03-01-2024, 02:52 PM | #1 |
Rep 416
Shocks for softer ride in comfort mode?
Any suggestions for replacement shocks that would give a softer/more forgiving ride in comfort mode? The streets are not always great up here in the Midwest, so I was thinking different shocks may help somewhat. Thanks in advance.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
03-01-2024, 03:32 PM | #2 |
Rep 5,548
If you want to retain EDC, your choices are limited. Available options:
1. Bilstein B6 Damptronic - supposedly it has a firmer ride in all EDC modes. 2. Evolve/Bilstein B6 Damptronic - supposed to have more comfort in EDC comfort mode but it’s received mixed reviews. 3. Bilstein B16 Damptronic - extremely firm compared to stock EDC in all modes. Adjustable ride height but has a min drop of ~20 mm. 4. KW DDC - has received good reviews regarding improved comfort in EDC comfort mode. Good performance in sport modes. Adjustable ride height and min drop is less than B16’s and maybe stock rode height can be maintained. 5. Nitron elec-TRON Roadsport - newly released by Nitron and is biased towards street. No reviews yet but should be one of the better options for the street. Price is ~$4900. 6. Nitron elec-TRON R1 & R3 - performance/track focused with custom spring rates. Most expensive option ranging between ~$5900 for R1, ~$8400 for R3. 7. TracTive Touring - similar to Nitron Roadsport kit. Designed primarily for street use but also more performance oriented. Price point is similar to Nitron Roadsport. Note: TracTive has poor customer service. Their warranty process is painfully slow and rebuild/replacement times range from a couple to several months. If you’re in the US, there’s only one source to get TracTive setups (EDC and non-EDC) from. 8. BMW OEM ZCP dampers - purchase oem ZCP damper and have your EDC coded to CS EDC. This improves ride quality in all modes and increases performance, too. You can add a HAS kit if you want to lower your car from the stock ride height. Min drop is different for different kits with drops ranging from 5 mm to 25-30 mm. I think that captures all of the EDC plug-n-play options. Considerably more options available if you no longer want to retain EDC. Last edited by M3SQRD; 03-02-2024 at 07:57 AM.. |
03-01-2024, 03:39 PM | #3 | |
Rep 1,048
03-01-2024, 03:49 PM | #4 |
Rep 5,548
louielouie538.00 |
03-01-2024, 05:15 PM | #7 |
Rep 3,604
Confirmed you need to splice or you can modify the KW receiver to accept the BMW plug. I just installed a set of these for a friend. Extremely comfortable setup, fine for street, canyons, and the odd track day. There are better options for pure performance though if that matters.
Current: F80
Prior: F82, F32 Last edited by RugbyBro; 03-01-2024 at 07:11 PM.. |
03-01-2024, 06:42 PM | #8 |
Rep 5,154
On my F80 the MP-HAS felt one step softer than my stock springs (non-ZCP).
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
03-01-2024, 06:43 PM | #9 | |
Rep 5,548
03-01-2024, 07:11 PM | #10 | |
Rep 3,604
Honestly we thought it was going to be much more plug-n-play than it actually is. Also, the rear reservoir location prevents all access to the spring perches so ride height adjustment requires that the A arm be dropped.
Current: F80
Prior: F82, F32 |
03-01-2024, 07:51 PM | #11 | |
Rep 5,548
RugbyBro7601.50 louielouie538.00 |
03-01-2024, 10:50 PM | #12 |
Save the manuals!
6015
Rep 6,746
While we're on this topic of increased street comfort, what is the *MILDEST* drop you can achieve on the front axle with springs for an EDC car with the primary goal of maintaining comfort and suspension travel?
Is the MP HAS kit the best choice?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
TopJimmy5460.00 |
03-02-2024, 04:21 AM | #13 |
46
Rep 54
I went with Tractive Touring for a more comfortable suspension that's also far superior in handling.
