      08-11-2013, 03:29 PM   #1
Freon
Drives: 2009 135i
DIY: Whiteline rear subframe inserts
edit: new imgur gallery link in case img links break or do not load:
View post on imgur.com
Picked up a set of Whiteline rear subframe inserts after reading the thread in suspension subforum. Decided not to go with the full M3 set due to labor involved. It looks like these should actually do a really good job anyway. This is a DIY for a home install with no lift. Shouldn't really matter, though.
Special tools needed: E18 female torx. Had to hunt for one of these. 16mm ratcheting crescent wrench would be super nice, but not required.
Here are the inserts before install. This is the rear pair with a subframe bolt sticking through to show approximately how they sit when installed. I think I actually got them rotated 90 degrees out, but you get the general idea. The extra single piece on the top left is the other side rear bottom insert turned bottom up.
To get started, chock your front tires, lift the rear of the car with your jack on the differential. Put your jackstands in place. If you don't have any I suggest getting some BMW jackstand adapters. Take off the rear tires, it will make life a LOT easier especially if you have no lift.
Leave the jack in place under the differential as it will keep load off the subframe bolts. Take out the two rear subframe bolts with an E18 bit (18mm female torx). They should come out by hand after you get them started.
Back to the front, you'll have to take two 16mm bolts out of a extra diagonal bracket that connects the front of the subframe to the chassis.
The bolts are hidden and a pain in the ass to get to. You can use a 16mm crescent wrench or take some of the plastic off. This is immediately in front of the rear tire.
I think you really need to full remove them to get enough droop to fit the inserts in.
Once those two bolts are out on each side, loosen the front subframe bolts. You'll need an extension to fit up into the mount bracket. Same E18 bolt head as the rear subframe bolts. I'd loosen them all the way then put them back about 3-4 full turns. With a jack under the rear you might be able to just remove them, but I left them in place to help keep the subframe aligned.
Now back to the rear subframe bolts. Lower your jack until you have room to place the upper rear subframe insert in. Grease it up (I lost the grease that came with the pack, just used some general purpose grease), and insert it. The rear upper has the skirts facing inside and outside, not front to back. It really only goes in one way, but pay attention.
Once both sides are in, grease up the rear lower, push it in (there are "keys" on the bottom outside edge that match up with the subframe so you can rotate it correctly). Jack the diff back up so you can get the rear subframe bolts back in 3-4 full turns on both sides.
Back to the front mounts, fully remove the subframe bolts. Lower the jack off the differential. There should be just enough room to slide in the inserts. I started with the top. This one was tricky to correctly align. I believe the skirts go front and back, and the block that hide under the rim go to the sides. Sorry, not 100% sure, forgot already, but you should put your finger in there and try to match the shapes correctly.
I think this picture shows the skirts towards the sides but I ended up installing it rotated 90 degrees from this picture (this is passenger/right side). Sorry, I don't recall exactly how they have to be rotated. It's not obvious, so jam your finger in the top and see which way fits right. The front upper insert is the only one that is not obvious.
Again, grease them up, and you'll have to kind of jam them in. Be very careful that the fingers do not get bent over. Make sure then go straight into the bushing. I had to jam them in a bit due to clearance as the front of the subframe doesn't like to sag enough to make it easy.
The bottom front insert is easy to align because there is a "key" that matches with the subframe as seen here, just like the rear bottom inserts (bottom front passenger side subframe insert here):
Once in, put your front subframe bolts back in, tighten, then put the two 16mm brace bolts back in, and if you removed the plastic reinstall. Go back to the rear subframe bolts and tighten those. Try to keep an eye on the outer exposed lip of the inserts so they do not fold under. I had to use a small flathead to keep the lip from folding under itself on a few spots on the top inserts, both front and back.
Lower jack, re-torque all your subframe bolts, put your wheels back on, jack the car back off your jackstands, remove jackstands, lower car, and you should be good!
I may go back and check torque again later to see if the subframe settles any.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
Appreciate 7
Mandinca119.50
      08-11-2013, 04:23 PM   #2
jordantii
115
Drives: M2 Sea
Perfect timing. Thanks for the DIY. Looks pretty straight forward. Can you tell us who you bought them from and how long did it take to get them once ordered?
Thanks.
