      09-06-2017, 12:45 PM   #331
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Originally Posted by Dackelone View Post
You can... but you will also need new rear shocks bc on the 1M/M3's the bottom of the shocks mount differently than on a 135i. So new rear shocks are needed.
Control arms (wishbones and guide rods), not the camber arm ("roll over strut"...?)
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
Dackelone10588.50
      01-27-2018, 06:09 PM   #332
3k1n
Drives: Subaru Sti
Hi Does anyone know if the M3 rear lower control arm is a direct fit to the 135i.
      01-27-2018, 07:19 PM   #333
rhodesman
rhodesman's Avatar
Drives: E88 135i
2010 BMW 135i  [10.00]
Yes, 100%. Edit: doh! Yeah, the shock will need to be changed.
Dackelone10588.50
      01-28-2018, 03:40 PM   #334
fe1rx
Drives: 135i, 328i, Cayman S
Yes it fits, but you need to change to an M3 rear shock. The lower mounting points for the shock are different.
Dackelone10588.50
      01-28-2018, 11:55 PM   #335
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
The light sensor bracket doesn’t fit I think. I believe you need to make your own for the m3 rear lower camber arm.
      04-04-2018, 12:12 PM   #336
Cavpilot2k
Chief Warrant Officer
1025
Drives: like a damn lunatic
I am having installed the BMW PS plus M3 front control arms. I am considering M3 RSFBs, but I already have the Whiteline inserts, so I'm not sure if it's worth the parts & labor to upgrade from inserts to full bushings, from a "what will I feel?" perspective.
In talking with the shop (Turner motorsports, a known BMW specialist), they are suggesting I consider the rear guide rods and upper link arms while I'm at it.
My car is my DD and only used for frequent daily spirited driving - I don't track it.
I'd be interested to hear opinions on both the RSFB (if I already have inserts, is it worth it - bear in mind that my inserts have close to 50k miles - don't know if they wear...) and rear rods and arms (are they going to be felt and or worthwhile on a non-track car?).
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK
Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff
      04-04-2018, 04:28 PM   #337
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
The rear guide rods and upper link arms - are a sound upgrade. It will give your rear axle the alignment it needs since its lowered and camber'd out.
As for the M3/1M RSB's.... I guess it depends on the cost. Personally I love mine and they are worth the hassle to install. I would also suggest new DOT stainless steel brake lines too - since you have to drop the rear axle to install the RSB's.
Dackel
      04-05-2018, 07:16 PM   #338
oneBIGtoe
18
Drives: 135i
Wait - so if I order the entire ECS M3/1M rear upgrade kit, then when I choose my new struts or coilovers I need to order something different than a straight 135i fit?
2012 DSB e88 135i Dinan S2
      04-06-2018, 03:17 AM   #339
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Yes. The 1M rear shocks attach differently to the lower control arm than the 135i shocks.
Dackel
      04-11-2018, 10:36 PM   #340
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Bilstien B6 and B4 for e9x m3/1m e82 are now very affordable. B8 can be also a deal if you want shorter shock travel.
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      04-17-2018, 12:03 AM   #341
elitesales305
shmo
elitesales305's Avatar
Drives: honda
can anyone chime in that has a e88 .. do these kits fit our car??
No sig
      05-12-2018, 01:39 PM   #342
Zombie_Head
Zombie_Head's Avatar
Germany
594
Drives: E30 325i 4-Door
When working on the car today, i noticed that one of the control arms (maybe lower ones) did not have BMW or Lemförder stamped on them...instead they had TRW.
I thought TRW also made the non M (or standard) arms like Lemförder, but as i checked the online catalogs they do not, maybe an early TWR non M version?
Next time i am under the car i will take a picture with the part number, i really do not think they are TRW/M style ones but the car was registered by BMW Munich AG for 2 years before it was sold.
      05-23-2018, 09:48 AM   #343
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
TRW also makes parts for OEM (you knew that). Maybe there was shortage of Lemförder, and BMW switched to TRW for that one control arm...
TRW makes the calipers on my dad's GTI.
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread
      05-23-2018, 09:49 AM   #344
chris_flies
3027
All the 1'ers have the same suspension, and the E9x 3'ers, and some other cars...
