09-22-2022, 07:49 AM | #1 |
Rep 7
Downpipe install
I was looking around online for a dpf delete and ran across a downpipe for n47 bought it and installed it. Didn't do any tunning and as expected the check engine light came on but no limp home mode. It's a bit quicker now. I'm still trying to figure out what to do about the DEF fluid. Is there a way to go in and disable it?
09-25-2022, 01:33 PM | #2 | |
30
Rep 34
10-03-2022, 04:26 PM | #3 | |
20
Rep 88
You 10000% want to get your ECU tuned. The transmission tune is good but optional, but the ECU tune is absolutely necessary.
If it's LCI you'll need to send the unit off by mail to get unlocked, pre-LCI can be done with a loaner tuner. Quote:
It will, however smell like an old school bus. If you get a cat, it will smell when cold, and if you skip the cat it will smell all the time. Not enough to bug me, but something to keep in mind. |
delete, downpipe, dpf |
