BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Buying New Rims (How Much To Install)?
ARMA SPEED
      08-22-2013, 08:00 AM   #1
Fruitycups
14
Drives: 328i xDrive
Hello fellers/fellas.
Have a quick question. So a friend said he'll sell his 403's to me which I will def purchase. My question is, how much does it usually cost to get it installed at the dealership? I never ever installed a spare before so I have no idea how to do it, which is the reason why I want to go to the dealership. With sensors being included, not sure if I have to calibrate and do some other mumbo jumbo stuff lol. Im also a bit weary placing the lift under my car, don't want to risk the chance of putting it in the wrong place and dinging the bottom.
Any advice on price?
      08-22-2013, 08:30 AM   #2
pazzo
Drives: 2017 X1 Glacier Silver
I was quoted 40 per tire at the local BMW dealership. That includes removal of existing tire from existing rim, removal of TPMS, and re-installation of tires, TPMS, balancing etc.
Pazzo
2017 F48 xDrive Glacier Silver
      08-22-2013, 08:46 AM   #3
Fruitycups
14
Drives: 328i xDrive
Holy cow. Do you think it'll be less for me?
The rims Im buying already have the sensors installed and comes with tires. And the tires/rims Im replacing I just wanted them removed as a whole and not dissembled.
      08-22-2013, 09:10 AM   #4
ERdiesel
Drives: 2014 335i xDrive
Call around to various dealerships and ask for quotes.
      08-22-2013, 09:58 AM   #5
rconti
Drives: x5 3.5d, Clownshoe, Tesla 3
If you're just swapping full wheel+tire sets, I'm sure someone here can tell you how to connect your car to the 'new' TPMS (though likely you'll have to do it on the cars individually, out of range from each other, or it'll still be picking up a signal from your "old" wheels).
In other words, do it yourself.
      08-22-2013, 10:01 AM   #6
torqstr
Drives: F30 335xi
Shop around, my local dealer wanted almost $400 for the exact same thing you are looking for. I ended up taking it to a tuner shop and they did everything , including filling the tires with nitrogen and setting the tpms for $55 total.
335xi / GLK350
C63 / S4(B7) / S4(B5) / 911 / A4 / SL500
      08-22-2013, 10:39 AM   #7
vitriol
vitriol's Avatar
15
Drives: 2016 340i M Sport
If you're mounting OEM wheels that are already balanced and tires installed, I would do it myself, as someone suggested, since you don't have to do anything other than lift the car, remove old wheels and install new ones.
If you don't have the equipment/knowledge to do this, I would go to tirerack.com and search for reliable shops they work with in your area. I believe the tirerack site lists the install price per wheel at various shops.
Just take it to a tire shop and have them do it. Don't bother with the dealer. It shouldn't be more than $80 to remove old wheels and replace with new ones. $40 would be more reasonable. It will take all of 15 minutes.
      08-22-2013, 10:48 AM   #8
Pauleebe
Pauleebe's Avatar
Drives: Inbetween BMW's.
That's a steal.
I think $100-200 is fair. They have to get it on a lift and do all four tires and the TPMS, and you're easily paying the expensive labor rate.
      08-22-2013, 10:57 AM   #9
Bimmerfestool
Bimmerfestool's Avatar
Drives: .
If the tires and sensors are installed on the rims, isn't it a matter of just lifting each corner of the car and replacing the wheels, pretty much like a flat? If the tires were roadforce balanced on the rims there should be nothing else to do. Since I'll be doing this twice a year to switch summer/winter wheels back and forth it better be easy!
      08-22-2013, 11:26 AM   #10
s1k0ne
Drives: ..
wait what? you're just swapping out stock rims for stock rims? The new rims you're getting already has the TPMS installed and all that?
Find a friend who has a jack/ torque wrench/ fitting socket for the lug nuts. Should be a 30 minute job
If you want to take it to a shop, i get charged $10/rim for installing tires/ mount/ balance so $40 in total. a shop to just swap out old rims for new rims, they shouldn't charge you more than $20
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      08-22-2013, 11:31 AM   #11
BMWFanatic2008
BMWFanatic2008's Avatar
234
Drives: 2023 M3 6MT
Just swap them yourself. Loading them in your car, driving to the shop, and waiting for them to do it would take more time Plus you have to tighten them to BMW spec (88.5 if I am not mistaken), which a random tire shop most likely wouldn't do.
