06-25-2015, 02:28 AM | #1 |
6585
Rep 5,305
F80 M3 / F82 M4 - Springs / Coilovers MASTER LIST
I've compiled a list of Springs and Coilovers for the F8X. This post will be updated as more information becomes available. Please help by letting me know if there is a change in status or if a new kit becomes available.
SPRINGS AC SCHNITZER - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1140744 http://f80.bimmerpost.com/forums/sho....php?t=1104262 DROP: 25-30mm/10-15mm; 0.98"-1.18"/0.39"-0.59" aFe SPRINGS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1233351 AST Suspension Lowering SPRINGS - Status: Available http://astsuspension-na.com/index.ph...bmw-m3m4-25mm/ EIBACH PRO KIT EURO - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1129065 http://f80.bimmerpost.com/forums/sho....php?t=1103311 DROP: 20mm/5-10mm; 0.78"/0.20"-0.40" EIBACH PRO KIT USA - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1023275 DROP: 20mm/5mm; 0.80"/0.20" EIBACH PRO KIT F83 - Status: Available Part #. E10-20-031-10-22 Front: 0.8 drop (182 lb/inch per Eibach) Rear: 0.6 drop (799 lb/inch per Eibach) EMMANUEL DESIGN SPRINGS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1341394 http://f80.bimmerpost.com/forums/sho...3#post21105883 DROP F80: 1.3"/0.3" DROP F82: 1.3"/0.9" H&R SPORT - Status: Available F80 - http://f80.bimmerpost.com/forums/sho....php?t=1076737 F80 F82 435i - http://f80.bimmerpost.com/forums/sho....php?t=1104141 H&R SUPER SPORT - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1125229 MACHT SCHNELL SPORT COMPETITION - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1159060 http://f80.bimmerpost.com/forums/sho....php?t=1156814 DROP: 28mm/19mm; 1.10"/0.75" Note:Macht Schnell uses the same spring set for the F80 and F82. Shims are provided for the F80 rear to balance out the height discrepancy. STATUS GRUPPE - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1112333 DROP F80: 33mm/20mm; 1.30"/0.8" DROP F82: 33mm/30.5mm; 1.30"/1.20" SWIFT SPEC R - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1145147 DROP F80: 25mm/10mm; 1.00"/0.40" DROP F82: 28mm/23mm; 1.10"/0.90" HEIGHT ADJ SLEEVE KITS aFe CONTROL VARIABLE HEIGHT SPRINGS - Status: Available https://afepower.com/afe-control-var...height-springs BMW M-PERFORMANCE COILOVER SLEEVE KIT - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1191427 DINAN - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1133605 GROUND CONTROL COILOVER CONVERSION KIT - Status: Available http://f80.bimmerpost.com/forums/sho...8#post19236448 KW HAS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1044712 MSS HEIGHT ADJUSTABLE SPRING SYSTEM KIT - Status: Available https://f80.bimmerpost.com/forums/sh....php?t=1690765 COILOVERS IMPORTANT INFO: Coilover kits that come with top-hats or camber plates have either 3 bolt pattern or 5 bolt pattern. Please reference your M3/M4 production date to choose the correct one. AC SCHNITZER RS ADJUSTABLE SUSPENSION - Status: Available http://shop.ac-schnitzer.co.uk/rs-ad...f82-6068-p.asp aFe CONTROL FEATHERLIGHT SINGLE ADJ - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1158803 AST 5100 1-Way, 5200 2-Way, 5300 3-Way - Status: Available http://f80.bimmerpost.com/forums/sho...