02-25-2022, 07:25 PM | #47 |
1427
Rep 2,650
Thus far, our VS-5RS is coming out on top, but I'm hoping the EC-7RS pulls a comeback. Luckily we are bringing both options out so you will have solid choices either way.
-Tom
02-28-2022, 10:02 AM | #48 | |
235
Rep 106
02-28-2022, 03:35 PM | #49 | |
1427
Rep 2,650
-Tom
03-01-2022, 03:37 PM | #50 |
1427
Rep 2,650
Max Discount Unlocked! Our 19 Forged Sprint Line Group Buy has reached the Max Discount of $500.00 off a set only a few days into this deal. Were excited to see where this deal goes after such a strong start and cant wait to get these wheels in your hands once they arrive. M2 Competition Sneak Peek We have a full feature of this car on the way including a mod list, but here is a quick look at our Brushed Clear 19 Sprint line wheels on an M2 competition. Wheels: Front: 19x9.5 ET28 Rear: 19x11 ET44 Tires: Michelin PS4S Front: 275/30-19 Rear: 305/30-19
03-08-2022, 01:38 PM | #53 | |
1427
Rep 2,650
Thanks for the pledge!
Our recommended staggered setup with rear-wheel offsets built specifically for the F8X Chassis is as follows: Front: 18x10" ET25 // Rear: 18x11" ET44 Available in: ARC-8, EC-7, EC-7RS, FL-5, SM-10, VS-5RS -Popular fitment -5mm front spacers may be required with certain aftermarket suspensions that reduce inner clearance. See suspension clearance section at the bottom of the guide. 18x9.5" ET22 front wheel can be used to avoid running spacers due to its superior inner clearance. Tires APEX Staff Pick: Front 275/35-18 // Rear 305/35-18 More fitment info and tire data can be found here: https://support.apexraceparts.com/hc...-Fitment-Guide -Tom
03-11-2022, 09:27 AM | #54 |
60
Rep 51
I'm on Ohlins suspension (not slammed). Stock camber plates. What offsets and size would work? Without spacers if possible?
2015 M3 - Carbahn Stage 1 - Ohlins R&T - Apex VS-5RS - Gintani Crankhub
03-11-2022, 02:14 PM | #55 | |
3525
Rep 6,752
For a staggered setup that will clear your Ohlins without any spacers, I would recommend the following fitment: Wheels Front: 18x9.5" ET22 // Rear: 18x11" ET44 -Available in: ARC-8, EC-7, EC-7RS, FL-5, SM-10, VS-5RS -Direct fit Tires APEX Staff Pick: Front 275/35-18 // Rear 305/35-18 -Direct fit With a 18x9.5" ET22 front and a 18x11" ET44 rear, you can run 275/35-18 front and 305/35-18 rear tires as a complete direct fit on an F8X M3/4 equipped with Ohlins coilovers. If you would like to check out some of our other F8X M3/4 offerings, our chassis specific fitment guide can be found here: https://support.apexraceparts.com/hc...-Fitment-Guide If you have any additional questions, please do not hesitate to reach out. -Geirsen
03-11-2022, 02:27 PM | #56 | |
60
Rep 51
thanks for the response. 19s are not an option??
03-11-2022, 02:35 PM | #57 |
3525
Rep 6,752
19"s are definitely an option and will actually be required if you have the larger CCB's. Fitment-wise they will pretty much be the same as the 18" setup. You can find all of our F8X applicable fitments in the guide I linked in my previous post.
-Geirsen
03-11-2022, 02:41 PM | #58 | |
60
Rep 51
03-14-2022, 04:54 PM | #59 |
3525
Rep 6,752
With 22 days left in our ongoing 19 Group Buy, we wanted to feature a few non-M 3 and 4 series on our 19x9 ET30 VS-5RS wheels. This is the least aggressive width and offset that we are launching during this Group Buy making it an excellent OEM+ option for front M-car fitment or square fitments on non-M 3 & 4 series detailed below. Wheels: 19x9 ET30 VS-5RS in Brushed Clear Front & Rear Tires: 245/35-19 Michelin PS4S
03-14-2022, 07:52 PM | #60 |
Rep 510
@Expert@ApexRaceParts do the wheels get made after the group buy ends or has manufacturing kicked off and those wise few that got in ahead of me will start seeing their precious metal soon?
