05-03-2020, 12:27 PM | #1 |
Homer Yen
130
Rep 76
Recommendation(s) to Upgrade HIFI via Plug-N-Play Approach?
Hello Forum Mates and Audiophiles -
I've read through many hours of posts within the Audio-related threads (here and on various other BMW forums). I most appreciated those contributors who have provided fact-based data on the topic of upgrading the HIFI (S676A) system. May I ask for your recommendation(s) as I am just turning my attention to upgrading my HIFI system. My audio components are still stock in my F30. PLEASE - MY APPROACH IS TO KEEP MY BUILD/UPGRADES AS PLUG-AND-PLAY (PNP) AS POSSIBLE. While I understand that there are excellent examples out there of creative approaches (recommendations for various amplifiers that require a different mounting solution, addition of trunk woofer, augmenting enclosures, etc...), I kindly ask that you do not recommend anything other than a PNP option. ALSO keep in mind that that my car has the HIFI system. If you are looking to upgrade from whatever premium system you have, you may wish to start a new thread for that. Thank you in advance! My approach could be viewed as a little bit sideways, but this is why I'm hoping you'll lend me your wisdom: Step #1: Earthquake SWS-8Xi 8-inch Underseat Woofers. One product where there seems to be unanimous approval (as well as supporting data) is upgrading the stock underseat woofers to the Earthquake SWS-8Xi. So, I'd like to get these as my starting point. You can find them on Amazon for $250 for a pair, which makes them a compelling purchase! That's 50% less expensive than any of the other brands that have been mentioned throughout the forums. If you own these, may I ask if these are basically "drop-in" units or would I need to buy something else (install accessories) off of the Earthquake website? I see that this product has a 160 watt/RMS rating @ 2 ohms. Now, from another thread (this one: https://f30.bimmerpost.com/forums/sh...d.php?t=975512), I see that the OEM amp has an output of just 40 watt/RMS @ 2 ohms. So, I'll need to then upgrade the OEM amp (based on the various articles/educational vlogs on matching amps with speakers). STEP #2: MAY I ASK: Which PNP amp would you recommend? I only know of two options: Revenant and Match Up 7BMW (I think these are the only two that would generate enough power - 160 watts/RMS @ 2 ohms). The BimmerTech amp has a rating of 70 watts/RMS @ 2ohm, so this doesn't seem like it would be able to generate enough juice to power the Earthquake SWS-8Xi). Are there other PNP amps out there or is Revenant and Match the only players (to be able to power the Earthquake with the higher RMS @ 2 ohms)? I'll just start with upgrading these components and go from there. Step #3: Looking into the future, MAY I PLEASE ASK: I've read differing opinions on upgrading the Central (dashboard) speaker while others say to delete it. If I decide to upgrade the speakers, what is your recommendation on the Central speaker. Upgrade it along with the others as it helps with the "soundstage" effect? Keep it stock as is and save my money because it doesn't really do anything? Unplug it as many forum contributors have done? Step #4: If I DECIDE TO ALSO REPLACE THE REAR DOOR SPEAKERS / FRONT DOOR SPEAKERS / FRONT DOOR TWEETERS AT SOME POINT Staying with the PNP approach, can you make a technical recommendation as to which of these speaker brands would be a justifiable purchase / provide good return on investment, if any (or just keep stock speakers given nominal improvement in your opinion)? I'm sure it has something to do with RMS vis-ŕ-vis "efficiency" vis-ŕ-vis some other factor, but I don't really understand the calculus here. - Match - BimmerTech - BavSound - Focal - another brand that's PNP for the F30? Many thanks for sharing your "sound" advice! Last edited by homeryen88; 05-04-2020 at 03:24 PM.. |
05-03-2020, 09:41 PM | #2 |
2034
Rep 2,815
Drives: F33 430 and F39 M35i
I couldn't find a Match on sale so I got the Revenant. Started with it and decided it was great and I didn't need to upgrade my speakers.
