      07-13-2009, 12:49 PM   #1
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
Will 245/40 18 rub in the rear with stock 264s and BMW Perf Susp?
So I am looking at running this setup on the stock 264s:
Car is lowered (modestly) with BMW performance suspension
Front- Michelin PS2 235/40 18
Rear Michelin PS2 245/40 18
I know the front shouldn't be a problem, but I am worried about the rears rubbing- I have searched and it seems like some are running that setup in the rear and have rubbing and some don't, can someone that knows for sure chime in? thanks in advance
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA
      07-13-2009, 01:17 PM   #2
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
245's in the rear on the stock rims shouldn't rub... at all. The stock tire on the rear is 245. I was lowered on the stock setup as low as my KW V3's would go and it didn't rub, it was just too far away from the fender to possibly rub.
      07-13-2009, 01:22 PM   #3
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
but are you on the 245/35 or 245/40- I am afraid the taller tire may rub
      07-13-2009, 01:32 PM   #4
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Oh sorry I missed that. I would go 255/35 if I were you. I still think it would be fine. I'm on 255/35 in the rears with a rim that has less offset. I remember the stock rears had quite a bit of room before the fender even when lowered, so I think it can manage an extra few mm of tire. I think I've seen a few people with 255's on the stock rims lowered and there was still room.
I think ideally you want the total diameter of the front and rear wheels to be as similar as possible.
      07-13-2009, 01:53 PM   #5
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
yea I know,
but a member on here as a pair of new PS2s in 245/40 for a good price, if they wont fit i'll be keeping the runcraps I think
      07-13-2009, 02:10 PM   #6
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
Michy PS2s are pretty fat tires...that 235 is going to be closer to a 245. A 225 might be a better idea.
      07-14-2009, 11:47 AM   #7
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
bump for any more input
      07-14-2009, 12:39 PM   #8
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
I know of a 135i with 235/255 (Dunlop Star Specs which are one of the fattest street tires around) on stock wheels, lowered, with no rubbing at all.
      07-14-2009, 12:49 PM   #9
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
yea, I'm not so much worried about width as height- the 245/40 is 25.7 inches tall vs the stock at 24.7 and I'm worried that whole inch will likely rub, no less throw off the speedo even more
      07-15-2009, 10:35 AM   #10
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
bump, I'd like to pick up some PS2s but need more input, thanks
      07-15-2009, 08:29 PM   #11
gyrfalcon
Ninja
14
Drives: 135i
I'm pretty sure you can run a 245/40R18 without rubbing on a stock suspension but only just. The fact that you are slightly lowered on the performace suspension leads me to think you will end up with some rubbing. I doubt it'll be much, maybe just during large dips and heavy load situations, but some nonetheless. Why don't you go with some 255/35 tires to be safe? There are ton of good choices in that size. The Star Specs will arguably provide more grip for a cheaper price than PS2s.
SGM/Coral
      07-15-2009, 08:55 PM   #12
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Technically if you increase the diameter of the entire wheel the speedo will become more accurate since the speedo over estimates speed on the stock setup.
On my stock setup, when my speedo read 60, my GPS said 57ish. When I changed to 225/40 front and 255/35 rear (vs 215/40 and 245/35) my GPS read 59ish.
      07-15-2009, 09:03 PM   #13
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
because there's a member on here selling the PS2s for cheap, I am not getting any tires if this wont work, I'll just wait
      09-18-2023, 09:59 AM   #14
dzid_
Drives: 135i 2011 DCT
Did it work?
Edit
Nevermind, it worked for this guy:
https://www.1addicts.com/forums/showthread.php?t=817952
