Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      03-18-2024, 12:34 AM   #1
Bladerosee
Bladerosee's Avatar
Drives: BMW M4
Front rim sizing questions
Can I run a 19x9 et44 on the front of the car? If not what sizes would fit in a 19 or 20? Looking at the bbs ci-r wheel and not sure what size will fit the front
      03-18-2024, 01:54 AM   #2
M3SQRD
M3SQRD's Avatar
2161
I suppose you could but then you’d need a 15 mm thick spacer to get it back to the stock offset.
The stock front is 18x9et29, 19x9et29 and 20x9et29 or, removing the diameter, a 9et29 wheel for width and offset. A common aftermarket front is 9.5et22 which has the same frontspacing as a 9et16. So if you wanted a stock look you’d run a 9et29 and if you wanted a flush look you’d run a 9et16 (not aggressive, stock camber).
Is this a street wheel setup? What size rear wheels are the ci-r offered in? Stock rear is 10et40. Commonly used rears are 10et30, 10.5et36, and 11et42.
      03-18-2024, 02:04 AM   #3
Bladerosee
Bladerosee's Avatar
Drives: BMW M4
I’d this a street wheel setup? What size rear wheels is the ci-r offered in? Stock rear is 10et40. Commonly used rears are 10et30, 10.5et36, and 11et42.
So pretty much some guy has a killer deal on set of rears in 20x9.5 et40 I will be running it at the drag once in a while since the tires I’m gonna mount are some drag radials that fit those rears but I just don’t really know how to find the correct fronts keep in mind my rims currently are the competition 666m rims at the moment
      03-18-2024, 06:03 AM   #4
M3SQRD
M3SQRD's Avatar
2161
A 9.5” wide wheel won’t allow you to run a proper rear tire for a f8x on the street. You definitely won’t be able to run a wide enough tire for the drag strip. Also, you’re stuck running a 20” rear with a short sidewall - don’t you want the tallest possible sidewall to maximize launch grip for the drag strip?
f80post