Plenty of threads on the Match. |
05-03-2020, 10:48 PM | #3 |
Rep 500
Revenant = Match UP 7BMW with lock configuration. I'm not sure if Bavsound had unlocked it in year 2020 but I wound't get it if it's still lock. In the future, if you are upgrading your speakers to other brand, you can't do the tuning or load other 3rd party tune profile.
05-04-2020, 12:13 AM | #5 |
2034
Rep 2,815
Yeah the revenant has two settings. Stock speakers or bavsound speakers. Mine’s stock. I’m giving the car to my daughter eventually so she doesn’t need the better sound. Flashing it back to stock as well and moving the bm3 to my next car too. Lol
05-04-2020, 07:29 AM | #6 | |
Rep 16,139
The SWS Earthquake is a worthwhile replacement if you want to have lower bass without going to a trunk mounted sub. It does require more power, because the inevitable trade off to get lower bass is reduced sensitivity. This thread shows how to do it. https://f30.bimmerpost.com/forums/sh....php?t=1701394 Last edited by Billfitz; 05-04-2020 at 07:34 AM.. |
05-04-2020, 08:14 AM | #7 | |
102
Rep 177
I've ordered a set of the Earthquake undserseat woofers (2ohm) with the technic pnp mounting rings. I should have everything by this weekend for installation. I will report back on y results! |
05-04-2020, 03:53 PM | #8 |
Rep 611
Audison. They offer many options for building your setup, from amp or amp+dsp, two-way speakers with crossovers, coaxial speakers, harnesses, cables, remotes... hassle-free, everything PnP, everything designed and tuned to work in the specific car together. Well-known for the sound quality, but also for the superior quality of manufacturing.
Listened to the car upgraded from HiFi to this configuration https://www.audison.eu/spc-kit/?kit=...=17&y=5&type=4 and the sound was really great. The AP8.9bit has enough power (you can bridge the channels for underseat woofers) and still keeps one channel left for adding the trunk sub easily. Still, they offer a more powerful AP F8.9bit with DSP... Listened to Audison and Focal speakers side-by-side and Audison would be definitely my choice... Anyway, I recommend listening to your options before buy, your personal taste is what matters . Last edited by J555; 05-04-2020 at 06:19 PM.. |
05-06-2020, 11:57 AM | #9 | |
102
Rep 177
I'm still waiting on the woofers to show up but the technic pnp speaker rings showed up yesterday. They appear to be 3d printed and are rather rough around the edges but looks like they'll work as intended. On another note, I do have a Bimmertech MMI Prime unit that adds Carplay and Android Auto functionality. The unit connects through the main HU quadlock connector and uses the auxiliary source for audio. Many have complained about reduced sound quality but in my experience sound is improved over the bluetooth connection. An advantage here is that the unit has a built-in equalizer to tweak sound settings to my liking. The equalizer only affects music being played through the interface, so the radio can only be controlled through the tone options in the iDrive. I was able to drop the frequencies between 140hz and 360hz and the drastically changed the characteristics of the underseat woofers. The low frequencies are much clearer and make for a better listening experience all around. I'm by no means an audiophile, but this did seam counter intuitive to me at first but hey, it sounds good. |
05-06-2020, 12:05 PM | #10 |
Rep 16,139
I'm curious how you dropped 140-360Hz in the underseats. They shouldn't be doing much in that range anyway. Mine are down -25 to -30dB in that pass band with a stock Hi-Fi setup.
05-06-2020, 12:27 PM | #11 | |
102
Rep 177
These are the EQ options I have (stock photo from the manf). When I lower the frequencies mentioned, it's for the whole sound source, not just in the woofers. Before I made these changes, it sounded like the subs were trying to do too much? Or maybe it was the door speakers? Hard to distinguish. The bass of a kick drum was super "poppy" - almost distracting. The higher bass frequencies sounded strained, while overpowering the lower frequencies. I have not messed with the amp settings other than loading in the limousine profile - but with these adjustments the listening experience is better for me at all volume levels. |
05-06-2020, 05:11 PM | #13 |
Homer Yen
130
Rep 76
As I continue to gather info, I'll post up new tidbits that you might find pertinent. This entry pertains to an email exchange that I had with both BimmerTech and Bavound about their made-for-BMW audio systems.
