BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
BPM
      11-01-2021, 09:17 AM   #309
Tony B
Drives: 2012 E92 M3, MW, ZCP, 6MT
Originally Posted by EMKOOP View Post
Yes they both utilize the same illuminated ZHP knob which should be 13 mm lower than E9x M3 stock shift knob.
I went with +8 mm on the AS SSK lever height to be in the best of both worlds approach. Hope that helps.
Do you have a picture of this combo installed?
Also, I am interested to hear about any changes in the shift feel.
      07-20-2022, 04:11 PM   #310
hsapra86
Drives: 2011 335i Sedan
Looking to switch shift knobs
Looking to switch ideally to the illuminated F10 M5 knob for my E90 M3... can someone point me to which is the correct one to purchase? When i look at sites like FCP and Turner, it says that does not fit the E90. Thanks!
      07-30-2022, 10:39 PM   #311
Hein Jockins
Hein Jockins's Avatar
94
Drives: 2017 340, 08 E92 M3
That's because it's not a direct fit and some modification is required. See OP's post and also there's some guides on YouTube. But since you have to modify it to fit E9x, don't think they would sell it as a direct fit for E9x.
      08-23-2022, 03:33 PM   #312
ramo135
Drives: '13 E92 ZCP Alpine White
Hey I did this mod years ago and just noticed recently it’s not lighting up at night anymore. Could this be a fuse issue or should it pop it off and see if it got disconnected or something?
      09-10-2022, 12:02 AM   #313
S54 ATL
Drives: e46 M3 cab
Can anybody weigh in on the "quality" of the ebay rings? I'm guessing they are not OEM, and that can sometimes make a difference on fitment.
      12-17-2023, 01:20 PM   #314
CTMike
Drives: 2021 X5 40i MSport/2011 E93 M3
So: I have 3 shifters/boots. Stock one is currently installed. I also have an IND tri-stitch boot with stock shifter and stock plastic ring with clips, and I have an M5 shifter and boot. While I know most folks transferred the M5 boot to the M3 ring… what I would like is the M5 shift knob on the IND tri-stitch boot. So that means cutting. It seems BIGW0RM and waterpanda had the best luck with this approach? I’ll try searching elsewhere too before just cutting things up… welcome any other advice. Thanks, Mike
Gone but not forgotten: 2005 X3 2.5 6spd, 2011 X5 50i, 2015 328d Wagon
m3post
