Vishnu Tuned 335i w/ AWD Billet Turbos!!! 450whp to Redline..
12-20-2010, 07:42 PM | #89 |
Rep 5,780
I guess I am under the beleif that if you mod it, it is your responsibility regardless of being seen or not. Seems like the ethical thing to me.
12-20-2010, 07:46 PM | #90 | |
Rep 3,736
12-20-2010, 07:55 PM | #91 | |
27
Rep 324
Mike |
12-20-2010, 07:56 PM | #92 | |
27
Rep 324
Mike |
12-20-2010, 07:57 PM | #93 |
Rep 2,428
12-20-2010, 08:01 PM | #94 |
27
Rep 324
Thanks guys for the welcome.. I like this forum.. Its right up my alley at a FAST PACE.. I like sites that people actually post and contribute their thoughts on whether good or bad.. Nothing worse than making a thread only to see 1000 views and 4 replies.. LOL
Mike |
12-20-2010, 08:21 PM | #95 |
Rep 728
Exciting news! I'm in love w/ that torque curve
Do you have any testing done w/ 93oct? What's the est whp on 93oct no meth, for real world driving situations? If I understand correctly, meth injection won't help (w/ 110oct) as you're already at the limits of the fuel system? Well...., lower IATs for a lil more HP, but not dramatic gains as you can't turn up the boost any further?
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
12-20-2010, 08:29 PM | #96 |
Rep 3,460
Way to be way defensive over nothing.
Here are the facts: You made 440whp when running it to 6k, at that boost level, that is not impressive at all, stockers hit that. On the 7k run, you made what 422ish, better then stock, 2400dollars better though? some say yes, ill say no. Push these turbos past the stock turbo limits and I will BET my ass you will not hold power to 7k, you arnt even doing it now on the 420 run, which wasnt till 7k to begin with. Any estimates to how high these can be pushed to begin with? You said positive and negative replies are welcome, don't take it personal. |
12-20-2010, 08:31 PM | #97 | |
27
Rep 324
The METH does help with race gas because of the added fueling support for the Direct Injection Fuel system.. |
12-20-2010, 08:45 PM | #99 | |
27
Rep 324
Remember something else.. There is more to an engine setup than just the turbo.. You cant expect stock cams to hold power til 8k rpm just because the turbos holds boost til 8k.. These turbos CLEARLY hold power much closer to redline than stockers and are a huge gain on top end.. Even if you shift the car at 6800 it stays on full power no problem.. |
12-20-2010, 08:48 PM | #100 |
1746
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
It's also worth noting that the dyno MAP sensor calibrations are approx .8psi higher than the Procede calibrations. So when the Procede was run at 18psi, the dyno logged almost 19psi.
And for the last several runs (17psi and up), methanol was inadvertently disabled. I really wish I had another day with the car. But I'm sure Mike will post up final results with everything working as it should. |
12-20-2010, 08:48 PM | #101 | |
Rep 3,460
Boost and fuel wasnt set? Theres nothing to set, you were on race gas and meth, that power is REALLY low for that boost pressure on a fully bolted car. You need to do some reading on here and see what others have hit on stocker vs upgraded twins, your about 60-80 whp off. |
12-20-2010, 08:50 PM | #102 | |
27
Rep 324
Mike |
12-20-2010, 08:53 PM | #103 | |
Rep 3,460
Research how timing works on this car, the research what fuel actually does to this car. It a closed loop system 100percent of the time, once you set it, its done. As for timing, once it sees racegas and meth, its maxed out as no tune actually advances timing as of yet. I never said stockers hit 422whp at redline, but 20whp is not worth 2400 plus 1k to insall these thing. However people have different opinions, you just happen not to like mine. Btw, did you ignore the part where i said you are about 60-80whp off from other upgraded set ups? |
12-20-2010, 08:54 PM | #104 |
27
Rep 324
So far 2 sets sold and we will wait to hear back with results when they are complete.. Ill keep everyone updated.. Both members agreed to do before and after dynos..
Mike |
12-20-2010, 08:56 PM | #105 |
Rep 4,732
12-20-2010, 08:56 PM | #106 | |
27
Rep 324
These will make even more power.. This was just preliminary testing.. who is to say with the new plugs the car isnt make 465whp at 7k.. I havent had a chance to get the car back on the dyno.. |
12-20-2010, 08:59 PM | #108 |
Rep 4,732
12-20-2010, 08:59 PM | #109 | |
Rep 3,460
12-20-2010, 09:01 PM | #110 |
27
Rep 324
HEre is an example of a Race gas tune and similar power on Race gas..
PROcede v4 Autotuning AMS Intercooler AMS Catback Exhaust VK Downpipes CP-E Charge pipe/Tial BOV DCI 100 octane ~19psi From 5500 to 7000 its more like 60+hp and on 450hp car its like 90hp on top.. Do you know what that looks like in car lengths thru 4 gears or 5 or 6 gears on the highway.. I dont know about you but for 2400 Ill take 5-6 car lengths over a similar modded 335.. Depends on how hardcore you are about being FASTER than the guy next to you.. Even look at the TQ @ 6500rpm.. thats ours is still at 350 and the stockers at 300.. |