My questions to both of them: 1. While I see some power specs listed for your amplifier, I don’t see any for your 4 ohm mid-range speakers (for the front and back doors plus the center dash speaker) and your 2 ohm underseat woofers. Can you tell me what are their power ratings (RMS/watts and sensitivity)? 2. Can you talk a little bit about the selling point of your amp? ANSWER FROM BIMMERTECH: Let me break it down and put it in easier to understand wording because honestly, I’m not a sound engineer and its complicated to me as well. LOL. So our speakers/amp are designed to be an OEM+ option. Meaning they work with the factory iDrive system, they fit into the same housings and use the same wiring as the OEM options, you get around 30-40% more power with the set up and overall the quality is much higher than the OEM hardware. Resistance is going to be dependent on what the vehicle needs and can use with the system that it has. So don't think of it as an extreme high end system with earth shaking bass, think of it as a more refined OEM option, much higher quality, truly built to last and perform the way an audio system in a BMW should! ANSWER FROM BAVSOUND: Tweeters: ----------------- Size: 25mm Material: Silk Composite Impedance: 4 Ohm Frequency Response: 4,000Hz - 20,000Hz Power Handling (RMS): 22W Sensitivity: 96dB +- 2dB at 1m with 1W input Midranges: ----------------- Size: 100mm (4") Material: Woven Fiberglass Impedance: 4 Ohm Frequency Response: 500Hz - 4,000Hz Power Handling (RMS): 40W Sensitivity: 84dB +- 2dB at 1m with 1W input Midbass: ----------------- Size: 130mm (5.25") Material: Woven Fiberglass Impedance: 4 Ohm Frequency Response: 80Hz - 500Hz Power Handling (RMS): 40W Sensitivity: 73dB +- 2dB at 1m with 1W input Ghost Subwoofers: ----------------- Size: 200mm (8") Material: Woven Fiberglass Impedance: 2 Ohm Frequency Response: 40Hz - 200Hz Power Handling (RMS): 100W Sensitivity: 73dB +- 2dB at 1m with 1W input These specs are very, very similar to the factory components so that our replacements can work with the factory amplifier. The thing to understand is that speaker specs with car audio aren’t really very revealing in this context. Speakers in this case are a lot like shock absorbers or springs -- they do have some specs in terms of how they behave, but that won’t tell you much because they operate in a dynamic way based on the inputs they’re getting (either from the road or the amplifier). The biggest difference between our speakers and factory come from two main areas: 1. Much improved speaker materials, such as going from plastic tweeter domes and paper speaker cones to silk and woven fiberglass. This means much more smoothness, life, and detail during the reproduction of music. 2. Much improved mechanical design. By changing the configuration and design of the suspension and motor structure of our speakers, we’ve made them much more linear with far less distortion than the factory speakers. That means more accurate reproduction of music. Amp: There's no need to program the Revenant amp, we've had it professionally tuned by 5 audio engineers working on it for over a week to create a beautiful soundstage and impeccable tunes. As you can see from our specs, the 4 Ohm speaker impedance is compatible with the amp as well as the 2 Ohm impedance for the underseat woofers. The amp has two tunes, one for stock speaker systems (green light) and one for upgraded Bavsound speakers [or other premium speakers but amp is specifically tuned for Bavsound speakers] (amber light). It is just a button on the amp that you hold down for 2 seconds and it switches between the two tunes. It takes a second for the light to change from green to amber. ***Do Not hold button for longer than 8- 10 seconds! it will reset the amp and then it will not work*** MY TAKE: $1,000 is no small investment, even for a high-quality amp. For me, the BimmerTech response is quixotic if not evasive. That’s kind of a dealbreaker for me. And that’s too bad. I know forum members like their products, and I do subscribe to their video channel. But, transparency is key here. BimmerTech pricing is: Amplifier: $899 Underseat woofers only: add +$558 All other speakers and front tweeters: add +$593 Total System: $2,050 Bavsound pricing is: Amplifier: $997 Underseat woofers only: add +557 All other speakers and front tweeters: add +557 Total System: $2,111 From a pure customer service point of view, I’d rather invest the extra $100 (amp only, but note that the entire system is only $50 more for Bavsound vs BimmerTech) for more forthright customer service. Moreover, the power specs of these two amps are published on their websites: BimmerTech amp: 55 RMS Watts for the 4 ohm channels (all speakers and tweeters) 70 RMS Watts for the 2 ohm channels (underseat woofers) Bavsound amp: 65 RMS Watts for the 4 ohm channels (all speakers and tweeters) 160 RMS Watts for the 2 ohm channels (underseat woofers) Comparing these specs, the Bavsound amplifier gives you more power, thereby (but please have a sound engineer on this forum correct me if I'm making an incorrect statement) allowing you greater latitude in shopping for speakers and subwoofers if you want something other than Bavsound speakers. At 70 RMS (BimmerTech), there are probably less options from which to chose. |
nigr12.00 |
05-06-2020, 07:41 PM | #14 |
2034
Rep 2,815
listen to Billfitz. He does audio for a living.
