05-26-2021, 06:20 PM | #23 |
Rep 4,917
Not sure why coil overs won't help him. As soon as you lay down the power, the car will tend to twist with the right wheel squatting which reduces grip on the left wheel causing it to spin. Not saying this is the end all - be all solution, but there is still huge benefit with coil overs.
Just doing the Dinan shockware upgrade on my xdrive made a difference on grip. Not LSD awesome, but in many cases where I had wheel slip from chassis rotation were now gone. |
05-27-2021, 02:07 AM | #24 | |
Rep 3,897
The twisting is so negligible that it makes 0 difference. Stock suspension of a nearly 2 ton vehicle is not made of cheese either. If your theory was right, the comfort-focused SUVs would have the most terrible traction ever.... and we all know that is not the case. Traction does NOT depend on suspension. Only handling and aerodynamics and of course comfort.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
05-27-2021, 02:17 AM | #26 | |
Rep 3,413
I have no grip problems at all. My setup is completely stock on 18" all weather high performance tires (square setup) and DHP with adaptive suspension. Oh, that's right. I forgot to mention I have the lowly 328 with a 4-banger N20 engine. No grip trickery required! Seriously, good luck finding the right balance to get the grip you need. I'm properly jealous of all your torque and horsepower. |
05-27-2021, 08:10 AM | #27 | |
Rep 4,917
Not sure if I'd compare a 5 ton / 200HP SUV to a much lighter 450HP car with this comparison, since there is a ton of other physics elements at bay. |
05-27-2021, 08:29 AM | #28 | |
Rep 3,897
Comparing different types of suspension, as in your example, to simply a change in height of the same suspension is BS to start with. But hey, if placebo made you think your traction was improved by lowering the car - it still counts as a success! So don't regret it.
05-27-2021, 09:08 AM | #29 | ||
Rep 891
Coilover kits almost always increase spring rates, which have a very large impact on traction, as does the ability to corner balance.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
alohasurftoad3127.50 Wires1664.50 |
05-27-2021, 03:10 PM | #30 | |
Rep 4,917
That being said, stiffer rear sway bars will also help by keeping both wheels planted. |
MacklinUSOB518.00 |
05-27-2021, 05:25 PM | #31 | |
Rep 15,858
Here's an interesting read. https://www.roadandtrack.com/car-cul...ave-less-grip/ |
MacklinUSOB518.00 |
05-27-2021, 05:41 PM | #32 | ||
Rep 891
If there is one BMW that is far from stiff it's the F2/3X xDrive. At the same time I absolutely agree with your opinion that some BMWs are unreasonably stiff, the Competition models being the worst offenders.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-27-2021 at 06:00 PM.. |
Wires1664.50 |
05-27-2021, 05:48 PM | #33 | |
Rep 4,917
Yeh, I need springs, just don't want to commit to them. My 340 is FAR from tight in the suspension area. Body rolls, it floats, far from "the ultimate driving machine". Dinan Shockware helped a lot, but that's a bandaid for sloppy springs. |
05-27-2021, 06:13 PM | #34 | |
Rep 891
To circle back to OP's original question for his RWD car, a diff is going to "rank first" considering you already have great street tires. It's also going to be the most expensive, but this game has always been pay to play, especially as you start down the path building a beast motor. Enjoy.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-27-2021 at 06:27 PM.. |
Wires1664.50 |
05-27-2021, 07:10 PM | #35 |
Rep 14,141
Drives: G82 M4C X-Drive
The MPS4S has excellent grip to wear characteristics, but if you are going big turbo then I would start with stickier tires. Sorry, wear is a trade off, you can't avoid it.
Another question is what you want to accomplish with these mods. Drag? Track? Or just highway pulls. Do you just want to be fast or do you want a balanced well handling car? If you just want to be fast on the street and on the highway then RE71R, Goodyear Supercar 3 or MPS4S in order of grip from greatest to least. You also might look into Falken RT660, Hankook RS4's, or Yoko AO52. Personally I love the RE71R's for track and street use. They are expensive and hard to find now however. Yes, I would get tires before anything else if you are really about true performance.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-28-2021, 05:41 AM | #36 |
Rep 470
The MP LSD on my RWD 340i has made for dramatic improvement in handling and traction. The easiest way to describe is it has changed the car from a one wheel drive to two.
In my humble opinion any increase in power is almost pointless until you install a LSD. You will not regret. |
05-28-2021, 06:00 AM | #37 |
Rep 1,238
Raise the boost reduction in 1st gear to 20%, and 10% in 2nd. If that doesn't work, reduce it a little more.
Enjoy being faster.
2023 M2. ZB. Manual.
2024 m235i |
05-28-2021, 09:53 AM | #38 |
Rep 1,934
Everyone is arguing about grip, but not specifying that dependent on the situation grip is solved differently. OP is not tracking so he is looking for straight line and from-a-dig grip. That is why suspension will not solve anything for him.
Once you move away from straight lines and want to improve grip on turns and such you need to focus on keeping the tires on the ground. That's when suspension comes in; coilovers, sway bars and the like. An LSD also helps here. For straight line grip you need to focus on wheel spin and that is dictated by the tire compound, contact patch size, and slip differential between the powered wheels. If this was a racing domain than you would also add downforce here . Focus people.
Wires1664.50 |
05-28-2021, 10:25 AM | #39 | |
Rep 891
OP if you're going to make the step to 200TW this year put in your order soon. A lot of the manufacturers do not produce them year-round so just keep that in mind.
05-28-2021, 11:34 AM | #40 | |
Rep 14,141
So… tires first.
05-28-2021, 11:40 AM | #41 | |||
Rep 710
MacklinUSOB518.00 |
05-28-2021, 11:53 AM | #42 |
Rep 4,376
definitely LSD for drag as well as turns
get a 2nd pair of OEM rear wheels with yokohama advan A052 255/35/19. swap when necessary, for (drag)racing. |
05-28-2021, 01:02 PM | #43 | ||||
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-28-2021 at 01:09 PM.. |
05-28-2021, 01:13 PM | #44 |
Rep 3,897
I meant no sarcasm in either sentence. 🤷🏻*♂️
coilovers, fitment, grip, lsd, stance, traction, tyres, wheel fitment, wheels |
