      12-30-2012, 01:12 AM   #111
Got_///M
Got_///M's Avatar
Drives: 2011 BMW 135i
Very nice write up! Thanks!!
      01-25-2013, 11:08 PM   #112
MTribe
13
Drives: 10 135, 06 Elise, 71 TR6
Used this thread to great effect! Thanks all for the contributions!
      01-29-2013, 04:44 PM   #113
chrisko
chrisko's Avatar
Drives: 2016 M3
Finally got around to doing this.
As others have mentioned, I didn't remove the whole glove box, just used those latch releases. And for this who are curious, you need the ATM fuse tap.
I also tapped into fuse 5 as my 8 was occupied.
Thanks for the write-up!
2021 M2 Comp | STEK Stealth Wrapped | PSM V2 Trunk Spoiler
2022 X3 M Comp | (SOLD)
2016 M3 | AWE Switchpath Diamond Black 102mm (SOLD)
      09-01-2013, 09:30 AM   #114
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
Great DIY i used it to hard wire my V1 however after reading through the whole thread i'm afraid i'm still confused on what amp fuses to use in the add-a-fuse device. People seem to be using all different combos, 2 x 20amp fuses, 2 x 10amp fuses, 1x 10amp & 1x 2amp or 1 fuse only
Also i planned on using slot 5 (as it's vacant) but according to the fuse diagram card it is allocated to the steering wheel picture along with fuses 49 & 75. Any idea what that picture means? Am i still ok to use that slot?
At the moment i am using slot 8 with a 20amp fuse + a 2amp in the secondary slot of the add a fuse device (in addition to the 2amp fuse in the V1 Hard wire kit) Just a bit concerned that the V1 is now actually protected by 24amps in total and could get fried?
      09-02-2013, 01:12 PM   #115
jordantii
115
Drives: M2 Sea
In the hardware kit there is also a fuse. Its been a while since I installed mine.
      05-10-2015, 06:36 PM   #116
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
Thanks for the write up, made the job very fast! I only had a medium sized add-a-circuit lying around so I used fuse #83 (20 amp) with a 10 amp fuse. Only downside to using #83 is that the power is always on rather than on ignition, so I'll have to turn off my V1 until I order a mini add-a-circuit to replace it.
      07-18-2015, 04:54 PM   #117
PA135i
PA135i's Avatar
Drives: 08 135i 08 CR-V
F**k ! Getting to that grounding screw was a BITCH!
But, I got it done. thanks for the write up.
Any advice on tucking the wire behind the trim? I used my fingers and a screw driver, but needs some more tucking to be perfect.
I used open slot #5 with (2) 20Amp fuses in the mini adapter slots. The advance auto guy said that will be be fine. looks good, works fine.
My install, perfect.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
      07-26-2015, 12:38 PM   #118
2002ish
36
Drives: E92 M3
Thank you for this thread! Hardwiring my trusty V1 was the first mod I did to my new car and this gave me the courage to do it.
I want to address a few issues I found that might help others doing this... I think the two hardest parts of this process include: 1) removing the dome light assembly / dropping the headliner and 2) finding a fuse to tap. Do all this at your own risk.
Before anyone proceeds with the install, start with a good phone cord... preferably the one that comes with the v1. I tried 3 different phone cords that didn't work right before I broke down and ordered another one from v1 (luckily I bench tested them before trying to install them). Note that Valentine Research has free shipping on their parts so my advice is just order one if you don't already have it (or used it on a previous project).
1) Remove the dome light and drop the headliner
Both are very easy steps once you know how to do them but (atleast to me) were daunting tasks. Lowering the headliner has already been covered countless times throughout the forum... it entails just removing two screws. At that point the headliner drops about an inch and a half without any further struggle with clips or anything else.
Once the headliner is dropped you have access to the two front tabs on the dome light. This thread contains a few photos that will guide you to exactly where the tabs are: http://www.e90post.com/forums/showthread.php?t=273231. Just depress those tabs and the assembly can be removed.
To ensure that the phone cord doesn't get ripped out or pulled out by accident I zip tied it to a large part of the wiring harness for the dome light assembly.
2) Finding a fuse.
I used a small blade fuse tap as everyone else has and I found an empty fuse slot. I think I used fuse 10... it was something related to power seats (which I don't have) and it's switched power. Unless you have a fully optioned car you should definitely be able to find a few empty fuse slots and not even have to deal with actually having a "pass through" fuse in your add a fuse.
As to what amp fuse to use, I also ordered two extra 2 amp small blade fuses from Valentine... the same ones that are used in the cigarette lighter power adapter for the v1. I figured if it works there it should work in the car.
Hope that helps someone!
      04-20-2016, 04:14 PM   #119
doublevanosrc
Loves his G20
doublevanosrc's Avatar
265
Drives: 2020 330ix M sport
2013 BMW  [0.00]
Glove box doesn't seem to want to drop. I once did it without taking it out. Thoughts??
2020 330ix-Msport
Past-
2013 135i
2011 135i
      06-11-2017, 03:36 PM   #120
shawnj
45
Drives: 135i
Are most doing this instead of mirror tap? I just got a V1, includes standard hardwire kit
      06-16-2017, 04:36 PM   #121
TridenTBoy
Drives: 2013 BMW 135is
2013 BMW 135is  [0.00]
I didn't know this was an option. I'm getting a Uniden R3 in the mail here soon enough. I'll probably do that with a mirror mount. Woot!
      06-17-2017, 07:18 PM   #122
tock172
Beachtown Bill Collector
tock172's Avatar
Drives: 2012 135i
2012 BMW 135i  [0.00]
1999 Lexus LS400  [0.00]
1985 BMW 325e  [0.00]
Mirror tap isn't an option on the 135i. I ran my V1 off the mirror wiring on every previous BMW of mine, but the E82 required me to power it off a fuse tap. Using a wire up in the overhead center console doesn't work because the current gets interrupted during operation of the sunroof.
2012 BMW 135i Space Grey Metallic M-Sport DCT Dinan S2
      06-17-2017, 08:14 PM   #123
TridenTBoy
Crushing my dreams! ...but, wait, that doesn't matter for me? I have an E88.
I'm still not sure of the location of where I'm going to put the radar detector. I don't actually like the idea of it being right under the mirror (blocking my vision).
      06-18-2017, 02:53 AM   #124
shawnj
45
Drives: 135i
I have one mounted with BlendMount, it's really not that in the way..