      08-11-2013, 04:30 PM   #3
Freon
Drives: 2009 135i
http://www.aftermarketsuspensionpart...sp?prod=KDT918
They were super quick with shipping. I think it only took 3 or 4 business days.
It is pretty straight forward. 1/5 difficulty. Whiteline includes instructions and grease. Their instructions are pretty good and include photos (you can see them in the first pic). My DIY is pretty much their instructions but I don't think they mention using a jack on the diff or the front bracket piece (also missing from pics). The instructions are labeled E90, so the E90 must not have that extra bracket that ties the subframe to the chassis.
      08-11-2013, 04:49 PM   #4
jordantii
115
Drives: M2 Sea
Great, Thanks for the link! Where are they located?
      08-11-2013, 05:44 PM   #5
JimD
JimD's Avatar
369
Drives: 128i convertible
Thanks for the DIY. The price is certainly reasonable. Did they improve handling?
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      08-12-2013, 10:12 AM   #6
Freon
Drives: 2009 135i
There is one turn I make every day on the way to work, left hand turn onto a road with a fair amount of crest. It always felt before like as I went over the crest in the road the car kind of "flopped" over before it settled. There was that sort of mushy center to the car that took a second to resolve. A lot of that is gone now. I imagine the remainder is due to the other bushings that still have slop in them, both front and rear.
There is no increase in NVH either that I can tell. Maybe a tiny bit more of a thud or thump gets transmitted to the chassis when shifting hard, but nothing while just driving around or even in corners.
      08-12-2013, 11:39 AM   #7
jordantii
115
Drives: M2 Sea
Ordered yesterday, shipped today will be here by thursday and i will install on Friday. If I can get rid of half the slop/shake I will be happy with the $53.00 purchase.
      08-13-2013, 09:40 AM   #8
jzmundy
jzmundy's Avatar
991
Drives: F97
Thanks for the DIY! Trying to decide between these or the stiffer (albeit more $$$) black Powerflex inserts.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S
      08-13-2013, 09:54 AM   #9
jordantii
115
Drives: M2 Sea
I have been thinking about all of the options out there as well. And I concluded that for 55 bucks and an hour of my time, the Whitelines were a no brainer. Just to see where I end up. My car is totally stock with warranty for another year or so. And I am not interested in doing a bunch of mods at this time. I have had my share of modified cars from mild to full race and everything in between. But I hate the way the rear of the car feels and don't want to spend close to 900 for the m3 bushings. So again the Whitelines make the most sense for me.
I am very familiar with the rear end dynamics and will be able to tell the difference quite easily once installed.
I should have them installed on Friday and will report back.
      08-13-2013, 10:06 AM   #10
jzmundy
jzmundy's Avatar
991
Drives: F97
Looking forward to your impressions! Thanks!!
Now - F97, Macan S
      08-13-2013, 12:57 PM   #11
Katkarot
29
Drives: 2010MDX 2012135i
Nicely done Freon and great DIY instructions.
I have the Whiteline inserts installed about a month ago and I think it's great value/performance. Really tights the rear a lot. I do have other pieces such as M3 FSB and Dinan suspension kit that help as well. The inserts just ties everything together nicely.
      08-15-2013, 08:22 AM   #12
jordantii
115
Drives: M2 Sea
Hey Freon, where did you find the e18 socket?
      08-15-2013, 10:19 AM   #13
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
I saw a bunch on eBay. Picked up a Snap On for $10. There were off brands for cheaper ($6 maybe?). Of course your local hardware or auto shops might stock it. I just didn't want to drive all over town looking for sort of an unusual socket.
____________________________
      08-15-2013, 01:41 PM   #14
Freon
Drives: 2009 135i
I got this set which covers from E4 up to E20:
http://www.amazon.com/gp/product/B0002SQEW8/
The steering rack is E12 and I imagine there are other uses of E-torx bolts, so I decided just to get an entire set. The local auto parts stores only had up to E16 so I had to order them off the internet.
Also after getting some more driving time in I notice less slop when I start to accelerate hard out of turns. I am more confident when applying throttle when unrolling the steering wheel and accelerating out of turns. Also, on very tight corners there seems to be less wheel hop on the inside tire when accelerating hard. Again, it's not like it fixes all the slop in all the bushings or the soft stock suspension, but it helps a ton. For the money and effort a great mod.
