Tuner Shootout (Procede / JB) - The Bench Tests
12-30-2008, 05:54 PM | #89 |
Modder Raider
758
Rep 8,633
Drives: M3
Thank you very much for doing this Scalbert!
I actually read every single word too. I have a question for you... I think I read somewhere that if the timing is controled via the DME, then this would be a not so good idea. Having said that, do you see a way where the JB3 can use the same method that the DME uses, but in a safe manner? Isn't it true..if the JB3 did not control timing then wouldn't we be pinging like crazy at the track?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
12-30-2008, 05:56 PM | #90 | |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
1) To phase offset the CAS waveform (CPS/CAS offset) or 2) To drive the coils directly using the factory CAS signal as a reference (for crank position). This requires tapping into the coil trigger wires which the JB3 doesn't do. There are no other way to actively control spark timing. Period. Sure, one can indirectly influence timing by manipulating IAT, coolant, oil, etc,. temperatures. This will forced the ECU to operate in different parts of the primary spark advance table (or in another "high det" table). Much like what the JB2 did with a switch to ground and a few resistors. But this is referred to as "influence" not "control" since you are completely dependent upon the factory ECU's compensation tables which can (and do) differ with various progman software updates. So basically, you cannot induce a X degree retard when RPM is Z, IAT is Y and RPM is Q. Looking at the hardware design of the JB3, I can tell that the intention as to adjust timing the same way it adjusts the wastegate signal-- by using the PWM output of the processor to pull it to ground. This didn't work because the timing signal is much more "dense" (58 teeth per one engine rotation) and the factory ECU is completely intolerant to the loss of data/teeth. The engine will simply shut off if a tooth is lost, replicated properly or implausibly placed with relation to the cam angle sensors. Can't treat it like a wastegate signal, that's for sure. So I'd bet that this is the reason Terry finally admitted to abandoning this approach as it was impossible to do with his limited hardware (no signal filtering, no crystal oscillator for time references, etc,.) So is he controlling timing some other way that has yet to be discovered by anyone else? Or is he relying on the factory knock control system to do all/most of the work? That's the question. One I'm sure scalbert is capable of answering with some more testing. Shiv Last edited by OpenFlash; 12-30-2008 at 06:15 PM.. |
12-30-2008, 06:04 PM | #91 |
Rep 4,445
I expected that from a pupil of Justice Stewart.
12-30-2008, 06:04 PM | #92 |
xbox gamertag: HuGeBluEmOnKeY
257
Rep 3,758
Im so lost right now, I thought he OP was going to do other tests like acceleration, etc...?
E92 335i alpine white | black dokota | auto | zpp | zsp | heated | iPod - ltbmw : vorsteiner : linea corsa : h&r : k&n : e92-lighting : expectalot-vinyl - --GONE-- |
12-30-2008, 06:07 PM | #93 | |
Rep 4,445
Why stop with just the last post, how about all your posts.
12-30-2008, 06:08 PM | #94 |
Rep 5,780
IMO, there is some sort of timing control whether it be direct or indirect. And no, I do not believe it is solely based on the DME's knock control system which would not be good. It would be a more indirect method considering we know what I/O are used and I have a couple of suspicions I will be looking at soon.
12-30-2008, 06:09 PM | #95 |
Rep 5,780
12-30-2008, 06:13 PM | #97 | |
Rep 4,445
Scalbert What other tests do you have in store for us? Is there anyway a Dinan flash can be incorporated into the mix?
12-30-2008, 06:14 PM | #98 |
257
Rep 3,758
Thanks man. Thats more understanding
12-30-2008, 06:16 PM | #99 |
863
Rep 2,897
Message to Shiv from a potential customer still on the fence
While everything you just said may be true.. Coming from you it just sounds defensive.. Seriously man, if your product is that much superior, just let IT do the talking for you. |
12-30-2008, 06:17 PM | #100 | |
Modder Raider
758
Rep 8,633
Drives: M3
IMO, I really wouldn't understand why Terry would overlook such an important component like this. I have never seen a million dollars, but that doesn't mean that it doesn't exist.
12-30-2008, 06:18 PM | #101 | |
Rep 5,780
Dinan would not lend its self to the next set of tests as wire splicing will be involved. But the dyno test could be if there is someone in the Atlanta area will to show. |
12-30-2008, 06:22 PM | #102 | |
Modder Raider
758
Rep 8,633
Drives: M3
Do you really think that Dinan would be kind enough to let us know how they are controling timing with their program? You did a great job Steve! (if that's your name, I saw other people calling you that lol) I'm not too interested in the dynos since I've pretty much been there but I can't wait to see some road test data!
12-30-2008, 06:28 PM | #103 |
225
Rep 2,548
Steve should be a technical moderator on this forum.
When, or if, Terry provides you with the information on timing control, can you disclose if it does or does not control timing? Basically a yes or no answer. We do not need the details since that is BMS's work. |
12-30-2008, 06:43 PM | #104 |
Rep 5,780
12-30-2008, 06:44 PM | #105 |
Rep 5,780
Yes, I will. But it will be under my own investigation as it will not be disclosed from BMS.
12-30-2008, 06:44 PM | #106 |
Rep 10,587
Johnson?
12-30-2008, 06:46 PM | #108 |
Rep 5,389
I disagree; I believe I have been very diplomatic with my recent posts in the past several weeks. In fact, I have restrained myself given the things that have been said about me on another so called BMW Enthusiast Forum. The things that the other Forum owner/moderator allows (and encourages) his members to say over there are just deplorable.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
12-30-2008, 06:46 PM | #109 |
94
Rep 2,339
If you find out on your own without help from others there would be no legal or eithical problem with publishing your findings.
What do I know? I'm insane.
12-30-2008, 06:49 PM | #110 |
Rep 10,587