&highlight=ast Review: http://f80.bimmerpost.com/forums/sho....php?t=1413065 BC RACING - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1042668 BILSTEIN PSS9 / PSS10 - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1129901 BILSTEIN CLUBSPORT - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1046894 BILSTEIN DAMPTRONIC - Status: Dev http://f80.bimmerpost.com/forums/sho....php?t=1126739 CA TUNED COILOVERS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1182388 Confirmed: CA Tuned kits are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs. FORTUNE AUTO - Status: Dev http://f80.bimmerpost.com/forums/sho....php?t=1112324 H&R Street Performance Coilovers - Status: Available https://www.ecstuning.com/b-h-and-r-...vers/50478~hr/ JRZ RS TWO - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1132585 http://f80.bimmerpost.com/forums/sho....php?t=1045730 Confirmed: JRZ RS TWO kits are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs. For the JRZ RS TWO coilovers you can choose between Touring and Sport. The Touring version utilizes the OEM top hats. The Sport version has the option(s) to include camber plates and rear mounting plates or using the OEM top hats. KW Variant 3 - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1062872 KW Variant 4 - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1477618 KW CLUBSPORT 2-WAY AND 3-WAY - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1079056 Confirmed: KW Clubsports are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs. KW GTS-SPEC CLUBSPORT 3-WAY- Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1221809 Video here - http://f80.bimmerpost.com/forums/sho....php?t=1249626 The new MSRP places the 3 way ClubSport closer in price to the 2 way adjustable ClubSport, enabling more M4 drivers to enjoy some of the magic that is available in the M4 GTS. KW Adaptive DDC - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1411096 MOTION CONTROL SUSPENSION - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1184964 http://f80.bimmerpost.com/forums/sho...9&postcount=51 http://www.motioncontrolsuspension.c...ts/prices.html For the MCS coilovers you can choose between MCS 2-Way and MCS 3-Way. Ground Control Camber plates can be paired with this kit. Damper and Spring Rate values are all customizable. MOTON ADJUSTABLE COILOVERS - Status: Available http://f80.bimmerpost.com/forums/sho...php?p=19702168 Confirmed: Moton Adjustable Coiovers will be available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs. Moton Adjustable Coilovers comes in the following configurations: 2-Way Sport, 3-Way Motorsport Pro, and 4-Way Motorsport Pro. The 3-way and 4-way Motorsport Pro rears will have a true spring-coil-over-shock configuration. NITRON COILOVERS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1385671 OHLINS Road & Track - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1193450 OHLINS TTX - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1129675 The TTX is built to spec. SACHS ZF COILOVERS - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1333320 STATUS GRUPPE COILOVERS - Status: Available http://f80.bimmerpost.com/forums/sho...9&postcount=32 TC KLINE - Status: Available http://f80.bimmerpost.com/forums/sho....php?t=1072499 Confirmed: TC KLINE SA and DA are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs. SPRING RATE CONVERSION OEM spring rates for the F80/F82 is 185 lb/in Front, 575 lb/in Rear OEM COMPETITION PACK spring rates for the F80/F82 is 198 lbs/in Front, 685 lbs/in Rear --------------------------- kg/mm to lbs/inch --------------------------- 2.0 kg/mm = 112 lb/inch 3.0 kg/mm = 168 lb/inch 4.0 kg/mm = 224 lb/inch 5.0 kg/mm = 280 lb/inch 6.0 kg/mm = 336 lb/inch 7.0 kg/mm = 392 lb/inch 8.0 kg/mm = 448 lb/inch 9.0 kg/mm = 504 lb/inch 10 kg/mm = 560 lb/inch 11 kg/mm = 616 lb/inch 12 kg/mm = 672 lb/inch 13 kg/mm = 728 lb/inch 14 kg/mm = 784 lb/inch 15 kg/mm = 840 lb/inch 16 kg/mm = 896 lb/inch --------------------------- lbs/inch to N/mm --------------------------- 