      08-15-2013, 01:46 PM   #15
jordantii
115
Drives: M2 Sea
Borrowed one from a friend. I'll order one now so I have it.
So I finished the install and its pretty much as Freon said. The rears are simple and the fronts are slightly hard to get the upper bushing in. And be carefull becuse the front upper looks like it can install in 2 directions but there is only one right way.
That being said it took me about 1.5 hours total from pull in the garage to back on the wheels.
I did a test drive of about 10 miles on some smooth and bumpy roads. I can tell you that the subframe is now more located and has considerable less movement. I did not notice the "second" set taking place as it would before. Is there a little bit of subframe movement? Yes but it is minor and is what you would feel in a car that is properly bushed.
I have yet to corner over any bumps so my take on the "subframe steer" is non existent at this point. But my first impressions are these inserts are worth the price and effort. I have never been a fan of inserts but in this case they work quite well and are a good alternative price wise to the M3 bits. I have not driven a car with the M3 bushings so I can't compare them. If this is what the M3 bushings would have felt like I would have been happy with the results.
After I put some more miles on them I will give an update. There is a particular corner with RR tracks that has always upset the rear of the car and should be a good indicator of how the inserts are performing. So far the dynamics of the rear end are much better and at this point I would recomend them as a sound alternative. I ordered them from the link that Freon posted and they arrived yesterday, ordered on Sunday. So quite fast and in stock.
      08-15-2013, 02:52 PM   #16
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
That was my problem - I already have a set, but it only goes up to E16. Problem is, the socket I ordered was supposedly delivered this morning (per tracking number), but nothing on my doorstep. So now I have a claim in w/ USPS, other wise I'd be installing these right now...
Anyway, thanks everyone for install info, impressions, etc.
      08-15-2013, 03:49 PM   #17
jordantii
115
Drives: M2 Sea
You can always find a local tool truck to get the socket. I was in the same boat as you. I have a set and need the 18.
      08-23-2013, 12:31 AM   #18
sliderpass
Drives:
<snip>
I just got these installed as in Australia by the time you buy M3 bushings have them installed with an alignment it’s about $1,000.The inserts including install were less than $200.
Still a bit premature for me but I'd more or less fully agree with this post. It's not an amazing transformation, but a good improvement & I'm not one to try and justify something to myself just because I paid $$$. NVH is hardly any more, slight however.
The inserts are enough for me to now realise my rear wheels need a balance - didn't notice any wheel vibration before the inserts. Over bad quality roads the rear doesn't feel as mushy..I'd say it's 30% improvement..
For the price you can’t go wrong, it's completely worth it. I've been in a car with M3 bushings (and coilovers unfortunately) so I can't draw a direct comparison however I can't see the M3 bushings being a night and day difference over these (and worth the extra $500 at least?).
Suspension wise I'm completely stock, and running decent street rubber (non-rft's)
Simon
      08-29-2013, 03:18 PM   #19
jordantii
115
Drives: M2 Sea
So it's been about 2 weeks since I did the install and my impression of the inserts remains the same. The rear is much more stable. Better than 30%. I would say its very acceptable with slight unwanted movements but totally manageable. If this was how the car came from the factory, I doubt we would have many complaints.
I hit the corner with the RR tracks several times in both directions and the car stays pretty settled. Maybe a slight secondary movement but that could be normal due to the tracks in the middle of the corner.
Overall I would do this mod again. It really is a no brainer considering the cost and effort it takes to install them. Now I just have to see how they long they last.
      09-03-2013, 06:01 AM   #20
_Ryan_
59
Drives: E87 130i
2005 BMW 130i  [5.24]
Fit them. Mine were fitted with M3 arms all round and B14s, I can tell what has done what, subframe doesnt wiggle nor slop. Car feels more connected. Best VFM mod for a 1er.
M3 arms should def be considered too.
      09-03-2013, 10:25 PM   #21
lastMleft
lastMleft's Avatar
Drives: e92 M3
This sounds pretty good, I might try this.
      10-07-2013, 06:41 AM   #22
Naoto
warranty denied.
Japan
13
Drives: 2011 135i
i finally got around to installing mine this past weekend. there is definitely a noticable difference, as the car isn't as "bouncy". it only took about an hour and a half to install.
