BMW M3 Forum (E90 E92)
EXXEL Distributions
      03-04-2021, 09:42 AM   #23
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
I want to revive this ancient thread because I'm building a 1 series track car with S65 swap and wanted to remove AC for weight savings. I [think I] found the golden ticket to this... the S85 never swapped belt direction and the PS pumps are all over the place for fairly cheap, and bolt right on.
The mounting bracket from the S65 has to be swapped over since the mount is slightly different on the S85. The input connection is at a slightly different angle on the S85 pump but it doesn't appear to be an issue. If it leaks I'll just replace that pipe with a more flexible one with worm gear hose clamps.
Since I haven't fired it up my only though/concern now is the flow rate will be significantly different and the PS will feel too heavy or too light, but I doubt it. I'll try really hard to remember to report back when I get the car together.
UPDATE: Car is together and drives perfect with the S85 pump.
I had to try a couple different belts and you'll want a 31.5-32" belt. I found the KRC 4060320 that fits perfect.
S85 PS pump PN: 32412282951
Belt: KRC 4060320 https://www.krcpower.com/ecommerce/part-gdy-4060320.asp
SYT_Shadow11490.00
tlrid3r513.50
      03-05-2021, 01:06 PM   #24
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
That is super useful information!
      03-06-2021, 09:26 PM   #25
amg6975
amg6975's Avatar
500
Thanks!
I just got the Gates belt and it's too long. It measure 33.5." Autozone has a Continental 4060325 in stock locally I'm going to get tomorrow and try, should be 32.5" and be just right. I'll update above if it works.
Edit: Ugh, still slightly too long. Trying a 31.5" KRC belt now.
Edit Edit: The KRC 4060315 belt fits great, updating the post above.
Edit Edit Edit: 4060320 fits better, the 315 was too tight, I was worried about it pulling on the main bearings too hard.
SYT_Shadow11490.00
      01-08-2023, 11:33 AM   #26
M_Torx
M_Torx's Avatar
328
Drives: M
am wondering why has a company not made a bracket with pullley on it that's goes in the same spot as AC compressor that would be so simple keep stock belt ???
TTP
      02-03-2023, 08:23 AM   #27
amg6975
amg6975's Avatar
500
Alright, Important update here. I actually had a suction hose failure on my car, which I'm chalking up to the angle of the S85 pump's inlet putting some tension on it. That with repeated track use split the hose.
I got to thinking and looking and trying to figure out how to fix this for good and since the two housings look identical other than that input angle, I figured I'd pop them open to see if the guts of the S85 pump could simply be put in the S65 housing. Can't hurt to look.
Sure enough, they're identical other than the direction the orifices face so I just put the S85 guts into the S65 housing, all new hoses, and away we go. This actually happened in the spring [and I forgot to update this] so the car has some road miles and many track days on it with flawless results.
I reused the same belt as above.
tlrid3r513.50
      02-05-2023, 11:36 AM   #28
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Thanks for share. Are the pump rebuildable.
I have an 2008 s65 pump and worried about its age.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      02-14-2023, 02:02 PM   #29
amg6975
amg6975's Avatar
500
Probably but I really wouldn't worry about it. Not much to go wrong in it. I'd be more concerned about the lines and reservoir. Upgrade the cooler while you're doing it.
      02-16-2023, 01:58 AM   #30
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
All that you mentioned I have already done so. This is why my last concern was the pump. 2008 pump are expensive
      02-16-2023, 01:25 PM   #31
amg6975
amg6975's Avatar
500
I would suggest just buying a new/rebuilt S85 pump and doing what I did. Basically the same thing as rebuilding it and way easier/cheaper than finding an OG S65 pump. It wasn't all that hard to do.
I couldn't find the gasket anywhere but reusing the one off my fairly fresh S85 pump worked fine.
tlrid3r513.50
      08-06-2023, 01:50 AM   #32
Antz M3
Drives: 08' 335i
Looking at getting the s85 pump for my s65 as the earlier style pumps are now £950 from bmw with extremely limited availability… I can get a brand new s85 pump for £300. If I were to change to suction hose to a slightly more flexible style do you think this would avoid it ever splitting? Or would it just be easier changing over the internals like you did? Assume no issues since with yours?
Thanks
      08-07-2023, 01:05 PM   #33
amg6975
amg6975's Avatar
500
Thanks
There is not a lot of room between the suction hose and the belt tensioner so just using a longer/more flexible hose probably won't work as I think it will rub. I would just get an S85 pump and rebuild your S65 pump with the internals from the S85 unit. Should be identical.
      02-24-2024, 03:54 AM   #34
rhyary
rhyary's Avatar
Drives: 2013 M3
Will this option from FCP works for a/c delete
      02-24-2024, 05:34 AM   #35
rhyary
rhyary's Avatar
Drives: 2013 M3
On the FCP site they are listing the same PS pump for 2008 and 2013 so I contacted them for clarification
m3post
