Noir883.00 |
05-26-2018, 05:59 PM | #164 | |
998
Rep 2,287
I'm in a loaner this week end, brand new 330i and that motor also falls off right after 6,000 but the red line is 7,000. Both of these cars feel dead after 6,000. It's a tough balance getting boost quickly at low RPM without sacrificing top end power. The loaner is a story in itself. I had a misfire and took to it the dealer to resolve while getting the oil changed, Still CPO. It's taken them days to figure it out. No codes but it sometimes coughed and bucked under heavy load. This seems like a common theme with the FI motors, coils don't seem to last in them. |
Noir883.00 |
05-26-2018, 09:07 PM | #165 | |
152
Rep 177
In short, the boost level is directly in proportion to the engine rpm NOT throttle position. Max boost is always achieved at red line. Turbo is completely different.
Noir883.00 |
05-26-2018, 09:13 PM | #166 | |
152
Rep 177
Boost level increase in proportion to engine rpm because the impeller is connected with the crank, hence max boost is at the highest rpm you can do on that engine, unless you have a blow off valve artificially limit boost level after a certain rpm. As for the 330i you have which runs out of breath after 6000rpm, you have another 1000rpm to stretch because you can take advantage of gearing (sometimes it more optimal than shifting up depending on the torque curve and gear ratio difference), or you take that extra rpm for a particular corner.
Torgus3781.50 |
05-27-2018, 09:47 AM | #167 | |
Slow.
3782
Rep 7,152
5:50 if you want to skip but you'll miss the math and the interesting stuff: https://www.youtube.com/watch?time_c...&v=zZBqb0ZJSwU https://www.onpointdyno.com/making-p...dyno-timeline/ Once you maximize the engine’s torque, the only way to make more horsepower is to make that torque at a higher speed. Infact, you’ll often see race engines lower peak torque in exchange for rpm, which makes more horsepower. The loss of torque is then made up with through gearing. Go get a dyno with your different pulley and lower RPM redline and we can do the math and see what makes the most sense. N52 SC dyno: N54 dyno: As you can see with the N54 the TQ drops off a cliff. Not so on the N52 SC. Hence why I really don't believe it would make sense to short shift even with the different pulley and E85 or meth which would change the dyno plot. Again if someone wants to guestimate the power of the dyno plot at various RPMs we can do the math and see. I could certainly be wrong and it might be a fun exercise.
05-27-2018, 12:24 PM | #168 |
Rep 1,402
That's exactly my point.
Maximum boost is at 5.5psi at 7000rpm, at 6000rpm boost is only about 3.5psi. If you use a smaller pulley and shift the boost curve you can get the same maximum boost of 5.5psi at 6000rpm. The additional boost at 6000rpm will add 2psi which will add about 12.5% more power. Because the boost curve is fairly linear and rises with rpm, we would see an additional +2psi at every rpm. This will increase both power curves tq and hp by 12.5%. So torque of 225-250 will become +12.5% to 253-281TQ. and hp at 6000rpm of 270 will become +12.5% to 304HP. Both more than the boost curve with maximum 5.5psi at 7000rpm. Now you must limit it to 6000rpm because it you rev it higher, you will get 7-8psi which might bee too much without some sort of cooling. |
Torgus3781.50 |
05-27-2018, 12:50 PM | #169 | |
Slow.
3782
Rep 7,152
The larger area under the curve the better! Would also be nice to have your boost come on earlier I am sure, especially as a DD. Even if you don't want to run meth, I highly suggest it, you could always just never let it wind out vs say asking bpc to lower the rev limiter(assuming they can) Happy memorial day weekend to you all btw. Edit: Does anyone know if the higher psi from 6-7k will really cause an issue and need e85 or meth for knock resistance? I ask as I wouldn't surprise me if ess was just massively conservative...
06-04-2018, 10:45 AM | #171 |
Rep 1,402
So if you used a smaller SC pulley and redline limit it to 6000rpm and size it so you still only make a maximum boost of 5.5psi but now at 6000rpm instead of 7000rpm.
This will add +2psi to boost curve or 12.5% more power across the whole hp and tq curves. You will make 10-12.5% more hp and tq from 2k to 6k and more peak hp and tq than before but will be limited to 6k rpm. Basically +20ft-lb more TQ across the whole curve. That' significant! This is probable better suited to auto than to manual cars. |
Noir883.00 |
06-12-2018, 10:52 AM | #172 |
Basic Bimmer
520
Rep 935
Drives: E92 328i 6MT ///M
6k RPM Redline.. I'd cry.
Then again, Auto.. I'd cry. =P I just love how having a motor that isn't super adored or adopted by the aftermarket community forces us to think outside the box here so much lol. |
Noir883.00 |
06-12-2018, 12:30 PM | #174 |
Rep 1,413
I need to get with Randall.
Really don't want to be speaking on the behalf of anyone, but from what I understand, the flex fuel deal isnt happening... Soooooooooooooooooooooo..... Just gonna have to schedule for install and dyno. Gonna order that catch can in the meantime. Seriously considering that LSD in the classifieds.
Supercharged |
06-12-2018, 01:22 PM | #175 |
Basic Bimmer
520
Rep 935
Me too, kinda, but right when I joined here I saw a bunch of horror stories related to MFactory and "Syncrotech" or whatever, so I feel like I'm permanently afraid of their products/work. For that kind of cash, I want to feel 99% if not 100% confident in my purchase.
I'll probably run open forever, and then if I still have/love the car a few years down the line, and it seems like I'll keep her for a long time, I'll go with Diffsonline.
Black Sapphire 328i ///M Sport Coupé Save the Manuals! |
06-12-2018, 01:42 PM | #176 | |
Slow.
3782
Rep 7,152
I was honestly a bit skeptical of it coming out for the N52 as I see little to no market for it and the leg work to make it work flawlessly on Motiv's behalf would be large. NA is also not their wheel house unless BPC was modifying the tables and just using the hardware boostbox. There is some cost associated with running full E85 and on an NA engine with very little to gain by running high concentrations of E85. I'm sorry for you guys. Guess you just have to stick with meth(which is better for a number of reasons IMO)
Noir883.00 |
