03-17-2024, 09:35 PM | #1 |
Rep 31
E92 M3 Handling
Hello all,
recently I picked up an E92 M3 with 96k miles (i know it’s high the deal was just a steal) and I haven’t really pushed the car yet because I am getting my rod bearings done soon and obviously don’t want to push the engine too hard. However, i have taken it onto some “twisty” roads and pushed it a little and the car just feels odd, almost loose and not really planted. I am coming from a 2018 Honda Civic Si which has electric power steering instead of the E9x very famous hydraulic steering so maybe I am just not used to it? I am not sure but I want to make sure that there isn’t any actual problems and it’s just me not being used to the car yet. I’m asking because the E9x M3 generation is KNOWN for its handling capabilities and it just feels odd when driving. Any suggestions or things it may be? Thank you so much to anyone that has some insight! |
03-17-2024, 11:48 PM | #2 |
Rep 5,959
With or without EDC? ZCP/Comp or standard model?
What’s tire condition like? Brand and model? When’s the last time the suspension was aligned? 96k miles is a lot of mileage on either EDC or standard dampers. Stock handling is well balanced; however, it can be improved with aftermarket suspension options that aren’t too expensive. 96k miles also is a lot of mileage on suspension components, sway bar drop links, bushings and monoballs as well as front strut upper mounts and rear upper shock mounts. Same goes for subframe bushings and differential bushings. What do you mean by loose? Oversteer? Does it feel like the front and rear suspensions aren’t communicating with each other or are out of phase/not settling together? |
03-17-2024, 11:59 PM | #3 |
Rep 31
It’s a 2009 E92 M3 comp. So i’m pretty sure that means it had EDC. There’s no oversteer or anything, the steer just feels like bouncy I guess?
I’m not really sure how to explain it perfectly without you actually being in the car you know? That’s understandable that with high mileage obviously comes with some wear on bushings, sway bars, etc. I just wanted to know if I had any problems or if I’m just really not used to it. Also, it’s on a winter tire setup with a lot of tread life left. It’s on 19” wheels and i ran 18” on my civic so maybe that could also be why. |
vchakerian13.50 |
03-18-2024, 12:11 AM | #4 | |
Rep 5,959
If it feels bouncy then the dampers could definitely be an issue at 96k miles. However, winter tires are definitely not something you want to be cornering on! Do you know if they are winter performance tires or winter snow/ice tires? Regardless, winter tires have taller and more flexible tread blocks and can create all kinds of weird handling traits. There may be other suspension issues but the winter tires are definitely not helping things. |
03-18-2024, 12:16 AM | #5 |
Rep 31
That’s definitely what it’s gotta be. I didn’t really corner that aggressive though don’t worry! I just wanted to feel what the M3 felt like 😂
But, I do have a pair of Michilen Pilot Sport 4S that the seller gave to me for free so once I get those on I’m sure that’ll make a huge difference. Thank you so much for your insight, I’ll put out an update once I get the summer setup on💪🏼 |
03-18-2024, 06:08 AM | #6 |
Rep 7,141
Car should feel fine and planted also with winter tires (drive Micheline Alpine myself) although obviously with less grip.
As mentioned def worth checking alignment. Recent example here: https://forums.m3cutters.co.uk/threa...stable.267803/ Does the EDC (button close to shifter) make any difference, or bouncy regardless of setting? |
PACarGuy686.50 |
03-18-2024, 06:37 AM | #7 | |
Rep 897
Drives: F87 M2CS
For modifications/updates, really just depends on what your budget is. Let us know and we can recommend you the most cost effective updates to get it feeling like a true M again
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
beckumf4.50 |
03-18-2024, 07:13 AM | #8 | |
Rep 7,141
Btw noticed every second ad over here these days say "E9x M Competition" typically without ZCP. |
03-18-2024, 11:24 AM | #9 |
Rep 31
Hello Reddevils7,
I am not really sure how to like directly reply to your chat but yes it is a ZCP. You made me unsure for a second lol, so I looked up the vin to make sure and it is definitely a zcp. I am aware of most aftermarket upgrades you can do for suspension but wasn’t too worried about it atm because of how highly reputable M suspension and handling is especially in the E9x generation. I also have to pay for my rod bearings soon, so I don’t really have deep enough pockets for everything right now 😔 |
03-18-2024, 11:27 AM | #10 |
424
Rep 304
Evolve did a series on a higher mileage e92 M3 and I imagine yours will need most of the suspension and bushing work they go into detail on:
My bushings and EDC are still in good shape at 84k miles, but I'm planning to refresh the EDC before 100k. Last edited by Cmassey3; 03-18-2024 at 06:31 PM.. |
03-18-2024, 11:32 AM | #11 | |
Rep 31
03-18-2024, 11:33 AM | #12 |
81
Rep 73
ZCP wasn't offered until 2011, so I'm pretty curious about how the VIN shows ZCP for a 2009. It could be possible that the previous owner just put 359M's on an EDC car?
03-18-2024, 11:35 AM | #13 |
Rep 31
03-18-2024, 11:35 AM | #14 |
81
Rep 73
03-18-2024, 11:36 AM | #15 |
Rep 31
03-18-2024, 12:01 PM | #17 |
Rep 31
Gotcha gotcha. Is there anyway to tell I have ZCP physically on the car because nothing else is coming up on the vin?
03-18-2024, 12:15 PM | #18 |
Rep 505
Drives: 2009 E93 M3 DCT
Post your VIN here so we can look.
03-18-2024, 12:22 PM | #20 |
Rep 505
03-18-2024, 12:29 PM | #22 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
It means lowered springs (10mm) all around, 359 style wheels, and more aggressive remapping of EDC.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