I've been happy with Tractive but I did have 2 shocks that failed some months apart from each other which combined with Tractive's snail-pace warranty claims left me without suspension for some time. Nevertheless, apart from warranty claims being slow, the Tractive Touring Line is an awesome bit of kit. Let me tell you a story. I use the car to travel around Europe every year with my wife and 3 kids. We bob around in the European motorways at around 70-80 mph on the stock suspension. I call this the "care-free" mode. You know having a coffee, driving with one hand on the wheel, singing along and such. I find that the car is incapable of being "care-free" after the 70-80mph on the stock suspension. The next mode up is the semi-serious mode, when half are asleep, it's night time and you want to cover some ground, so you focus a bit and increase the speed to 90mph. And the next mode up is when you tell the family to buckle up cause we are about to take off, usually done temporarily when you are in a real hurry to catch a plane or boat, you focus real hard and go up to 120mph. When I installed the Tractive all these modes went up by 25-35 miles. Carefree zone was now 110mph. Semi-serious zone was now 130 mph. Take-off zone was now 160+ mph. Comfort was seriously upgraded for all passengers and our Euro-trip with Tractive on was a joy for everybody. Last edited by noemon; 03-27-2024 at 11:32 AM.. |
azuritschwarz347.50 |
03-02-2024, 07:49 AM | #14 |
Rep 5,548
noemon
Sorry to hear about your issues with TracTive. Unfortunately, you’re not the only one that’s had issues with them. I was going to mention this in the above list but forgot to. I’ll update the list regarding TracTive’s warranty issues and poor customer service. Your new Intrax setup is a great non-EDC setup and you’ll love its performance. What spring rates did you go with? Are you able to adjust the pressure in the remote reservoirs? What’s the rebuilt interval? |
noemon46.00 |
03-02-2024, 05:51 PM | #15 |
Rep 5,548
For mildest drop, I’d say it’s MP HAS which I believe you can get as small as a 5 mm drop. I believe BMW’s recommendation is 10 mm on the front and rear. I think their recommendation is based on stock damper and use of bump stops to limit travel. Bump travel control with bump stops is BMW SOP and 10 mm is a standard value for ride height drops. For example, on the e92 M3 zcp it was lowered 10 mm from the base model height. Anything more than 10 mm likely means you’re engaging the bump stops more than what BMW wants. If you install the kit, push the bump stop down the piston rod until it touches the top of the front strut. Drive the car for a while and then check the location of the bump stop. If it’s at the very top of the piston rod then that means you’ve at least engaged the bump stop.
6ixSpd6014.50 |
03-02-2024, 07:05 PM | #16 | |
46
Rep 54
Spring rates recommended by Intrax 32 n/mm front, 92 n/mm rear for majority road use which are basically the stock comp spring rates. I will not have external reservoirs as the ARC is internal in my setup, so the previous point became moot as I will no longer have to mount the reservoirs. I am 95% road user as a daily and this is where we ended up with Donald from Intrax after liaising with the engineers. If I want to go higher spring rates I will have to go with Intrax's top mounts, which will also push the reservoirs externally, this will inrease the price by another 1k, but frankly this is more about comfort than the track. Reason I was asking earlier about his setup and the NVH was because I was considering going full monty, with Intrax top mounts, camber plates and external reservoirs, as the only thing holding me back is metal to metal NVH. I can still do so, so if anybody here wears Intrax and its top mounts, please do let me know about NVH in the car. Last edited by noemon; 03-02-2024 at 07:12 PM.. |
03-04-2024, 10:24 PM | #17 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Rep 294
M539Restoration on youtube just posted about Evolves new setup for his E92.
Here is what they did for the F80. Might be worth looking into. https://youtu.be/-SoluDtg8P8?si=d0N3gdEbocsbgE82 |
03-09-2024, 05:10 PM | #18 | |
Rep 416
03-19-2024, 04:07 PM | #19 |
Racecar Driver
1289
Rep 1,955
Drives: BMW M4
Do you have 18's on the car? A taller tire would help.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
03-21-2024, 05:28 PM | #20 |
Rep 902
I bought the MP HAS and some ZCP shocks because I've heard the MPHAS setup is softer, and also that the CS setup is softer. Having a decision making complex on which direction to go. Lol
aka Hootie49.00 |
04-02-2024, 08:37 AM | #21 |
Rep 11
Great question OP!
I am a new owner and was JUST going to make a post, asking how other owners feel about the ride quality. Don't get me wrong, I knew what I signed up for when I purchased, and any hardcore sports car like this will have a firmer ride... But I also live in the Midwest and our roads have quite a few undulations, and I can't help but feel like the ride quality is a bit harsh over most streets. I am on MP HAS, installed about a month ago, however the prior owner (or maybe the one before) had ATROCIOUS lowering springs on it, and I am slightly concerned that the shocks may be shot after x amount of miles driven on the old lowering springs. I think my best bet would be to find another F80 owner and ask for a ride along so I can have some peace of mind... However, if anyone has eyes on this forum, I would love to hear some more perspective so that I can start to discern if the shocks are truly bad. |
tgb1974142.00 |
04-02-2024, 10:49 AM | #22 | |
Rep 5,548
Have you inspected the dampers to see if there’s any signs of hydraulic fluid seepage around the piston rod at the top cap? Lack of seepage doesn’t mean your dampers are fine but it’s a good sign. Do you feel like you’re on a boat that’s pitching, rolling and heaving uncontrollably? Do you feel the entire car, or a single corner, bouncing several times after hitting a bump? |
LXAS6131.50 |
