02-14-2012, 01:40 PM | #1 |
Rep 4,040
Drives: 130i coupé ;)
Where to buy 135i Brake air/cooling ducts? For retrofit them to 128i
I wish to purchase the brake ducts ONLY that go behind the front bumper/valence fro stock 135i or Performance bumper.
Any place where I can buy just these ducts? It occurred to me that stock 128i Bumper has no air ducts for brake cooling. Sure they are not 6 piston brakes, but it would be nice to retrofit and route some air that way. I have an I idea that is also visually pleasing. Also how do Performance bumper air ducts differ from stock 135i? Real OEM shows that they feed air from center vent and not the side vent in stock 135i bumper. Performance bumper 135i Bumper Thanks
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
02-14-2012, 02:39 PM | #2 |
210
Rep 2,233
I think you'd be better off switching to slotted or crossdrilled rotors and Cool Carbon pads.
I am about to install that combo on my 128. The CC pads are mostly for the brake dust issue. |
02-14-2012, 03:00 PM | #3 |
117
Rep 1,998
if you spec a 128 w/m package front and rear bumpers and trim, then you get theses from the factory..
The only bad thing is that the duct just ends into the face of the spinning tire.. It does allow cooler / fresh air to enter the wheel well area, but by no means i would call them "brake cooling ducts" but they dont hurt either.. to add, i have the Perf Brakes on my car ( 6 piston brembos ) and i track 5-6 times a year.. my stock pads were pretty good, till i got better... better means bigger testicals to brake harder and later into some pretty wild corners at high rates of speed with your daily driver.. I run cool carbons for the spring to fall months, and stock pads for the winter.. cool carbons are def less dust.
X1, R58 JCW, M2 in my future if planets align
02-14-2012, 03:25 PM | #4 |
Rep 4,040
Thanks for the replies,
Can you point me to the vendors for these cool carbon & slotted rotors for future reference? So these ducts just add air to wheel well. So does it make more sense to do a more simple version of this?? http://www.m3post.com/forums/attachm...2&d=1260960053
02-14-2012, 10:25 PM | #5 | |
210
Rep 2,233
Got the pads at Bavarian Autosports, the disks at Turner Motorsports. http://www.bavauto.com/ |
04-06-2012, 05:29 PM | #6 | |
701
Rep 3,268
Drives: 2010 128i
I was at the track last week and my car felt really good - but I wanted more brakes. I think once you sort the suspension, that becomes the 128i's "weak link." So that'll probably be my next mod, I think...but it would be cool to add some ducting, if possible. I was also looking at vented backing plates and brake ducting hose, but I can't figure out a place to route it to to let air in...would consider swapping bumpers if needed.
____________________________ |
04-07-2012, 02:44 AM | #7 |
Rep 4,040
PM me I have a few Ideas, no bumper swap required
04-07-2012, 03:18 AM | #8 |
European Editor
10594
Rep 22,992
OP - You might also want retrofit the F30 splash shields too while you are at it...
http://www.1addicts.com/forums/showthread.php?t=663510 |
04-07-2012, 10:34 AM | #9 |
Rep 4,040
F30 shields are definitely one way.
I have more in mind to mimic 135i and BMP bumper
04-15-2016, 09:14 AM | #11 |
Rep 1,233
F30 backing plates are an easy and relatively cheap first step.....or you could try and fab up your own, wouldn't be too hard. I'm probably going to attempt adding 135 ducts to my 128i this summer, will need to do some exploratory work first but new fender liners will be required at the very least..
04-16-2016, 08:04 PM | #12 | |
Rep 4,040
On 128i it can look good and fill the wide smile of stock nonM-sport bumper Now my goal is t get the full BMW Performance bumper with 135i brake ducts for it
04-16-2016, 09:55 PM | #13 |
Rep 1,233
Nice - I think the performance bumper has specific brake ducts for it, or are they the same as 135i ducts? I'm tempted to consider something similar as well...you have a good source for the bumper?
04-16-2016, 10:12 PM | #14 |
Rep 4,040
its the ducts for the BMW Performance bumper, made for the 135i. The same plan Bimmer-Bob has, or hopefully hes already done..
02-10-2017, 04:38 PM | #15 |
366
Rep 317
Has anyone retrofit the 135i Air ducts w/128i Performance Bumper?
I was thinking of doing the same thing - after staring at the realoem diagrams and the install .pdf for the Performance Bumper I don't see a reason it wouldn't work, but it'd be a nice reassurance to hear someone else has done it before dropping the money on the new bumper and fender liners. |
08-20-2017, 09:28 PM | #16 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
I'm in the process of turning my fog lights (base 128i bumper) into brake duct inlets. I bought a spare light to mess with and destroy. All it took was some 3" brake duct which is easy to find (you can also use SCET(?) tubing from an airplane), a 3" hole saw, and a section of 3" thin-walled PVC pipe. Remove the fog light cover, and the reflector. Drill out the foglight housing where the bulb goes in. Epoxy the pipe section to the housing, then fit the hosing around the pipe, and use a hose clamp to secure it to the pipe. I haven't worked out routing into the wheel well, but I'll get back to you all when I finish. I'll probably remove the backing plate (I snapped it off of one of the bolts when I did the front pads) and route the hose through the inside of the wheel well...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
02-05-2020, 07:08 PM | #17 | |
Rep 437
02-05-2020, 09:09 PM | #18 | |
Rep 1,233
Ha - so unfortunately I never got to this after all this time...I remember doing some digging and there would be a reasonable amount of fiddling/fabricating to get it done and I abandoned the thought... |
02-12-2020, 07:35 PM | #19 |
3027
Rep 2,860
I used 135i ducts when I switched to the BMW Performance Aero. Other than new lower fender liners, it was bolt in. The mounting points are already there.
ornicar136.00 |
128i, 135i, brake duct |
