BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - California
BPM
      01-08-2024, 01:35 AM   #1
Z33KLF
Drives: E90 M3
WTB: TRW Front Left Lower Wishbone
WTB TRW Front Left Lower Wishbone
The reason I’m posting is because the front left lower wishbone is back ordered and I was not able to find any website/company that have this part in stock.
Part#: 31102283577
      01-14-2024, 12:48 PM   #2
krudmunk
Drives: F80 M3
You can also use Lemforder or OEM. I think TRW is no longer available and not making any at the moment since they relocated their factory.
I recently got monoball lower control arms and they came pressed in with Lemforder arms. Got them installed and handles like brand new car.
      01-14-2024, 06:44 PM   #3
tdott
Drives: M3
The tension arm is different. Lemforders are non-m arms that GAS uses to install their monoballs. Lemforder doesn't appear to make M3 arms, only non m, so I wouldn't used those since unlike the tension arms they are different dimensions and uses a rubber bushing.
      01-14-2024, 07:17 PM   #4
krudmunk
Drives: F80 M3
Had that concern too. But GAS provided this video. https://germanautosolutions.com/wp-c...Comparison.mp4
Ordered the lower control arms with GAS monoball and the side by side with OEM looks exactly same. Didn’t have any fitment issue.
I went with GAS front lower control arms and OEM front upper control arms.
      01-16-2024, 07:40 AM   #5
tdott
Drives: M3
That video only shows the tension arm (often referred to as the Front Lower Arm).
The Lower Wishbone (often referred to as the Front Lower Rearward Arm) is what the OP is referring to, and is the arm that is backordered. This arm isn't in the GAS video comparison and I haven't seen anyone claim the M and Non-m versions are the same, I believe they aren't because the M wishbone give more camber on non-ms.
TRW M Wishbone Arm.
Non-M Lemforder
      01-16-2024, 11:00 PM   #6
krudmunk
Drives: F80 M3
TRW M Wishbone Arm.
Non-M Lemforder
What you’re calling wishbone is called as front upper control arms by BMW.
Yes, you’re correct, there is an M and an non-M version. And to my knowledge, you can only buy genuine BMW upper control arms now. TRW is not selling the arms with the BMW logos shaved off at the moment. I don’t know whether TRW may or may not be supplying BMW these front upper control arms at the moment or BMW has enough inventory for now.
I went with OEM on the front upper control arms from FCPEuro. And got the front lower control arms with monoballs already pressed from GAS. Handles and feels like a brand new car now.
      01-17-2024, 08:11 AM   #7
tdott
Drives: M3
Sounds like we agree, I just wanted to correct your mistake again so no one is confused, no one calls it an upper arm, Realoem/tis calls it a wishbone, FCP/other site call it a "Front Rearward".
It would be wrong to call it an upper arm, it's the lowest arm in the front suspension.
      01-17-2024, 10:50 AM   #8
tdott
Drives: M3
I beleive you are wrong again, I ordered the right wishbone from FCP and the Left from RockAuto two weeks ago.
This is the TRW arm I got from FCP.
TRW Germany arm, with BMW logo shaved off. Not sure how long this will last but it's not like the tension arm that changed a while ago (atleast in my experience).
      01-17-2024, 11:11 AM   #9
itoto
itoto's Avatar
Drives: E90 M3
2009 BMW E90 M3  [0.00]
Can try delphi, i ordered them instead. Couldnt get trw because rockauto doesnt ship trw to california cause trw didnt submit prop65 stuff supposedly.
yt:itoto
insta:@m3.toto
chocstraw495.50
      01-17-2024, 10:44 PM   #10
krudmunk
Drives: F80 M3
TRW is the OEM manufacturer for these arms.
I think only BMW have TRW arms at this time. TRW is not supplying/selling themselves or giving to anyone else but BMW at this time. It could possibly be that BMW just have enough inventory.
I’m not sure what’s going on. But I waited for TRW to restock for a while since their price is so much lower. I couldn’t wait longer and ended going with FCP Euro. What you got is same as what I got.
      01-18-2024, 07:34 AM   #11
tdott
Drives: M3
      03-03-2024, 02:08 AM   #12
Z33KLF
Drives: E90 M3
How do u like these so far?
      03-04-2024, 07:32 AM   #13
tdott
Drives: M3
Didn't end up installing the Delphi arm, got a notification from FCP the TRW was instock, ordered it right away.
Will keep it as a spare.
      03-13-2024, 05:38 AM   #14
chocstraw
chocstraw's Avatar
496
Drives: E92 M3 ZCP
Just installed the Lemförder GAS control arms with monoballs and I am very pleased with the general build and quality.
If TRW is cost cutting by producing in Malaysia, I wouldn't put it beyond bean counters to cut costs on materials in the ball joint.
I guess if I didn't have the monoballs I'd be more concerned with the Lemförders but I think the monoball GAS arms are the best upgrade I've done besides camber plates for suspension.
      03-13-2024, 07:56 AM   #15
tdott
Drives: M3
FYI this thead is about the lower control arm, not the ones you got.
The left one has been mostly out of stock at FCP for the past couple of months.
m3post
