PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
FTM Sucks!
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-04-2011, 02:13 PM | #1 |
Rep 7,089
Drives: '06 AW 330xi
FTM Sucks!
So every time I go on a long trip, I check my tire pressures. Im going home today (about a 2 hour drive) so while I was filling up, I checked the tire pressure on all 4 wheels and they were all within 2 psi (of spec) but the front, passenger side wheel. It was at around 20 psi....my fronts are suppose to be 32psi.
Anyway, my car didn't tell me I had a "flat." I know FTM is not as accurate as TPMS but 12psi is a pretty big drop. FTM should have picked this up and warned me, no? I always reset the FTM when I check the tire pressures and I did today after making sure my tires were properly inflated. Does anyone know exactly how the FTM system works? I know it monitors the rotational diameter of the tire or something....less air, smaller diameter, more air, larger diameter. But which sensors are used? ABS? I want to clean them as I think the winter salt/road grime has hindered their ability to read proper values. Thanks. |
02-04-2011, 03:29 PM | #2 | |
NHTSA Nazi
28
Rep 1,983
Let's say that your front left was at 30 and your front right at 20. The system will think that is OK and you'll be able to lose several pounds before it alerts you. Try this Inflate all tires to the same amount (or front two the same, the rear two the same) Drive for a week Check pressure If the tires held pressure then Deflate 1 tire to 20psi and start driving. You should get a warning. If not, then your system needs repair. |
02-04-2011, 03:46 PM | #3 |
2880
Rep 2,761
Drives: 2020 M4 ZCP / 2023 X3 M40i
I don't know anything about FTM, but you should check tire pressures when cold. Best way is doing it early morning when the car has been sitting overnight. Checking pressures during the middle of trip won't give you accurate readings.
02-04-2011, 03:49 PM | #4 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
When I read your title I thought you were referring to the E90postwhore Midget!
he sucks! back on topic sorry.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
02-04-2011, 03:50 PM | #5 |
505
Rep 35,580
Drives: JB 33ZERO
this is true, as temps rise so does pressure.
02-04-2011, 03:56 PM | #6 | |
Rep 566
Drives: 2006 330xi 6MT
When you initialize it, it is checking the difference between the two. Meaning if both the left and right tires lose air at the same rate FTM will NOT activate. I agree with you it's retarded. My tires werent holding air for some reason and my pressures in both fronts got down to 15 only 2 days after I filled them up and FTM never activated. I only noticed because I scraped my bottom going over a speed bump. I check my tires religiously now. |
02-05-2011, 01:23 PM | #7 |
Rep 7,089
Thanks for the responses guys....I'll have to try deflating one side to see it it trips.
I usually check my pressure at the beginning of the trip so it shouldn't be warm (expanded) especially in this weather. |
02-05-2011, 01:28 PM | #8 |
Moderator
618
Rep 10,855
Curious, the FTM works great on my 335. Some times it seems more sensitive than at other times. Not sure how it is able to deal with measurement when there is tons of snow, I guess it is able to detect differences that are consistent over a long period.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
02-05-2011, 07:05 PM | #9 | |
Rep 7,089
But washing the car shouldn't affect the sensors. I mean I haven't had problems with it until this winter.....the car is about to turn 5 years old in May though. |
02-05-2011, 07:55 PM | #10 |
124
Rep 2,554
what? my idrive says tpm?
This whole time i thought my tires were up to spec, but its just been measuring the tire diameter difference? Can anyone confirm that i have a FTM and not a TPMS? What about tirerack, it says that my car requires tpms sensors? Edit: would FTM even work with RFTs? |
02-05-2011, 08:07 PM | #11 |
Rep 1,190
The older system that used the ABS system is DIFFERENT than newer cars with TPMS. TPMS has a sensor in the tire that reports tire pressure changes to the car. FTM uses the abs sensor to determine rolling diameter. I do not think there is a sensor in the wheel when you have FTM.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
02-05-2011, 08:07 PM | #12 | |
Rep 7,089
FTM works with RFTs. All pre-March '07 (I think it was March) models have FTM and all E9xs come with RFTs. |
02-05-2011, 08:31 PM | #14 |
Rep 7,089
Not sure. Maybe through your turn signal stalk?
Procedure should be in your manual. If you don't have one, there is one on the bmwusa.com website. |
02-06-2011, 01:40 PM | #15 | |
NHTSA Nazi
28
Rep 1,983
02-06-2011, 01:43 PM | #16 |
Rep 14,829
Are the systems different on the 330 v. 335? I do find it funny, that when I switch to my snows, which do not have TPMS, it takes about 4 miles for the system to light up. Likewise when I put the OEM's back on.
03-10-2011, 10:27 AM | #17 |
Rep 7,089
330s in the US will have ftm. Post March '07 e9x in the US have TPMS. That's why it takes a few miles to tell you it's flat....ftm measures the rotational diameter of the tire.
01-05-2024, 02:46 PM | #19 |
Rep 2
Drives: 2006 bmw 330xi. 1997 bmw 318i
I believe ftm go off the rotation of the tire like if your rear left is spinning faster than your rear right due to the tire loosing pressure it will send the code as a flat tire
