Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      02-20-2024, 03:15 PM   #1
cormy
Drives: M4 Comp
Has anyone actually used the flat tire inflators in these cars?
I can't really see it working in anything other than a very small pin hole. Then what, does the rim have to be cleaned?
I bought a mini 20" spare for the trunk and am trying to figure out a way to secure it down in the event of a front crash.
Was curious as to others experience.
      03-08-2024, 11:43 AM   #2
cormy
Drives: M4 Comp
Wow..so nobody ever got a flat while out on the road. Amazing--what luck!
      03-08-2024, 03:54 PM   #3
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
Drives: F80
If your a prepper then you should consider keeping a decent tire puncture patch kit in your trunk along with a Li powered inflator. Where I live contractors drop nails like they are seeding a gold course.
Tire shops dislike "fix-a-flat" sealants which make a spoogy mess of their tire mounting machine.
A friend had the compressed tire sealant thing explode in the trunk of his F80 while on track last summer (very hot day).
He pooped himself and his trunk was also a mess.
      03-28-2024, 09:05 AM   #4
paulo_f80m3
paulo_f80m3's Avatar
Drives: 01' E46 325i / 16' F80 M3
2001 BMW 325i  [8.50]
2016 BMW M3  [0.00]
Yeah I've never used the OEM kit. The tire sealer is most likely expired. I do have a tire plug kit, a small tool kit, and a small compressor though. I used it once a couple of years back. Got the tire warning for the left rear and pulled into a parking lot. Found a nail with air escaping from it. Went under the car and removed the nail, plugged the tire and filled it back up. The following day had the tire patched/plugged properly from the inside. I do also recommend a blanket of some sort though. The pavement was a bit hot.
mr.paulo.dias
dms-011134.00
f80post
