BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Sponsor M3 Project Cars Showcase
BPM
      07-21-2014, 02:57 PM   #1
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
▀▄ eas | Frozen White M3 Sedan gets the Works
Most of our customers modify their cars in multiple stages, having us install one or two parts during each visit. Others, like the owner of this Frozen White wrapped E90 M3, want everything done in one fell swoop. So many components of this 2008 M3 have been replaced or upgraded that it's essentially a brand new car. It really did get the works.
The first order of business was strapping this sedan to our Dynojet to see what kind of power it was making. In its stock form this 2008 M3 recorded 332whp and 256wtq, which from what we've seen from dynoing hundreds of M3s, is on the lower end of the spectrum. We would soon fix that by installing an ESS Tuning VT2-625 intercooled supercharger system. To help the supercharger make even more power, we swapped out the restrictive OEM exhaust system with an Eisenmann Race muffler mated to a Macht Schnell Race catless x-pipe. After the installation and some 95 octane fuel, this M3 recorded 566whp and 364wtq, which is a very substantial gain of 234whp and 108wtq. It's actually making more toque at the wheels now than it was making horsepower at the wheels when stock!
Pushing this kind of power, the car was now in need of better brakes and suspension. A set of Ohlins Road & Track DFV coilovers paired with Ground Control adjustable camber plates was the perfect suspension upgrade for this high-performance sedan. To further improve power delivery and stiffen up the ride, we installed a full set of Macht Schnell solid aluminum bushing in the subframe as well as the differential. Yellow StopTech brakes, consisting of 6-Piston calipers with 380mm rotors in front and 4-Piston calipers with 355mm rotors in the rear, will effortlessly stop this M3 from any speed while looking great behind the HRE P40 wheels.
Inside, we removed the old iDrive system and upgraded to the newer CIC version. An AWRON Kompressor 1 digital gauge display was installed in the dash to monitor the supercharger's boost level as well as engine temps, oil pressure, g-forces and more. Because this M3 is equipped with a 6-speed manual transmission, we installed a Rogue Engineering OCTANE short shift kit in combination with a billet aluminum Ultimate Clutch Pedal, which both allow for quicker and more controlled shifts.
When this M3 showed up to our facility, it was a mostly stock sedan. By the time we were finished, it was an absolute beast. We took a ton of photos during every step of this build, so take a few minutes to look around. Enjoy!
Modifications:
Awron Billet Velocity Stack
Awron DGA Gauge (Kompressor 1)
BMW CIC iDrive Retrofit
BMW Performance Carbon Fiber Trunk Spoiler
Eisenmann Race Exhaust System
ESS VT2-625 Supercharger System
Ground Control Adjustable Street Camber Plates
HRE P40 Wheel Set
Macht Schnell Solid Aluminum Differential Bushings
Macht Schnell Solid Aluminum Subframe Bushings
Macht Schnell Stainless Steel Race Catless X-Pipe
Ohlins Road & Track DFV Coilover System
Rogue Engineering OCTANE Short Shift Kit
StopTech Big Brake Kit (ST60 380mm Front, ST40 355mm Rear)
UCP Ultimate Clutch Pedal
Baseline Dyno Session
Parts Installation
Modified Dyno Session
The Finished Product
Click here to view the whole photo album on Flickr.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      07-21-2014, 03:42 PM   #2
Stronie
Stronie's Avatar
Drives: 2017 F80M3 Comp. 6MT
Wow! Awesome mods..... E90 FTW
      07-21-2014, 03:57 PM   #3
JRV
Drives: 2011.75 AWE90M3
Very cool! Thanks for posting!
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package
'11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery)
      07-21-2014, 05:25 PM   #4
GrahamDobbins
41
Drives: 2008 JBM M3 BPM Sport Stage II
Yep...looks good.
      07-21-2014, 05:53 PM   #5
webninja
Drives: 2011.75 E90 M3
That is a dramatic change, must be like driving a whole new car. Looks great with the BBK and wheels.
      07-21-2014, 06:22 PM   #6
M3Carbon
M3Carbon's Avatar
Drives: 2011 E92 M3, AW/FRE
Awesome build! Needs LCI conversion next.
Instagram @m3carbon
      07-21-2014, 08:11 PM   #7
nicebraces
///M
nicebraces's Avatar
Drives: '13 E93 M3/'14 Cayenne Turbo S
^+1 ... Slap on LCI tails and this ride's mint!!
      07-23-2014, 09:22 PM   #8
SilentAttack
SilentAttack's Avatar
163
Drives: 08 E90 Jerez Black 6MT
Nice mods!!! The only thing I could suggest is a LCI tail upgrade!! Best mod I have done so far.
Stupid Photobucket
      07-23-2014, 09:27 PM   #9
italyix
italyix's Avatar
Drives: '08 E90 M3
Speechless...
Rear needs a diffuser though.
Gratz!
      07-24-2014, 12:33 AM   #10
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Looks fantastic. Just need the LCi tails and trunk.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      07-25-2014, 11:43 AM   #11
hyperxm3
Drives: E90 2008
Car is not done yet. Need more time, stay tuned.
      07-27-2014, 06:43 AM   #12
UBER ///M3
Nüburgring Nordschleife BTG 8:05
UBER ///M3's Avatar
Germany
49
Drives: 2012 LEMANS BLUE E92 ZCP M3
So much win, awesome job!
ESS V2 Tune, ACM Test Pipes, AA Green Filter,Custom painted Recaro Pole Positions, Akrapovic slip on, Stoptech ST60/ Pagid pads, KW Clubsports, APEX ARC8s/Pilot Sport Cups, Hamann carbon fiber hood, ONEighty Headlight mod (selfmade), CRT lip with splitters, Blacked out/paint matched emblems, black aluminum extended paddles and pedals
      07-27-2014, 10:18 AM   #13
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Nice build
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      07-27-2014, 05:30 PM   #14
Chicken Little
Chicken Little's Avatar
9
Drives: 2013 E92 Frozen Black
Now that is what I am talking about. Nice job guys, the car looks great.
      08-02-2014, 11:43 AM   #15
davesaddiction
is fast cars
davesaddiction's Avatar
Drives: '08 E90 M3 6MT SSII BPM Stg II
Damn. Incredible. Call me first if you're ever looking to part with it!
Daddy's Rocket Sled!
Clarkson: "It is... pretty much perfect... Why don't I have one of these cars?"
Harris: "The saloon is definitely the M3 of choice."
      10-22-2022, 06:32 PM   #16
BigD90
Drives: 2008 Supercharged M3-6 speed
Just putting out the word that the frozen white m3is up for sale.
But its not white any longer
      10-30-2022, 09:52 AM   #17
Rochen_00
Rochen_00's Avatar
350
Drives: M3 e92
Nice car!!! Is a oem+
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position
      01-11-2023, 11:14 PM   #18
holomeow
Drives: BMW M3
Love the car!
m3post
