BMW M3 Forum (E90 E92)
      09-13-2013, 03:52 PM   #133
UroGator
UroGator's Avatar
Drives: 2008 MR E92 M3 6MT
Originally Posted by Bigvo9 View Post
I just bought an E93 kit on eBay for $140 shipped.
http://www.ebay.com/itm/121142026340...84.m1497.l2649
Waiting for it to come in so I can install. I have an 08 pre-wired.
Hopefully you have an E93 as this kit is specific to that car. Was about to buy this as well until I looked into it further.
      09-16-2013, 03:22 PM   #134
UroGator
UroGator's Avatar
When I reconnect the negative terminal after installing the alarm, does this reset anything or force me to input any codes for the radio, etc. to get them to work again?
      09-27-2013, 12:27 PM   #135
Bigvo9
Drives: E93 M3
Yes, I have an E93. I'm going to finally install it today. I'll let you know how it goes!
      09-27-2013, 10:45 PM   #136
Bigvo9
Drives: E93 M3
I completed the installation today and I must say, it was a PITA to get to the negative terminal. After i reconnected it, the only thing I had to reset was the date and time. Also the trip meters got reset. Radio, M settings, etc. were all the same. Now time to get it coded!
      10-18-2013, 09:03 PM   #137
UroGator
UroGator's Avatar
Who did you use to code your alarm?
      08-09-2015, 09:33 PM   #138
Iyzmi
Drives: E92 M3 6MT ESS625
Finally got around to installing my alarm. I was surprised to find that the lock/unlock chirp works without any coding. I'm not able to set off panic mode or control any of the alarm options in iDrive though. 99% of the reason I wanted the alarm was to get the chirp so I might just leave it like this instead of spending ~$150 on coding.
      02-04-2016, 07:41 AM   #139
blast1st
Test
blast1st's Avatar
Philippines
115
Drives: MDX as my daily @blast_1st
This is very helpful. thanks
      04-14-2017, 04:37 AM   #140
GeorgeA
GeorgeA's Avatar
Drives: E92 M3
Are all M3s in the US pre-wired for this alarm system? I have an 09 with pre 03/2009 production.
      06-14-2018, 11:54 PM   #141
Mdriv3r
Mdriv3r's Avatar
Drives: F13 M6
Hey all I am prewired,
I have two questions.
1. Can The Carly app to code this on the fly to save time?
2. Can I use ISTA-D/P to program this feature?
I have both of these and a laptop with ISTA for updating modules. Also, if its not too much trouble, some directions on how to do the programming on ISTA would be great. Thanks.
      06-01-2020, 07:41 PM   #142
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
An addition to this ; You will also need to remove the $5AG if your vehicle came with Alarm Prewiring to activate your interior MicroWave sensors before you default code your DWA module IF you add the sensors to your door trims.
Before removing $5GA:
VALUE_MUW_HL
wert_03
wert_05
VALUE_MUW_HR
wert_05
VALUE_MUW_VL
wert_05
VALUE_MUW_VR
wert_05
After removing $5GA:
VALUE_MUW_HL
wert_04
VALUE_MUW_HR
wert_04
VALUE_MUW_VL
wert_04
VALUE_MUW_VR
wert_04
Originally Posted by RBB View Post
Nice DIY. Installed the alarm a couple of weeks ago and finally got around to the coding this past weekend.
Did the coding myself and it was very simple. Add +K302 to your VO in both CAS and NFRM. After that use expert mode profile to code your DWAI, DWAS, CAS and CAPPL (if you have Idrive) modules to defaults.
I you're like me and had previously coded your CAS and CAPPL modules and don't want your changes overwritten then code DWAI and DWAS to defaults and change the following values in CAS and CAPPL.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      11-02-2021, 05:57 PM   #143
Hivand_M
Hivand_M's Avatar
Drives: E92 M3
Does anyone know if I can just install the siren if all I want is the lock/unlock chips? My car is not wired for an alarm.
Thanks!
      11-02-2021, 07:47 PM   #144
SLBMW
SLBMW's Avatar
52
Drives: 2013 F30 , E92 M3
Thanks!
You can just install a mod4cars RemoteKey+ if you just want the chirp.
      11-02-2021, 07:49 PM   #145
Hivand_M
Hivand_M's Avatar
Drives: E92 M3
Thanks!
I don't think they sell that anymore, at least I wasn't able to find it.
      11-02-2021, 07:59 PM   #146
SLBMW
SLBMW's Avatar
52
http://www.mods4cars.com/sms/shop/in...ode=view&id=65
Seems like they have it available?
Hivand_M138.00
m3post