300 lb/inch = 53 N/mm 350 lb/inch = 61 N/mm 400 lb/inch = 70 N/mm 450 lb/inch = 79 N/mm 500 lb/inch = 88 N/mm 550 lb/inch = 96 N/mm 600 lb/inch = 105 N/mm 650 lb/inch = 114 N/mm 700 lb/inch = 123 N/mm 750 lb/inch = 131 N/mm 800 lb/inch = 140 N/mm 850 lb/inch = 149 N/mm 900 lb/inch = 158 N/mm 950 lb/inch = 166 N/mm 1000 lb/inch = 175 N/mm 1050 lb/inch = 184 N/mm 1100 lb/inch = 193 N/mm --------------------------- Torque Specs and Bolt Information: Front Suspension: Plastic Shroud Bolts - 10mm - ¼ Turn Carbon Brace Bolts - 13mm - 12 ft.lbs. Carbon Brace to Coolant Tank Bolt - 10mm - Snug (A) Aluminum Brace E-Torx Bolts - 9mm - 25 ft.lbs. (B) Aluminum Brace E-Torx Bolts - 10mm - 30 ft.lbs. (C) Aluminum Brace Cowl Bolts - 16mm - 35 ft.lbs Strut Hat Bolts - 13mm - 25 ft.lbs. Strut Spindle Nut - 18mm-12pt - 25 ft.lbs. Strut Pinch Bolts - 16mm - 60 ft.lbs. Sway Bar End Links - 16mm/T30 - 44 ft.lbs. Headlight Leveling Sensor - 10mm - Snug Rear: Lower Strut Bolt - 18mm - 74 ft.lbs. Eccentric Bolt - 21mm/18mm - 74 ft.lbs. Headlight Leveling Sensor - 10mm - Snug --------------------------- M-Performance HAS DIY INSTALL: Thanks to Tommy L Garage for the video tutorial. Thread here: https://f80.bimmerpost.com/forums/sh....php?t=1633885 ////////////////////////////////////////////////////////////////////////////// Last edited by x.shell; 01-31-2022 at 08:26 PM.. |
31
MovingChicane109.50 CAOZKAN98.00 yuKon2242.50 EdM54069.50 FlyingLow78930.50 highdesertf8012.00 IM2C2068.50 TProfit81.50 zorrro436.00 Remonster824.00 DLag30103.50 Palomequet159.50 FatHulk127.50 ShawnOST94.50 thecarsavant35.50 krm347.00 noemon51.50 |
06-25-2015, 11:14 AM | #2 |
Race to win.
60
Rep 271
Very nice and complete list, this should be a sticky!
Current: 2003.5 E46 ///M3 6MT - 2019 Ford Raptor 802A
Past: 2015 F80 ///M3 6MT - 2006 E46 ///M3 6MT - 1999 E36 ///M3 5MT - 1991 E30 ///M3 5MT |
06-25-2015, 11:33 AM | #3 |
Rep 1,061
Very informative, thank you for organizing!
2015 F82 YMB M4 (Feb 28th ED, re-deliveried on Apr 18th) |My 2015 YMB M4 ED Journal 2008 E92 SSII M3 Coupe (Sold) | My long gone 2008 E92 SSII M3 2002 E39 SG 530i (Gone) |
06-25-2015, 11:58 AM | #4 |
Rep 399
Thanks for working this up. Maybe classify by linear or progressive ?
Delivered 11/28
YMB F80 - Excutive, DCT, and SO int. Current ///AMG 2009 P30 Calcite White C63 - V4 Eurocharged ******* 2012 Mini Countryman S JCW |
06-25-2015, 12:17 PM | #5 |
6585
Rep 5,305
That would be great. I think I read that the Eibachs have linear fronts and progressive rears. Lots of information being thrown out in threads, so I'm not sure what information is correct. If you know that a specific product is linear or progressive, let me know and I'll update the list.
06-26-2015, 01:46 PM | #6 |
Supreme Leader
2284
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
Sweet post. This should be a sticky
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
06-26-2015, 03:24 PM | #7 |
6585
Rep 5,305
06-29-2015, 12:22 PM | #9 |
Supreme Leader
2284
Rep 6,548
SupremePOWER
07-01-2015, 01:13 PM | #15 |
562
Rep 1,340
07-01-2015, 02:17 PM | #16 |
Supreme Leader
2284
Rep 6,548
Only if the springs dont go too low otherwise the shocks are no longer in the proper operating range.
Positive reports coming back from the AC Schnitzer springs....we are curious to see how the Eibach USA springs will perform.
SupremePOWER
07-06-2015, 02:52 PM | #20 |
27
Rep 372
Awesome, Was looking for something like this!
2007 E92 335i - SOLD
2008 E92 335i - SOLD 2008 G37S - SOLD 2005 G35S - SOLD 1988 RX7 TURBO II - SOLD but never forgotten |
coilovers, sleeve kit, springs, suspension |
