2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Aftermarket wheels for the m235i ?
      01-17-2014, 01:33 AM   #1
M.barnes
Drives: 123d
Anyone planning on producing some wheels for the m225i soon?
Would love a bigger wider set of wheels, probably 19s.
Forgestar?!
      01-17-2014, 01:59 AM   #2
r3llik
Germany
26
Drives: BMW M235i
New wheels are first Day Buy (for me) !
My Favorite http://www.mb-design.de/kv1-konkaveversion1/
      01-17-2014, 02:02 AM   #3
Tigershark
Drives: 116i M Sport
The lack of colour and wheel options on the F20/F21/F22 M sport and M135i/235i models is bizarre to say the least. The wheels on the M135i/235i aren't that nice at all so I was surprised when BMW didn't offer any other choice.
C'mon BMW; more choices please!!
F20 116i /// M Sport Estoril Blue
      01-17-2014, 05:30 AM   #4
M.barnes
Drives: 123d
not keen on those MB ones, fancy staying fairly classic and going down the concave route / competition alloy look.
especially having seen some of the wheels on USA e92 M3s etc, vorsteiners and forgestars etc etc.
Just not sure on offsets and fitments
      01-17-2014, 06:47 AM   #5
waitwhat
Drives: ...
will buy hamann evo anniversary when they're available, those are super dope wheels if you ask me...
check them out on f32: http://www.hamann-motorsport.com/ind...1/bmw/4er/f32/
      01-17-2014, 07:00 AM   #6
M.barnes
Drives: 123d
i think i have different tastes i am afraid.
i like these and similar.
      01-17-2014, 07:34 AM   #7
riccappa
riccappa's Avatar
54
Drives: 14' M235i
+1
      01-17-2014, 11:28 AM   #8
waitwhat
Drives: ...
^ these are dope too.
i'm just into more elegant/classical look.
      01-17-2014, 12:57 PM   #9
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
Some nice 19' CSLs in bright silver would look awesome--I think those replicas can be found pretty easily.
Wonder what BMW charges for those? I bet it's an arm and leg--they were also on the 1M...
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      01-17-2014, 01:10 PM   #10
M.barnes
Drives: 123d
Yeah offsets will be well off for a 2 series though
Csl wheels would be nice though I just don't think they'll fit
      01-17-2014, 01:52 PM   #11
RSXDC5
RSXDC5's Avatar
707
Drives: M3
I've actually done a ton of wheel offset/width calculations already; i've been trying to find wheels that will fit and remain semi concave at the very least.
Since the M235i wheel offsets are SO high, its been tough. I actually found 1 combination of Apex EC-7 wheels that will fit with their Profile 2 face. I need to look up the width/offset combo, but I think 3mm needed to be shaved from the wheels to increase their offset...I'll look the specs up in a bit and share with everyone...
OEM:
F - 18x7.5 +45
R - 18x8.0 +52
APEX EX-7:
F - 18x9.0 +31 --> shaved 3mm to --> +34
R - 18x9.5 +43 --> shaved 3mm to --> +46
EC-7 CLEARANCE:
You will need to run an aggressive amount of front camber (-2.5 to -3 degrees).
F - 8mm less inner clearance, 30mm more outer poke
R - 13mm less inner clearance, 25mm more outer poke
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      01-17-2014, 02:16 PM   #12
M.barnes
Drives: 123d
Nice.
What spec are you basing your calculations on? Do you know the standard offsets of the m235i etc?
Reckon I'll have to wait and follow rather than be a first. Can't afford to buy a set of wheels that don't fit lol. Really like the forgestars too!
Mineral grey, 20mm lowered, forgestars.
Done.
      01-17-2014, 04:02 PM   #13
abc
Drives: 325
that wax looks pretty shiny... what product?
      01-17-2014, 05:33 PM   #14
M.barnes
Drives: 123d
Brilliant! That gives me some food for thought at least. Forgestars seem to come in lots of offsets too.
      01-17-2014, 05:39 PM   #15
M.barnes
Drives: 123d
This says quite different on front is that because of your camber assumptions?
      01-17-2014, 06:13 PM   #16
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Are you talking about the reduction in inner clearance or the addition of outer "poke"?
Negative camber will recess the top portion of your wheel/tire into the wheel well more, alleviating any "poke" if there was too much. Adding negative camber is really for handling though, it increases your tires contact patch while cornering.
The front and rear specs i gave for the apex wheels are specifically tailored to use up most fender well clearance (inside clearance and outside clearance). The amount of clearance you have depends on things like camber or spring diameter.
      01-17-2014, 11:05 PM   #17
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
Apex told me they would have some new wheel styles for 2014.
Otheriwse, I like the new OZ Leggera
Wouldn't mind those in a gunmetal or even gold!
Also some new sparco
My personal favorite, but too $$$
These look ok
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      01-18-2014, 04:36 AM   #18
M.barnes
Drives: 123d
Sorry didn't put link in.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
When I put your specs in the results are different regarding amount it will stick in and out. Just wondering whether the difference came from the camber
      01-18-2014, 05:55 PM   #19
RSXDC5
RSXDC5's Avatar
707
Drives: M3
I'm assuming your specs were 3mm off correct? I increased the Apex wheel offsets by 3mm (in the online calculator) to account for shaving the rim 3mm.
      01-19-2014, 03:24 AM   #20
M.barnes
Drives: 123d
Doing the fronts on 1001 even with aftermarket et34 gives 8mm less inner and 30mm more outer?
      01-19-2014, 06:42 AM   #21
as7920
as7920's Avatar
602
Drives: 2023 SG/FR M4 xDrive Competiti
How about the other OEM 19" set (BMW LA wheel, M double spoke 624) shown on the 2nd M235i racing?
More details here:
http://realoem.com/bmw/showparts.do?...86&hg=36&fg=15
http://www.etk.cc/bmw/EN/search/sele...CE/36/36_1886/
      01-19-2014, 09:01 AM   #22
M.barnes
Drives: 123d
Hate them I'm afraid. Proper rice wagon wheels as you guys would say.
2addicts
