Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      11-08-2016, 09:20 PM   #1
Signature Wheel BMW
Signature Wheel BMW's Avatar
Drives: Signature BMW
Arrow Official Signature Wheel Gallery | Fitment Q&A Thread
Introducing the official Signature Wheel Gallery and Fitment Q&A Thread. We will showcase our wheels in this thread and we will also openly help you figure out the best wheels/tires setup for your vehicle. It doesn't matter if you're interested in Signature or not, we will even use our team of engineers to help you ensure you'll have the perfect fitment. At Signature, we believe in sharing our knowledge and making the car community a better place. We publicly disclosed proven "flush" fitments/offsets/tire sizes on our website and the list will grow as we test fit more vehicles. At Signature, we believe in pushing the fitment limits to be "aggressively tasteful."
We call all of this the Signature Movement, so come on in and ask questions...
http://www.signaturewheel.com/fitments
Who are we? Signature is founded by a group of car enthusiasts who spent years of modding and racing our personal vehicles. We realized when choosing a set of wheels, you have 2 of 3 choices as follow: (1) Reasonably Priced (2) Strong (3) Lightweight. We created Signature so you no longer have to choose, you can have a set of reasonably priced, ridiculously strong, and ultra light wheels. On top of that, we promise our wheels to arrive at your doorsteps within 5 weeks from ordering. No ifs, buts, or ands... We haven't missed our deadline yet, that's a promise we plan to keep.
Signature wheels are designed in California and manufactured by one of the top forged wheel manufacturers in the world. We have 50 CNC machines allocated, same factory coating, and a team of engineers to ensure there's no delay on deliveries. Our wheels are machined from the highest grade 6061-T6 aluminum that's been pressed at thousands of ton and heat treated at proprietary temperature. We believe in designs that are strong, light, and timeless.
JWL/VIA CERTIFIED
HUB CENTRIC
ACCEPT OEM LUG BOLTS AND NUTS
MAX BRAKE CLEARANCE
Our 2-Piece wheels are available with hidden or exposed hardware. If exposed, you can choose the hardware colors to be Black, Raw Aluminum, Gold, or Blue Titanium. OEM TPMS compatible. Optional Center-Lock, Anti-Slip Knurling Bead Tread, and OEM caps center hole.
Go ahead, ask us wheels and tires fitment questions...
"Leave Your Signature"
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
AND1_M369.00
      11-09-2016, 08:18 AM   #2
Signature Wheel BMW
Signature SV302 - brushed black barrel, brushed black face, and hidden hardware. 20x9.5 ET15 and 20x11 ET30 - 235/35/20 front and 285/30/20 rear. CATuned Coilovers. More aggressive than our standard recommendation, but the owner Seth loves the look.
Appreciate 3
      11-09-2016, 08:50 AM   #3
Signature Wheel BMW
Signature SV102 - Brushed Aluminum - 20x9.5 ET20 and 20x11 ET40 - 265/30/20 front and 295/30/20 MPSS rear. KWV3 coilovers.
Owner: kitw
      11-09-2016, 09:35 AM   #4
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
Originally Posted by Signature Wheel BMW View Post
Signature SV302 - brushed black barrel, brushed black face, and hidden hardware. 20x9.5 ET15 and 20x11 ET30 - 235/35/20 front and 285/30/20 rear. More aggressive than our standard recommendation, but the owner Seth loves the look.
Looks sick! I just got a 11" ET25 for my F82. The manufacture told me there gonna be no rubbing with 285/30 …. ... ET30 is already close to the fender
      11-09-2016, 10:03 AM   #5
Signature Wheel BMW
It depends on the tire brand. In general, Pirelli is narrower than Michelin. So no rubbing may be true for Pirelli tires, but not Michelin MPSS or Cup2. ET25 is cutting it very close, you "may" need tcamber in if needed. Please share your findings once mounted so we can help the community.
Here's a better angle of 20x11 ET30 with 285/30/20 (NITTO NT555). NITTO width is between Pirelli Zero and MPSS. As you can see, I don't think there's even 2mm room left let alone 5mm.