Pledge #9,733,566 😭 |
03-29-2022, 11:22 AM | #61 | |
1427
Rep 2,650
-Tom
SilverLakeM3241.00 |
03-29-2022, 11:23 AM | #62 |
1427
Rep 2,650
19 Sprint Line Video Library With our marketing team cranking out the content, we wanted to give you the chance to view these wheels in all their glory. With a huge variety of chassis covered, these videos showcase our 19 Sprint line wheels on-car and on the road including on an F80 M3. We still have a few days before the Group Buy ends so dont miss your chance to pledge and save! F80 M3 F30 340i F32 440i F87 M2 Competition Sunset Orange F87 M2 Competition E90 M3 E92 M3
x.shell6580.00 |
04-01-2022, 03:55 PM | #63 |
1427
Rep 2,650
Despite our 19 Sprint Line Group Buy coming to an end, we arent fooling around. We have another stellar video showcasing our new Forged 19 Sprint Line wheels this time on a clean track-ready F80 owned by our friend Spencer.
Looking for the widest possible fitment without any fuss? Our 19 Staggered F8X M3/M4 specific fitment can do just that, allowing for a 10 front and 11 rear wheel as a direct fit on a completely stock vehicle. Pair that with a 275 width front and 305 width rear tire and you're ready to carve up your local canyon roads or hit the track and set a new PB. With only 4 days left, dont miss your chance to pledge for a set of these 19s Wheels and Tires: APEX VS-5RS in Brushed Clear 19x10 ET25 w/ 275/30-19 Michelin PS4S 19x11 ET44 w/ 305/30-19 Michelin PS4S APEX EC-7RS in Brushed Clear 19x10 ET25 w/ 275/30-19 Michelin PS4S 19x11 ET44 w/ 305/30-19 Michelin PS4S Suspension: MCS 1Way NR coilovers Ground Control camber plates 5in 2.25" Front spring w/ helper SPL Front Arms (minus lower arm) SPL rear control arms (all replaced) Brakes: GiroDisc oversized front rotors Alignment: Front: -3.8° camber / 0° toe Rear: -1.9° camber / 4mm toe in
04-04-2022, 07:05 PM | #64 |
3525
Rep 6,752
F82 M4 competition finished in an individual spec Imola red? Yes please! Through in-depth on car testing as well as laser scanning of every OEM brake kit offered, our 19 F8X specific fitments clear even the massive CCB/2NH calipers with room to spare. All while maximizing spoke concavity and preserving the ideal offsets needed for peak performance as well as a nice aggressive appearance.
Our 19 Sprint Line Group Buy ends tomorrow at midnight. Join the over 300 other enthusiasts that have pledged for a set of these wheels to lock in the deepest discount well offer on a set anytime soon! Wheels and Tires: APEX VS-5RS in Brushed Clear 19x10 ET25 w/ 275/30-19 Michelin PS4S 19x11 ET44 w/ 305/30-19 Michelin PS4S APEX EC-7RS in Brushed Clear 19x10 ET25 w/ 275/30-19 Michelin PS4S 19x11 ET44 w/ 305/30-19 Michelin PS4S Original Build/Spec: - 2018 M4 - Competition Package - Carbonstructure/Dakota Leather interior - Individual Imola Red II - 6 speed manual - Carbon fiber roof - M Performance carbon fiber mirror caps - M Performance carbon fiber front attachment (lip and splitters) - M Performance flow through spoiler Interior: - M Performance V2 steering wheel - M Performance dry carbon fiber steering wheel trim - M Performance carbon fiber / tri-stitch Alcantara e-brake and boot - M Performance Alcantara armrest - M Performance V2 shifter with tri-stitch Alcantara boot - IND painted start/stop button with bezel - Turner Motorsport polyurethane shifter bushing - Hardwired Valentine One V2 radar detector Exterior: - IKON Adaptive LED headlight retrofit - Replica V-style three piece diffuser - Replica (VLAND) GTS taillights - ARM Motorsport 90mm exhaust tips - IND painted front reflectors - IND painted hood and trunk roundels Suspension/Brakes/Driveline: - Macht Schnell Competition Sport lowering springs - F80 M3 CCB calipers - M2 Competition (2NH) rotors and pads - Castrol SRF brake fluid - Motul Gear Competition differential fluid - Stock alignment specs (waiting to do upgraded arms and adjustable sway bar links to corner balance) Engine: - Stock tune - ARM Motorsports resonated downpipes - MAD single midpipe with active brace - SSR charge pipes - BMC drop-in filters
x.shell6580.00 |
04-22-2022, 01:03 PM | #65 |
3525
Rep 6,752
While our 19 Sprint Line Group Buy has ended, we are still working on creating and editing content showcasing our latest wheel designs. We should have production wheels beginning to ship out to customers over the next few weeks and another huge thank you goes out to the BMW community for helping make this one of our most successful Group Buys ever.
Here are a collection of links to new feature threads showcasing these new designs. Select the images below to view the unique specs, modifications and video/photo showcases of our newest Forged wheel lines.
05-04-2022, 08:05 PM | #66 |
Rep 600
Just received my set of staggered 19" forged VS-5RS's and certainly glad I was part of the group buy. These are definitely light and look amazing.
