ZPOST
  TireRack
      03-18-2024, 09:36 AM   #1
belcom
belcom's Avatar
179
Drives: '18 540i, '06 Z4si, '07 Z4MC
255/35/18 tire on 3.0si with a 9" rim ET30
Has anyone tried to fit 255/35/18 tire on the front of 3.0si?
I got 2 sets of 224m wheels. Have these installed on the 3.0si right now but front tires are flat spotted and old. So I have to get rid of them. I was thinking of using the 2 rear wheels from the second set, and already have 2 x 255/35 PS4S tires I can throw on there.
So the front wheels would be 18x9 ET30 with 255/35 tire (Michelin PS4S). I do have ST X suspension on this car and can play with height but no camber plates (prefer not to buy camber plates as this is a street car and really no need for aggressive front camber).
Did anyone accomplish something similar? maybe with a different rim/wheel but similar specs and same width tires?
AK72286.00
      03-18-2024, 09:43 AM   #2
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Adding a 12mm spacer will decrease your offset, not increase! Since you're already running that wheel/tire combo on the rear, why not just move the rear to the front and do a static test fit?
      03-18-2024, 09:50 AM   #3
belcom
belcom's Avatar
179
Got the offset thing mixed up. Thanks for clarification. Statement removed.
I can do the static test with just the rim I suppose, or with one of the rear wheels. But I have 265/35 tires in the rear. So those are a bit wider.
      03-18-2024, 10:49 AM   #4
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Ahhh... didn't realize you currently have 265 on there
      03-18-2024, 10:58 AM   #5
belcom
belcom's Avatar
179
I do have a friend who has the same wheels with 255s in storage. So I can still test fit. he's got Indy 500s on his wheels which may have a bit different profile and width than Michelins but still a good test
AK72286.00
      03-22-2024, 11:53 PM   #6
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Running a Kumho Ecsta 730 255 35 18 on BBS RG-R RG760 18x8 et35 up front. Slight pinch, not enough to worry about. Doesn't rub. Camber -3.3. Rear is Ecsta730 265 35 18 on BBS RG762 18x9 et45
zpost
