BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
EXXEL Distributions
      09-26-2023, 02:51 PM   #23
tmafuru
Drives: kia picanto
hello guys good prod https://www.fcpeuro.com/products/bmw...om-51317138664 .
snaptube vidmate
      10-03-2023, 11:44 AM   #24
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
Originally Posted by tmafuru View Post
Yup, that's the one! Also available in stock at most BMW dealerships for just about the same price.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package
      02-23-2024, 01:25 PM   #25
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
Originally Posted by Thumbie View Post
Ugh! I just did my rear. Top was easy peasy (although I did this once before on my e36). Key is lining up the corners before pressing it all in so you don't get a bulge on one side.
The rear I could NOT get to stay. Wish I read through these threads first...The center third is fine, but the two ends won't stay in (one side will go in all the way but slowly comes out, the other wont even go all the way in). They are on enough to just cover the edge of the glass so that'll be "good enough" until I get a new trim and try again.
This is what I will try. Lots of painters tape as seen in above photo.
Update: I redid the lower trim. Got a fresh part from the dealer. Spent a good hour with a razor to cut out all the excess goop from the factory rear window install. THIS WAS A VERY IMPORTANT STEP!!! Seriously cut as much out as you can.
Added some dots of sealant (in addition to the bead that comes on the trim already) and pressed into place and held pressure for 5-10 minutes. It's been two months and so far so good.
-Thumbie
      02-23-2024, 05:51 PM   #26
bmxcamel
bmxcamel's Avatar
556
Drives: F87 LCI, G01 m40i, E90 M3
Agreed on this. I used this sealant and it’s been good for nearly 6 months.
3M Black Super Weatherstrip https://www.amazon.com/dp/B00063X38M
Thumbie95.50
      02-26-2024, 11:26 AM   #27
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
Yep that's the stuff I used!
Cutting out the factory goop and using extra 3M sealant are they key.
I took so long with a razor. I wonder if one of those loop tools for pottery would work, although it's probably not sharp enough. Do you know the tool I am talking about? I think it's called a ribbon tool
-Thumbie
m3post