Current: 2022 X3M Comp
Previous: 2020 X4M Comp | 1982 E24 633CSi | 2016 F82 M4 | 2015 F80 M3 | 2014 F30 335xi | 2013 F30 335xi | 2010 E92 335xi
      08-22-2013, 11:44 AM   #12
Bimmerfestool
Drives: .
Question: does the car come with a jack or they cheaped out on that too?
      08-22-2013, 11:50 AM   #13
Fruitycups
14
Drives: 328i xDrive
So if the sensors come already installed, how do I get the sensors to read with my vehicle once installed on the car?
      08-22-2013, 12:17 PM   #14
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Why would any car have a jack and no spare tire?
      08-22-2013, 12:43 PM   #15
Fruitycups
14
Drives: 328i xDrive
Will any lift jack work? I have a 2008 honda pilot that came with a jack. I know the BMW has those little rubber "stops/squares" for the jack to be placed on. Not sure if the pilot jack will fit and I dont want to force it and ruin those little rubber stoppers.
      08-22-2013, 01:02 PM   #16
vitriol
vitriol's Avatar
15
I wouldn't try this, for a couple of reasons. First, you'r going to have a hell of a time making the Honda scissor jack work. Second, it'll take a couple of hours of onerous work without the proper equipment (i.e., decent floor jack, jack stands, tire iron, torque wrench).
You have three options:
1) Go out and buy the necessary equipment (floor jack and jack stands primarily);
2) Borrow them from a friend; or
3) Take it to a tire shop (as has been noted already, it shouldn't cost more than $40 assuming TPMS sensors are already installed, wheels are balanced and tires are mounted).
If I were you I'd go with option #3. If you were inclined to do #1 or #2, you probably would have done it already!
      08-22-2013, 01:34 PM   #17
Bimmerfestool
Drives: .
So I can take off the run-flats.
      08-22-2013, 02:23 PM   #18
tdizzle
Drives: 2017 F80 ZCP
Your car will give an error when you start it/power up and give you the option to reset the tpms. (You could just go to the tpms options in idrive as usual also and reset from there).
It's really as simple of pushing a couple buttons and drive 1/4 of a mile or something.
WHen I put my new wheels and tires on the message popped up and I hit reset and it was done. Literally a two button press that took a couple seconds.
For the record, I used my jack (cost about $100 for a nice one) and the BMW adapter sold by BMS and the other adapter that you screw into your hub to facilitate easier mounting from BMS ($15 or so). It's about a 30min job if you don't know what you're doing with non shop equipment.
Edit Some things you may want to make your life easier:
http://burgertuning.com/wheel_hanger_pin_BMW.html
http://www.burgertuning.com/BMW_prot...el_socket.html
http://burgertuning.com/BMW_jack_pad_adapter.html
      08-22-2013, 07:09 PM   #19
Bimmerfestool
Drives: .
Great links thanks ^^^^^^^
      08-22-2013, 09:38 PM   #20
Kabrich
The jack does not come with the car. You get the jack as part of the optional 4 Spare Tires kit, which you clearly have if you need to take off the run-flats for the Winter.
      08-22-2013, 10:38 PM   #21
FeelingBlue
ESTORIL
FeelingBlue's Avatar
Drives: '21 BMW M2 Competition
I just mounted my wheels. I couldn't break the lugs loose (I didn't have a breaker bar or impact driver), and was afraid of damaging the wheel by trying any extremes to loosen them. So I made some calls and found a local tire shop that said they would mount them no problem (I found shops that quoted me $15 but I had to leave the car overnight, and others that quoted me $80 - not sure of the thought process behind that price). It took 20min~30min and $25, but my wheels are perfect now. No damage done, and all the lugs are tight as can be. Although I may end up buying a jack & impact driver in the future just for easier access to clean both the wheels and brakes...
      08-22-2013, 11:25 PM   #22
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Originally Posted by dwalls90 View Post
That's a steal.
you think this work will take more than an hour???
