Oil Cooler: Missing on my car - Called BMWNA, told not available on cars before 10/11
07-07-2014, 12:56 PM | #67 | |
Rep 83
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4, Sport Oil Cooler Valve, FlexFuel Wires, GoFastBits DV+ - Approx E30 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue |
07-07-2014, 01:36 PM | #68 | |
687
Rep 2,770
You do have to have the OEM oil cooler installed to get either stage though.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
07-07-2014, 07:19 PM | #69 |
Rep 535
Yeah that's wrong. I have a 2008 335xi manual with sport package and I have the oil cooler. I think that all Canadian 335i's with sport package came with one. The 18" wheels are also standard with the sport package in Canada
07-07-2014, 07:46 PM | #70 | |
Rep 1,192
Drives: 2011 335i MT
Did you know that Cobb is non-invasive - installs/uninstalls through the OBD II port?
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
07-08-2014, 12:37 PM | #71 | |
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
As a side note, I did speak with BMW NA again about 2 weeks ago. I informed them of the vehicles similar to mine that have the oil cooler. After I did that the rep. seemed to become frustrated and became short with me. Essentially he said that my car should have never come with an oil cooler and 'case closed' - there is nothing which I can do.
Even though he couldn't tell me why the other vehicles had it and mine didn't. Oh well - lesson learned. Quote:
Even though Cobb is plug/play I don't feel comfortable having that on my car and then if something happens taking it off and getting the issue fixed. I feel as if it is stealing and lying - just how I am. But thanks for the suggestions.
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks '07 BMW 335i Coupe & BMW Z4 3.0i - Gone |
07-08-2014, 03:22 PM | #72 | |
Rep 688
Finally someone who gets it. I have been preaching this for years. |
07-08-2014, 04:21 PM | #73 | |
453
Rep 2,973
I didn't feel bar running a Cobb when my water pump failed. Un-related. I didn't feel bad when the injectors when south. Un-related. I didn't feel bad when my HPFP failed. Un-related. Just because you run a tune and need warranty work doesn't mean the two are related. I personally tried to get the PPK. I have all the right option. The dealer could not install it. They had some issues. So, then...... I bought a Cobb. No issues.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
07-09-2014, 08:38 PM | #74 | |
Rep 10
Drives: 2011 BMW 335i xDrive
I doubt you would find these parts on a salvage yard, unless someone had recently totaled the 335is car and the front end was not damaged. By the way, I think the price of PPK is fair considering that you get a very expensive new fan with wiring harness and relay switch, a set of new spark plugs, an additional radiator + hoses and a bunch of small stuff that, if purchased separately, can easily add up to ~$200. FYI - I was told that the PPK dealer invoice price (without air ducts) is $1165, the lowest price I found online was from getBMWparts.com for $1180, but the air ducts kit will add another $230. The bottom line - paying this much only to get the additional 20 hp from your engine isn't worth it IMHO. I did it primarily to increase the cooling capacity and reduce thermal stress on my engine while driving on a track. But if overheating wasn't an issue, I wouldn't even bother with PPK. |
07-09-2014, 09:02 PM | #75 | ||
Rep 10
+1 from me as well. I want to be able to go back to my service adviser not just to make a service appointment but also to get a valuable advice (e.g. on warranty matters) and not feel like a cheating bastard. She knows my car better than I do, why would I put this valuable resource in jeopardy just to get a few more HP out of my engine. |
bmw usa, bmwna, missing oil cooler, oil cooler, xdrive |