05-06-2020, 09:30 PM | #15 |
Rep 16,139
The higher power of the Bavsound amp, especially with respect to the woofer channels, is a plus. That said, the best single improvement will be had from an amp that has a fully adjustable DSP EQ, with at least 15 bands of EQ adjustment. The lack of that capability is the main shortcoming of the stock amps. The information given about the speakers from both Bimmertech and Bavsound is advertising copy only. There is no useful engineering data. These pages contain actual engineering data:
https://www.parts-express.com/8-glas...-ohms--292-494 https://www.parts-express.com/4-glas...odels--292-490 It's that data that engineers use to compare different speakers, not advertising platitudes. |
homeryen88129.50 billqs0.00 |
05-06-2020, 10:38 PM | #16 | |
Rep 500
@homeryen88 - Both Bavsound and Bimmertech are rebranded Audiotec Fischer DSP amp. Just different model. Bavsound using UP 7BMW and Bimmertech is PP 86DSP. Last edited by pierreye; 05-06-2020 at 10:47 PM.. |
billqs0.00 |
05-07-2020, 10:40 AM | #17 | |
102
Rep 177
05-07-2020, 11:13 AM | #18 |
Rep 16,139
If you don't use the OEM H-K amp the EQ in iDrive doesn't do anything, as the DSP is in the amp, not the HU.
05-07-2020, 12:47 PM | #19 |
118
Rep 178
homeryen88 For an F30 with HIFI, you will not find a better value than our original analog Soundstage™ - https://integralaudio.com/soundstage...eries-f3x.html. It will far outperform the other options you're looking at, and is massively discounted to $999 as we clear them out (being replaced by newer product lines).
I'm currently working remotely near Bethesda, MD, not far from you. Come take a listen.
Kevin Bennett
Integral Audio - We make the finest automotive audio systems on the planet. Have you seen our SoundstageDSP™ for BMW 2 series and SoundstageDSP™ Ultra for BMW 3 & 4 series? www.integralaudio.com |
J555568.50 homeryen88129.50 |
05-07-2020, 02:49 PM | #20 |
Homer Yen
130
Rep 76
@Billfitz - may I ask from a technical standpoint and since you've seen the specs … which would be the better 2 ohm underseat woofer?
Would it be the GRS B200-2 (rated @ 100 RMS/watts) that you referenced above (from www.parts-express.com)? Or would it be the Earthquake SWS-8Xi (rated @ 150 RMS/watts)? Let's go with the assumption that one would upgrade the amplifier to match power properly. In addition to these two having some engineering data for all to see, I ask about these two specifically because they are also similarly priced and several HUNDRED dollars less than the other options that were mentioned thus far. Thank you, @ Kevin/Integral Audio. I promise to review your products. Your brand is new to me, and I love learning new things. |
05-07-2020, 02:58 PM | #21 |
Rep 16,139
The Earthquake, by a good margin. The wattage rating, BTW, is one of the least important specs. The lower Fs of the Earthquake is one of the factors that allows it to go lower, while the higher X-max of the Earthquake allows it to do so with less distortion.
05-07-2020, 05:44 PM | #22 |
102
Rep 177
