ZPOST
  TireRack
      12-08-2023, 04:34 AM   #1
zoomnad
zoomnad's Avatar
Drives: 2008 BMW Z4si "M" suspension
Tightest lug bolts ever!!!
I had to check on the ABS sensor in my right rear wheel. What a surprise I had when I could NOT get the lug bolts off! My impact air gun could not (I have a 6hp 60-gallon compressor), and my 12" breaker bar could not, I needed a cheater bar of 24" on my 12" breaker bar! Plus, my weight (170 lbs.) to break them loose! never in my 57 years of car stuff have I seen anything like this! I have just bought the car because I always insist on tightening them with a torque wrench! I guess the tech thought this was a BMW TRUCK so he brought out the biggest impact gun!
If you want to be happy for a day, drink. If you want to be happy for a year, marry. If you want to be happy for a lifetime, drive a BMW Z4!
      12-08-2023, 06:28 AM   #2
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Not many mechanics use a torque wrench on lug nuts anymore, just hammer them on with an impact gun until they stop turning.
All the more reason to do your own work.
2008 E86 M coupe
      12-08-2023, 09:57 AM   #3
B328iC
Drives: 97 328iC, 2003 Z4
Had some so tight that we used a breaker bar, a concrete block & backed the car up for force on the bar.
      12-08-2023, 10:18 AM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
It can also be corrosion. For sure if it's this stuck and done my impact, there's bound to be damage on the wheels as the bolts are conical.
I always put some anti seize on the lug bolts (and always torque to spec, never use an impact...)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      12-09-2023, 02:51 AM   #5
zoomnad
zoomnad's Avatar
I always use a torque wrench but only use the impact wrench to unbolt them! The best I could find out on CarFax, the tires were installed before putting the car on the dealer lot! I never thought the Z4 would be perfect, and it is not, but when I am done going over it, it will be close.
zpost
