01-08-2012, 07:03 PM | #46 |
n1smo
97
Rep 1,483
Drives: E92 M3
Any updates from the guys that swapped to the mini battery?
12-02-2012, 04:36 AM | #48 |
313
Rep 359
I'm running a 55Ah Battery in my e92 M3. That was the smallest capacity which could be programmed into the battery management system by BMW.
Works without any problems. I just get the battery weak message from time to time. But that's because I don't use the car as a daily driver - mostly just for tracking. So the car sometimes sits 2-4 weeks around in the garage. If you'll use it as a daily driver you will not get the message as the battery will be charged regularly. But even in my case. Never had the situation where I couldn't start the car anymore. The battery monitor which throws the message is very sensitive. So even if you get the message you'll be able to start the car 5-6 times before it's really to weak. In my opinion this is a nobrainer if you're looking to save some lbs. But don't just change the battery. Get a cheap 55Ah from an Autoparts store and then let BMW code the new capacity into the energy management system. 55Ah fit's without any custom bracket directly into the existing holes.
02-28-2013, 10:50 AM | #50 | |
Rep 1,711
02-28-2013, 12:22 PM | #51 |
8259
Rep 18,848
Drives: BMW
Coding the car to the new battery.
05-14-2013, 03:04 PM | #53 |
8259
Rep 18,848
Drives: BMW
Yes, registration is essential after battery replacement.
12-02-2014, 03:36 PM | #54 |
Rep 573
Drives: 2008 E90 M3
I know i'm late to the party here. Did anyone have results from using the Z4M battery?
05-22-2015, 04:20 PM | #57 | |
Rep 876
Try this part number for the 55ah battery: 61217591080. Not as light as the above, but at 45 lbs it is still much lighter than the M3 OE at 61 lbs: 61217553952 (70ah and 760cca). |
05-15-2020, 08:26 PM | #58 | |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Anyone aware of an update number? Also, wouldn’t ANY H5/6/7/8 battery fit here with brackets considering they are (mostly) all similar/same shape? |
05-16-2020, 06:03 AM | #59 |
Rep 10,642
I think the older mini battery is an H5. I am not sure whether the bracket still fits but presume so since people have used this battery.
