2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack ► Official APEX Wheels Showroom Gallery Thread
      10-22-2020, 05:43 PM   #89
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
Peter is correct. ET 45 9.5 rear is aggressive even with 255. That is my street setup. 43 is a poke with 265s. My 255s on 9.5 at 45 is at the very edge.
      10-22-2020, 05:49 PM   #90
danyosun
Drives: 2012 E92 M3 6MT
Originally Posted by PeterWT View Post
Originally Posted by danyosun View Post
Has anyone ran 9.5 ET43 in rears? Everyone seems to run 9.5 ET58 for APEX wheels.
All the VMR guys seems to run 9.5 ET45 as a perfect fitment.
ET45, perfect? No.
I have ET58 - 5MM spacer (ET53), with 265/35 Michelin A/S3+ and I think that pokes a little.
You'd have to have a high poke tolerance for 9.5 ET45.
Oh alright, thanks for confirming that for me. I might just go ET58 to be on the safe side.
Are you rubbing at all? Would probably be possible with about 2° camber you think?
      10-22-2020, 07:27 PM   #91
aftercorbu
aftercorbu's Avatar
No rubbing. My rear offset and 255 tires are known to be a safe fitment. To run 265s you will need to be in the 53 offset range.
      10-23-2020, 07:44 AM   #92
JY01
JY01
JY01's Avatar
693
Drives: 2023 BMW M4 Competition xDrive
Got some Apex EC-7s yesterday, digging this new setup
18x8.5 ET45 with 5mm spacer, 235/40/18
18x9.5 ET58 with 5mm spacer, 265/35/18
Tires are Bridgestone S04 Pole Positions, they seem to run wide but the 5mm spacer gives me just enough room to clear the shocks
Appreciate 5
      10-23-2020, 11:44 AM   #93
aftercorbu
aftercorbu's Avatar
Looks great!
      10-23-2020, 04:48 PM   #94
Expert@ApexWheels
Expert@ApexWheels's Avatar
3532
Drives: M3
https://www.2addicts.com/forums/show...3&postcount=31
This guy is running 19x9.5 ET43 in the rear. The angles of these photos make it tough to see, but it will definitely poke as others have pointed out and may rub under suspension compression especially with wider tires.
This is correct, we generally recommend a 5mm spacer in the rear with our 18x9.5 ET58 to get to the 53mm effective offset that the 265s require.
Thanks for the purchase and for posting these shots!
-Tom
      10-23-2020, 07:42 PM   #95
danyosun
I wasn't planning on running 265, original plan was to run 255. Didn't even think of 245, a slight more stretch for clearance and possible negative camber might be an option? If you're running ET43 on 255, it's doable then right, just a poke of around 7mm from my calculations.
Originally Posted by Expert@ApexRaceParts View Post
https://www.2addicts.com/forums/show...8;postcount=31
On one of his post he said no camber, no spacers, no rubbing and just a slight poke. So seems doable. He's on M Performance Springs, I'm on Dinan Springs. Also, I wasn't planning on running wider tires, I was aiming for 255.
I guess my main goal is to try and avoid using a 5mm spacers. If I can add a little negative camber and maybe stretch the tires more (245?if that's even advisable) to fix the tiny poke, I'm willing to do it if it's a slightly more aggressive and dialed in fitment.
Forgot to mention, I plan on tracking this car so I would end up with around -2.25° negative in the rear, which I believe should clear roughly 8mm or so. Therefore, the more aggressive ET43 should not really be poking at that point based off how I calculates everything and imagine it would be.
      01-05-2021, 06:46 PM   #96
Expert@ApexWheels
3532
Drives: M3
We seem to never have enough 2 series content. Lets see your photos with APEX wheels if you have them!
I found some old pics from one of our customers from back in 2015. His F22 was on a staggered set of APEX EC-7 wheels in Race Silver finish.
APEX Wheel Fitment Specs:
  • Front: 18x8.5" ET45 EC-7 in Hyper Silver with 235/40-18 Michelin PSS
  • Rear: 18x9.5" ET58 EC-7 in Hyper Silver with 265/35-18 Michelin PSS
      01-08-2021, 07:32 PM   #97
PeterWT
PeterWT's Avatar
Drives: '17 M240i, AT, BSM
Here's mine with EC-7s in anthracite with Michelin A/S 3+:
Front: 18x8.5" ET45, 5mm spacer, 235/40
Rear: 18x9.5" ET58, 5mm spacer, 265/35
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
      01-15-2021, 06:35 PM   #98
Expert@ApexWheels
3532
Drives: M3
Looking good! Thank's for posting!
