TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Coding performance brakes
      10-22-2016, 01:05 PM   #1
david in germany
Drives: 118i, 335i and 328i
Ok, I have upgraded my wife's 328i to 335i brakes and also coded the car to the performance brakes. I must say, the car brakes better than my 335i now. I know it can't be just that the car is 200lbs lighter. Could coding the 335i to performance brakes better the system?
Just a thought I was pondering that may be worth discussing.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
E90Dom0.00
      10-22-2016, 04:58 PM   #2
LMB335IS
Sua Sponte
LMB335IS's Avatar
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
That's a F series only application. There's no coding involved with E series brakes so I'm not sure you'll find much feedback here in the E series forum.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      10-22-2016, 06:12 PM   #3
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
Could just be the state of the brake fluid and lines, or the rotors + pads.
I'm sure the 200 pounds makes a decent difference too, it's the equivalent of having a big guy in the car.
I came from an E46 328i that had fresh rotors and pads, and I feel like that even braked better than my 335i. Replacing runflats with better tyres helped, but still feel like it maybe could use fresh fluid and I'm not sure what kind of pads I've got.
      10-22-2016, 08:05 PM   #4
shadowcoder
shadowcoder's Avatar
Greece
51
Drives: 2006 330i
Interesting you say that. I am upgrading the brakes of my E90 330i
with the BMW performance brakes and the dealer said coding is needed.
      10-22-2016, 08:28 PM   #5
feuer
feuer's Avatar
Drives: wife crazy!
That's what I know too but David says coding is different on 135i that comes with 6 piston front and 2 piston rear. However, those "performance" brakes on the 135i perform worse than 335i brakes so homestly can't see how that partit coding will help when running 335i brakes and F-series Brembo like you and me.
      10-22-2016, 09:15 PM   #6
maddmatth
New Zealand
555
What does the coding change? Only thing I can imagine is to adjust how it calculates bake heat, so it doesn't think you're overheating the brakes when they're fine.
      10-22-2016, 10:06 PM   #7
shadowcoder
Greece
51
Drives: 2006 330i
Change in pressure perhaps since rotors/calipers are of different size than stock and are also drilled? ABS and traction control thresholds? Brake power distribution?
      10-23-2016, 04:36 AM   #8
david in germany
Oh no, need to run out and tell my wife's e90 it is not an e90! Yes, I coded the e90 to retrofit performance brakes.
      10-23-2016, 04:38 AM   #9
david in germany
Both have fresh fluid flush, fresh rotors and pads (same brands as well) brand new Ts810 Conti winters on both as well.
      10-23-2016, 04:40 AM   #10
david in germany
Identical parts now but the rotors and calipers were considerably smaller on the 328i when stock.
      10-23-2016, 09:39 AM   #11
feuer
feuer's Avatar
Drives: wife crazy!
Please post DIY on the coding. Thank you!
      10-23-2016, 10:01 AM   #12
david in germany
Not sure how many actually have ICOM and ISTA and if they do it is pretty easy.
Log into car, have you replaced a module (check no)
Check retrofit select which module (check that your Schumaker INC 700 is set to coding)
get back into car
accept job wait 15-20 min.
Tell wife you will be done soon and the task she wants you to do can wait, feel the wrath, wait more. etc... LOL
335e92tx1036.00
E90Dom0.00
      10-23-2016, 04:07 PM   #13
LMB335IS
Sua Sponte
LMB335IS's Avatar
get back into car
Is it possible through WinKFP and NCS Expert? Tool 32?
      10-24-2016, 12:43 AM   #14
david in germany
You can. You will need to add SPBR to the VO and then code the DSC and FRM modules if I remember correctly.
Presently I am waiting on a fresh set of front rotors and then I will be upgrading my 118I to performance brakes (using 135I calipers and rotors on the front and 328I rotors and calipers on the back). Once I get the rotors in and install I will take a few pics of the coding process.
Appreciate 3
LMB335IS1299.00
E90Dom0.00
      10-24-2016, 07:07 AM   #15
LMB335IS
Sua Sponte
LMB335IS's Avatar
Thanks. I guessing this all really just applies to all the base models that came with the smaller brake setups and had the Performance Brakes as a upgrade option. There was no factory upgrade option for the 335i so I would assume that there's no coding option available either unless maybe the M3 is coded differently and/or has something in the VO.
      10-24-2016, 07:36 AM   #16
david in germany
That is my thought. I am thinking that if I log into my 335I with ista I should NOT see the option for Performance Brake retrofit like I did with my wifes 328i.
      10-24-2016, 10:54 AM   #17
Dan Bilzerian
Dan Bilzerian's Avatar
355
Drives: E90 325i 6MT
Wait, so I have to get the car specifically coded if I want to upgrade to 335i brakes?
      10-24-2016, 12:08 PM   #18
david in germany
for them to work properly, yes.
      10-24-2016, 04:34 PM   #19
Dan Bilzerian
355
Thanks David in Germany lol
Or should I say Danke sehr
      10-24-2016, 05:44 PM   #20
Skunkworkz
Drives: BMW328
What type of coding machine is required and where can I purchase one?
Sotek3.50
      10-25-2016, 12:25 AM   #21
david in germany
I am using a thinkpad T410 with complete BMW coding suite that uses a BMW ICOM head. I pieced mine together. ICOM was from a seller on ebay, Thinkpad from Amazon (refurb) and the coding suite was from an Amazon seller.
      10-26-2016, 05:50 PM   #22
shadowcoder
Greece
51
Drives: 2006 330i
get back into car
I have the following problem in case you know the solution to it.
I purchased the kit and took it to the dealer for installation. My car is a
2006 E90 330i.
Unfortunately there doesn't seem to be an option for the performance
sports brakes under ISTA in the retrofit selections.
Are they required to flash the car to the latest and then it will pop up?
How are they meant to address this?
Any help appreciated because right now we don't know how they are meant
to code the new brakes on the car with ISTA