      11-09-2016, 10:45 AM   #6
LOW4LYF
LOW4LYF's Avatar
2163
Oh shit ... I want to use my stock 285/30 Michelin tire
I don't want to roll my fenders, camber should be ok, but no fender rolling
Another Member is running ET30 with 295/30
http://f80.bimmerpost.com/forums/sho...highlight=Zito
F80 and F82 have the same fitment?
Front gonna be 20x10 et25 with stock 265/30 Michelin
      11-09-2016, 11:16 AM   #7
Signature Wheel BMW
No mod needed in front, unless you run KW HAS or KW CS then you'll need 3mm spacers front. Rear: you should be fine with cambering in w/o rolling fenders. F80 and F82 have the same suspension/offset. Toyo Proxes 4 have almost the same section width as MPSS.
The seller did mentioned it was too aggressive. The black M4 rear camber was in very heavily to fit.
      11-09-2016, 03:53 PM   #8
JamesGames
JamesGames's Avatar
Drives: E60 550i|F82 M4|F48 X1|VA STi
It depends on the tire brand. In general, Pirelli is narrower than Michelin. So no rubbing may be true for Pirelli tires, but not Michelin MPSS or Cup2. ET25 is cutting it very close, you "may" need to roll your fenders or camber in if needed. Rolling fenders is very easy to do, just make sure you use a heat gun at warm setting so the paint won't crack. Please share your findings once mounted so we can help the community.
Is it even possible to roll F8x fenders? It looks like it's already flat and rolled from factory?
      11-09-2016, 04:06 PM   #9
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
The SV-104 looks like a winner! Any more angles of this wheel?
      11-09-2016, 04:12 PM   #10
Signature Wheel BMW
How about this angle? Notice the muscular shoulders and sharp angles.
      11-09-2016, 04:13 PM   #11
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Rolling the fenders isn't just to flatten the excess sheet metal. A roller can also pull the existing fender out a few mm to make room for a more aggressive tire/wheel offset. Stance bro dudes have been doing this for a long time. Not recommended.
      11-09-2016, 04:14 PM   #12
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
HOLY FACK. That is beautiful.
      11-09-2016, 04:16 PM   #13
JamesGames
JamesGames's Avatar
I consider that pulling fenders, not rolling. Not a fan of pulling fenders but don't mind rolling the inner fender / lip to gain a little more clearance. Pulling fenders makes the fenders look messed up sometimes.
      11-09-2016, 04:18 PM   #14
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Come on... it's hella tight bruv.
JamesGames1326.00
      11-09-2016, 04:26 PM   #15
Signature Wheel BMW
Correct. The back quarter is pretty flat, front could be rolled which is pointless with the plastic limning in the way.
      11-09-2016, 05:28 PM   #16
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Any pricing info? Or did I miss that...
      11-09-2016, 11:13 PM   #17
Signature Wheel BMW
PM Sent
      11-10-2016, 08:15 AM   #18
Signature Wheel BMW
Signature SV103 in Brushed Black Tinted - 20x9.5 ET20 front and 20x11 ET40 rear. MPSS 265/30/20 and 295/30/20. Eibach Springs.
      11-10-2016, 11:43 AM   #19
LOW4LYF
LOW4LYF's Avatar
2163
Signature SV103 in Brushed Bronze - 20x9.5 ET20 front and 20x11 ET11 rear. MPSS 265/35/19 and 295/35/19. Eibach Springs.
265/30/20 295/30/20
      11-10-2016, 12:19 PM   #20
JamesGames
JamesGames's Avatar
Signature SV103 in Brushed Black Tinted - 20x9.5 ET20 front and 20x11 ET11 rear. MPSS 265/35/19 and 295/35/19. Eibach Springs.
ET 11 Rear with a 295? Typo?
      11-10-2016, 12:22 PM   #21
LOW4LYF
LOW4LYF's Avatar
2163
Yeah...somthing is off ... I guess 41 or 31?
      11-10-2016, 12:29 PM   #22
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
It's a typo. Probably put in ET11 by accident since the width is 11 inches. The offset is most likely ET40; default for this wheel in that width.
f80 wheel, f82 wheel, forged wheels, signature movement, signature wheel
f80post