-Ian
PeterWT253.50
      02-02-2021, 01:12 PM   #99
Expert@ApexWheels
3532
Drives: M3
Checkout our customer Jared's 2 series on a set of 18" APEX EC-7 wheels in Anthracite finish!
APEX wheel fitment Specs:
  • Front: 18x8.5" ET45 EC-7 with 235/40-18 Michelin PS4S
  • Rear: 18x9.5" ET58 EC-7 with 255/35-18 Michelin PS4S
      02-07-2021, 08:08 AM   #100
PeterWT
PeterWT's Avatar
[/CENTER]
No spacers?
      02-13-2021, 12:43 PM   #101
helloelectro
174
Drives: 2018 BMW m240i
[/CENTER]
No spacers?
5mm spacer in front. None in rear. This is my car BTW
      02-14-2021, 03:14 PM   #102
PeterWT
PeterWT's Avatar
Thanks for the confirmation. Looks nice!
      02-23-2021, 06:27 PM   #103
Expert@ApexWheels
3532
Drives: M3
The Fully Forged APEX ARC-8R and EC-7R feature a profile 2 medium concave design in all sizes. This allows even the F2x chassis to have some concavity despite the high offset requirements.
  • Front/Rear: 18x8.5" ET35 with 235/40-18 Michelin PS4S tires
  • Additional Modifications: Lowering springs
Owner's Instagram: @greglimbardo
      03-18-2021, 02:45 AM   #104
GetShwifty
Drives: 2016 M235i
Do all these 18x8.5" ET35 with 235/40-18 Michelin PS4S setups you keep posting need spacers in the front for suspension clearance? If they do, why do you just have ET35 and ET45 instead of an ET40 wheel?
      03-18-2021, 11:07 AM   #105
Expert@ApexWheels
3532
Drives: M3
Thanks for the question! None of the 18x8.5 ET35 setups need spacers. Our 18x8.5 ET45 wheels do require 3-5mm spacers up front, but they allow you to run wider front tires without modifying your alignment compared to the 18x8.5 ET35s.
We produce a large number of 18x8.5 ET35 wheels for other BMW chassis as this is a very versatile width and offset combination that works as either a front fitment or square fitment on other non-M cars. 18x8.5 ET45 was developed specifically for the high offset requirements of the 1 series chassis and is really only used on the 1 and 2 series. Its offset is slightly higher than ideal for the 2 series front fitment but can be compensated for with a spacer and is ideal for the rear fitment of the 2 series. There isn't enough demand for a 3rd 18x8.5 ET40 wheel that would slot between these 2 wheels specifically for the 2 series market front fitment.
-Tom
      03-23-2021, 01:43 PM   #106
CarbonLion
33
Drives: '15 228i
2015 228i  [0.00]
Not my first bimmer but my first to wear Apex-es
FL-5 18x8.5 ET35 square wrapped in 235/45 MPS4S.
I am running Dinan springs and the fronts rub the fender lip just slightly under rapid compression, but it occurs so infrequently it's no biggie for me.
Current - '15 228i
Appreciate 3
      04-03-2021, 04:55 PM   #107
SkyeC
Too many cars, not enough time
43
Drives: 17 m240i
Updated pics now that I've installed ST XA coilovers... Wheel/tire spec in sig.
FOR SALE: 2017 ///M240i, 6 speed, slick top, Estoril Blue. https://www.2addicts.com/forums/show....php?t=1865469
      04-04-2021, 05:36 PM   #108
spidy512
Drives: 2015 f80 M3
2015 BMW M3  [0.00]
Looks GREAT!
What camber are you running and do you like the Millway Streets? I am thinking B16 and the Millway as a combo.
Anyway, great looking ride. Looks like are in the same area code as well...
josh
      04-05-2021, 09:35 PM   #109
SkyeC
43
Drives: 17 m240i
Thanks! Millway Streets have minimal NVH, no problems with them at all! -2.5 front and -2 rear, love it so far on the street.
And yeah, I'm in Dublin. Don't drive it much though, just random trips on the weekends and whatnot.
      04-11-2021, 08:02 AM   #110
JD11937
130
Drives: 2017 M240xi
@Expert@ApexRaceParts would you guys ever be interested in developing an aerodisc like product that could be fitted to some of your existing wheels?
2addicts
