BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Full e85
Studio RSR
      08-13-2019, 12:14 PM   #1
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
Full e85
Is it possible to run full e85 on a f30 335i
Pwg I do a mixture now with 4 gallons and it helps out so much with my timing when ever I don't use e85 my timing is all over the place according to my logs and bm3 support
my question is is it possible to run full e85 and if it is what's the steps or what exactly do I need or is way too much of a hassle
Would I need to replace injectors and lpfp and just do too much to the car to accept e85
Also I'm not going to lie is so much cheaper lol
I live here in la county so man gas prices are always higher here
bmw m2
      08-13-2019, 12:19 PM   #2
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
You do realize, your gas mileage will take a SERIOUS hit right? So, you'll save money filling up each time but will be filling up more often so it kind of cancels each other out.
You'll need a tune at a minimum (MHD or BM3).MHD offers a full E85 OTS tune already with no upgrades required. I don't believe BM3 has an OTS E85 map available yet.
-Nick
      08-13-2019, 12:21 PM   #3
cesarortiz23
Drives: bmw m2 lci
-Nick
wait your telling I won't need a lpfp or anything just a tune ???
Why do people say I need to upgrade lpfp and spark plugs etc.
Right now at the moment I am getting 16.8 mpg
On 4 gallons of e85 and the rest 91
bmw m2
Phyrexia504.50
      08-13-2019, 12:31 PM   #4
e46m3to335i
Drives: 2015 F80 M3
-Nick
All I'm saying is that MHD offers a full E85 OTS tune.
Phyrexia504.50
      08-13-2019, 02:52 PM   #5
louielouie
Drives: '18 F80
You will definitely blow your fuel pumps running full e85 if you don't upgrade them. I'd say you're already testing your luck running 4 gallons. I've spoken to MHD about this too, and they recommend just ~1 gallon on stock FPs. Not sure why others are getting a different answer.
      08-13-2019, 02:57 PM   #6
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
This thread is confusing. I just put 300 miles on a tank of E30 (4.25 gallons E85 + Shell 93) running the v1.08 Stage 2+ E20 tune. Was that a no-no? The car ran great and my logs look good. I flashed back to the 93 octane tune this afternoon.
I thought the E85 tune was not for stock fuel systems. MHD app and website are unclear.
      08-13-2019, 03:35 PM   #7
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Not sure whats confusing about the MHD app and website.
You can run the Full 85 tune with stock fueling OR the E20-E30 maps (depending if you are EWG or PWG) with stock fueling.
If your map is set for E20 and you run E40, then your Fueling system will eventually not keep up. There is a reason why the OTS maps are set to a certain E20-E30 limit and you shouldn't go past that!
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
harkes1091.50
      08-13-2019, 03:36 PM   #8
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
-Nick
bm3 offers 100octane and e30 maps
My Build Thread can be found HERE
      08-13-2019, 03:37 PM   #9
ronanz
ronanz's Avatar
This ^^^
The HPFP is the weak link in your fuel system
      08-13-2019, 04:10 PM   #10
rcsup1
155
Drives: x3 35i
I'm running 8 gal E85 with 93, so about E50. At first it was by accident (I wasn't paying attention). I ran some logs and everything looked great so I've kept it in that range. The main issue as has been stated here is that HPFP can't flow enough for full E85 and crash's sending the car into limp mode.
My thread and logs here:
https://f30.bimmerpost.com/forums/sh....php?t=1641595
My car is a PWG so the turbo does't flow as much as the later EWG which would put a bigger strain on the pump.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
      08-13-2019, 04:58 PM   #11
Phyrexia
Resident Pedant
The License Store says "E85 mix map" and the description says "E30 Map". So I filled up my car with an E30 mix, bought the maps, go to flash, and saw that I only have E20 maps and E85 maps available. Meanwhile the MHD Website advertises only an E25 map pack for F-series N55.
Haven't seen any indication that the E85 map was for stock fuel systems until today, in this thread. No documentation on MHD's part at all. :shrug:
      08-13-2019, 06:53 PM   #12
MineralF30
61
Drives: 09 E92 335i
You can run full e85 but i'd definitely upgrade the lpfp to a walbro, it will flow much better as it is meant to handle full e85. I haven't tried out the full e85 maps on MHD so cant speak on that but i run e85 on my custom tune with port injection and i love it.
Your gas mileage will be horrible though, i get around 14-16 mpg and have to fill up about every 2 days but then again i drive about 70-80 miles per day so your results might be different.
      08-13-2019, 06:59 PM   #13
e46m3to335i
Drives: 2015 F80 M3
-Nick
I'm well aware of what BM3 offers OTS wise. Was just saying to the OP that I'm pretty sure BM3 doesn't offer a "full E85" flash like MHD does.
      08-14-2019, 07:55 AM   #14
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Are there really people out there running the MHD full E85 tune with no supporting fueling upgrades, i.e. upgraded LPFP with PI or upgraded HPFP?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      08-14-2019, 08:12 AM   #15
e46m3to335i
Drives: 2015 F80 M3
Not sure but I really doubt it. I wouldn't LOL.
      08-14-2019, 08:46 AM   #16
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
There is no way with stock LPFP and stock HPFP. Maybe the LPFP can handle full e85 but the HPFP surely cannot.
I've been running e50 for the last year+ with both stock LPFP/stock HPFP with no issues and with Stage 2 LPFP (walbro 450)/stock HPFP with no issues, all logs have looked good.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      08-14-2019, 08:52 AM   #17
adrien78
France
52
Drives: BMW F30 335i
I am, but the full E85 in only available for N55 EWG if I'm right.
I was a beta tester for this map. Stg1 should be ok without any problem but for stg2 it's not the same.
They released a map too hard for the HPFP, I have some pressure drops after 5000rpm, corrected by lowering the boost.
I'm running like 12,5-13psi at this time, curves are ok, no drops.
Running full e85 since 3 months, my HPFP is still alive lol.
Phyrexia504.50
      08-14-2019, 09:09 AM   #18
zole2112
zole2112's Avatar
147
I stand corrected you can tune to account for e85 by limiting your boost levels so that your fuel demand volume doesn't exceed your HPFP capability.
      08-14-2019, 09:32 AM   #19
adrien78
France
52
Pureboost did it. I just give them some feedback and logs and they sent me other maps.
      08-14-2019, 11:15 AM   #20
rcsup1
155
Drives: x3 35i
What gains are you guys running full E85 with the lower boost pressures seeing?
Does the increased timing really offset the reduced boost pressure in terms of overall power?
      08-14-2019, 11:58 AM   #21
Munchi435i
Munchi435i's Avatar
From all the research i've read, it seems the PWG turbo cars are able to run much higher levels of E85(E30-E50). So it's no surprise that your able to run E50 with no issues but the question is, how long will that last before having to upgrade any part of the fueling system??
If you are EWG, then the only maps available to you are the E20 and full E85.
Im not sure what is available for the PWG turbo cars since i run a EWG turbo.
Also, I have not purchased the E85 mix maps so im not sure about the description your talking about but from everything i've read on the forums, you can run full E85 on stock fueling, at the sacrifice of lower boost.
      08-14-2019, 02:52 PM   #22
JaredG_F30
JaredG_F30's Avatar
1106
So is the Full E85 map faster than the Stage2+ E30 or 93 octane maps? I'd love to see a log if you have one.
Phyrexia504.50
