Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Journal: N54 Total Engine Rebuild & Upgraded Internals
      04-29-2011, 11:07 AM   #221
dzenno
273
Drives:
Hey how's this going? Got the car back?
I had no idea that the stock OEM pistons were Mahle built forged units...is this correct? This would mean all the internals are forged which isn't what I thought all this time...i know for a fact the crank is forged and recently found out that the con rods are also forged...if the pistons are also forged that's just amazing
      05-01-2011, 07:44 AM   #222
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
The car is still not fully reassembled. It's getting there, though. The OP will be back with updates in due time, but due to time constraints these will not be forthcoming immediately.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      06-01-2011, 11:03 AM   #223
ETS Michael
ETS Michael's Avatar
Drives: 335i
Great Thread and Great Pictures!
      06-01-2011, 11:41 AM   #224
Alpina_B3_Lux
263
2009 335i  [8.90]
Pursuant to the latest info I have (as of yesterday), the car should be ready in the next 2-3 weeks. Took a bit more time than anticipated, mainly because the owner is distracted with other matters.
Alpina_B3_Lux
      06-01-2011, 12:05 PM   #225
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
WOW! It looks like that oil is not just getting into the intake little by little. It looks like the intake valves were DRIPPING with it.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      06-01-2011, 02:49 PM   #226
magic77
magic77's Avatar
258
Drives: ex- 335i
Alpina_B3_Lux
Lol judging by my last conversation with Tony at the current main matter its taken over his life, though going by end results its a good thing.
I cant wait to return
F30 335i M Sport - now departed
      06-04-2011, 09:07 PM   #227
MrBlonde
MrBlonde's Avatar
Australia
122
Drives: Audi TTRS, M Coupe, 1299
Perhaps the matter of a dry sump system could be revisited here.
.-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) 25th August 2004. +2010 X5 35D+
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
      07-17-2011, 01:09 PM   #228
zltm089
zltm089's Avatar
243
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
any updates?
      07-18-2011, 06:43 PM   #229
bo.benson
bo.benson's Avatar
Drives: 04 GTO A4, 97 Z71, & 07 335i
A little off topic but I have a question that maybe someone here can answer. In this pic(OP's modified) we're looking at the front of the crank.
I need to replace my crank hub due to an accident the car was in, I have a 32nd or so of wobble in the pulley which is causing the belt to derail and shred every so often. My question is, does the timing sprocket ride on this snout directly, ride on the hub itself, or in between the two? I'm trying to do this without timing tools and am very nervous about pulling the hub without having the cams and crank locked.
Thanks, Bo
-Bo
      09-13-2011, 09:14 PM   #230
AaronHoloster
Drives: BMW 335i
Cam shaft question
Nice setup there . I have a question when you are aligning the camshaft , are the 3D bar code suppose to be facing upward or downward also does it matter if the Vanos gear set at any angle before you torque down the camshaft bolt ( of cuz the cam trigger wheel are set with the tool)??
      10-14-2011, 12:22 AM   #231
prelude2perfect
prelude2perfect's Avatar
60
Drives: 2013 M5 and 2015 535i
Any updates?
      10-14-2011, 01:40 AM   #232
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Quote
Great Photo and Report
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      10-14-2011, 03:56 AM   #233
Alpina_B3_Lux
263
2009 335i  [8.90]
Originally Posted by prelude2perfect View Post
Any updates?
The car has been up and running for a few weeks now. However, it still needs some time to be broken in properly (1500 - 2000 miles) as the engine is basically new.
It does run very well even during this break-in phase, though. Much, much better than before.
I'm sure the OP will be back with a more detailed update once the car's broken in and he's had time to do a write-up.
Alpina_B3_Lux
      10-14-2011, 04:22 AM   #234
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Alpina_B3_Lux
great news! hated that brake in period
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      03-21-2012, 12:13 PM   #235
Kalud
Kalud's Avatar
24
Drives: e92 335i
Any updates ?
      03-26-2012, 08:31 PM   #236
Jeffman
Jeffman's Avatar
28
Drives: 2008 335xi E90
Originally Posted by Kalud View Post
Any updates ?
I just read all11 pages. Fascinating. I'd certainly like to hear an update. Anybody out there? Thanks.
      03-27-2012, 02:45 AM   #237
Alpina_B3_Lux
263
2009 335i  [8.90]
The OP is unfortunately very busy with a professional project right now, and has been for almost a year.
I can tell you that the engine has been modified accordingly, has been driven for around 1000 miles (break-in), then been taken apart to inspect all clearances. It has now been reassembled and the car is driving, and very well at that. Everything is working perfectly. The OP is planning to drive it on the Nürburgring this year, but it is currently unclear when that will happen.
I fear that he will have no time for an extensive report on this, at least for the time being.
Alpina_B3_Lux
      03-27-2012, 10:04 AM   #238
firechicken99
Drives: Black '07 335i
subscribed! Awesome stuff
      03-27-2012, 01:21 PM   #239
Fundahl
Drives: VO 1M, 300zx TT
Great to see this development!
      06-23-2012, 03:25 PM   #240
bo.benson
bo.benson's Avatar
Thanks, Bo
I suppose no one can still give me the answer to this? Still shredding belts, the most recent today resparked my want to replace the hub. I'd just really hate to slide it out and the lower sprocket and chain go flying upward.
-Bo
      09-20-2012, 12:53 AM   #241
flinchy
Drives: E82 135i
such a disappointing read, all these plans and still not realized a year and 3/4 later
      09-20-2012, 12:56 AM   #242
CaptainInsano
Drives: 2007 E92 335i 6MT
Holy dead thread revival batman.
FFTEC 6466 6mt 335i | FFTEC GTX3076R Evo IX
carbon, cylinder head, engine, intake, n54, n54 engine, piston, rebuild, valve