      05-23-2018, 11:17 PM   #345
tree233
15
Drives: 2006 130i hotrod
Has anyone measured the track increase from the M3 control arms? How much longer are they than stock?
It's easy to find info on the camber increase, but I can't find any info on the track increase...
Also wouldn't the ultimate setup for track driven cars be the Meyle HD tension arms, with the bushing replaced with a spherical bearing? Due to the HD having a larger stronger ball joint.
      07-27-2018, 12:15 PM   #346
DLJ6
Drives: 2009 128i
Since my original bushings are shot @ 162k miles I am looking to do this mod/upgrade. ECS-Tuning's site indicates that the M3/1M Front Control Arm Upgrade Kit does not fit my E82 '09 128i but Turner Motorsports' indicates that it does.
Are there any other vendors of the TRW M3 arms/wishbone to check with?
I might end up having to just replace the bushings as neither vendor will have the M upgrade in stock until November..
Thanks
      07-27-2018, 12:46 PM   #347
gjm120
2183
Drives: 2013 128i, 2021 230i
Thanks
I'm certain they fit. You can usually find the arms pretty readily. Try FCP Euro. You sometimes can find them on Ebay or Amazon. Find the TRW number (it's JTCxxxx) and look around.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
      07-28-2018, 02:34 AM   #348
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
The 1M/M3 arms will fit, but they are slightly oversize compared the stock parts. Many people have them installed, so its definitely possible to persuade them to go into the stock 135i crossmember/front subframe. In my case I had a mechanic install them with all kinds of other suspension mods.
There is a current thread about the fitment aspect:
https://www.1addicts.com/forums/show....php?t=1518918
      04-26-2020, 11:57 AM   #349
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2014 BMW 528i  [10.00]
Not sponsored or anything just pointing this out because I'm looking to get these real soon (one of my bushings is making noise)
FCP Euro has the kit for $100 less, and doesn't include the headlight leveling rod.
https://www.fcpeuro.com/products/bmw...e9xm34piecekit
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      04-29-2022, 12:50 PM   #350
Almuliman
Drives: 2013 LMB 6MT 128i
Missed this thread and posted this on a new thread a while back, so just FYI: That kit is currently NA from FCP Euro. They told me they were having concerns about quality and are working on finding a new supply (still TRW / OEM? ). No ETA, but in the meantime Turner still has it.
      02-26-2024, 12:44 PM   #351
Almuliman
Turner has a kit with the upper arms from TRW and lower arms from Delphi and Precision Engineered Chassis for $272 (https://www.turnermotorsport.com/p-2...m-upgrade-kit/). They claim all parts are manufactured in Germany, which doesn't jive with that I've read about Delphi and PEC.
Does anyone have any experience with any of this? The kit altogether, Delphi and PEC for suspension parts, ...
      04-10-2024, 01:14 PM   #352
AshwinLB
47
Drives: 2008 BMW 135i 6MT
Originally Posted by Almuliman View Post
Turner has a kit with the upper arms from TRW and lower arms from Delphi and Precision Engineered Chassis for $272 (https://www.turnermotorsport.com/p-2...upgrade-kit/). They claim all parts are manufactured in Germany, which doesn't jive with that I've read about Delphi and PEC.
I’ve just bought Delphi m3 front lower control arms just because TRW arms are still on back order from what I presume is a change of manufacturing from Germany to Malaysia like the thrust arms did a few years ago. I haven’t installed them yet but the thing I noticed is that some of the seals are not all 100% seated correctly which has me weary but I’m not willing to pay for Genuine BMW and can’t really wait for TRW to come back in stock since I’m redoing my suspension for the season at the moment. So I’m taking the risk and will change them again in a few years with genuine or TRW.
For thrust arms, the geometry between non-m and m are the same, the difference being the fluid filled bushing vs solid rubber bushing on m3. I decided to go for non-m Lemforder arms (which are still made in Germany vs TRW Malaysia), and bought them with GAS monoball bearings pre-installed so they’re technically “better” than M3 spec.
Hope this helped your question somewhat even though I dont have actual driving experience with the parts yet.
Almuliman483.50
