Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Downpipes question
      12-24-2012, 03:13 PM   #1
reeltime
Drives: 2015 M4
Downpipes question
Hey guys, i'm looking to buy some DPs but I have a question concerning inspections. In MA, we have to do visual and emissions testing, so if i get catless DPs, how am i supposed to pass inspection?
I did a good amount of searching and the answer is either get the DP fix, or take out the DPs every time for inspection. I also saw that if you use a JB4, it doesn't throw any codes. I'm currently running COBB stg 1 agressive and know that i can clear codes but i don't think it'll pass emissions..
i needz input
2015 AW/SO 6MT F82 M4
      12-24-2012, 03:24 PM   #2
MrRetep
MrRetep's Avatar
107
Drives: 435i M-Sport
For visual you will need stock DP's every time. For the scan you will need the DPfix, JB4 will clear the light/codes but it will not give the "ready" command or whatever that passes the scan inspection. so in any case you will need one or the other.
      12-24-2012, 03:35 PM   #3
reeltime
Drives: 2015 M4
Yeah i figured i would need the dpfix. Is that just hardware that plugs into the ECU? That will work with any tune right.. not just a BMS tune?
      12-24-2012, 03:39 PM   #4
MrRetep
MrRetep's Avatar
107
correct, you just plug into the appropriate pins in the ecu connector and yes it will work with any tune.
      12-24-2012, 03:44 PM   #5
e92oholic
Drives: 2013 MINI JCW GP
And as long as the 2nd cats are there no one should notice the dps. They are tucked away pretty good.
      12-24-2012, 04:16 PM   #6
Envuks
Envuks's Avatar
26
Drives: '08 e92 335xi
DPs won't be noticed on the visual. You will need a DP fix.
Jet black e92 6mt 335xi:
18" BBS RGRs, KW v1, ESS Stage 2 flash, VRSF 7" FMIC, VRSF downpipes, JG Mods m-tech front, mtec V3 AEs, BMS OCC, hardwired valentine 1, p3cars gauge, amber delete, sport seats, factory oil cooler.
      12-24-2012, 04:25 PM   #7
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
I can confirm that the visual won't matter in MA. Only the OBD2 readiness.
      12-24-2012, 04:35 PM   #8
reeltime
Drives: 2015 M4
Sounds good.
Yeah i wasn't too worried about the visual.
Looks like i have to buy a DP fix. Do i need a DP fix if i have a JB4? I was thinking about changing just because of the ease of integrating meth/e85.
Thanks for the replies guys
      12-24-2012, 04:39 PM   #9
MrRetep
MrRetep's Avatar
107
Sounds good.
Yes you will still need a dp fix in addition to a JB4. (At least you used to, I'm not 100% on that. )
      12-24-2012, 09:13 PM   #10
reeltime
Drives: 2015 M4
Sounds good.
Alright sounds good.
Thanks a lot guys, I appreciate it
      12-25-2012, 12:54 AM   #11
ek99civic
BMW Noob
ek99civic's Avatar
Drives: 2008 335i
Once you install the downpipes you can switch to Cobb stg2 and it will take care of the CEL. So you wont need the downpipe fix.
      12-25-2012, 08:23 AM   #12
reeltime
Drives: 2015 M4
I read that somewhere but then they said that it won't pass inspection because the emissions wont be able to communicate with the car. I thought you had to remove the tune?
      12-25-2012, 08:54 AM   #13
TOS_335i
bs_335i
TOS_335i's Avatar
Drives: 2009 335i
2009 BMW 335i  [0.00]
You do need the dp fix (Cobb just hides the dash light), but you don't have to remove the tune (if you're running any of the stage 1 maps). PA has the same inspection process, and I went through with no problems whatsoever.
BTW, my Cp-e DPs are currently for sale... I sold my car about a month ago.
Cobb Stage 2+FMIC | CP-e DPs | CP-e DCI | ETS 5" FMIC
      12-25-2012, 02:03 PM   #14
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
i needz input
The majority of people who end up modding their cars go cattless DPs. If you go cattless you "risk" the following
  • Drone
  • Rasp
  • Smoking (from seals that are about to go due to no back pressure)
  • Not legal ie being busted
  • Will spend more money to have them uninstall/reinstall unless you do it yourself
If you want to stay clear from all the above, get downpipes w/ HighFlow Catts and have your mid catts removed later
Edit: Kinda figured I was going to get a back lash about the DP / Smoke statement on the side lines. So let me clarify.
Usually when people do DPs the next thing that is done are removing mid-pipes (sooner or later). I did not say you "WILL" blow your seals if you go cattless. I said you "RISK" the chance of smoking usually caused by seals coming to their end of life. This mostly happens (smoking) with those who are "completely cattless", which is one of those mod bugs when you start removing catts.
Being cattless but keeping your mid catts retains some sort of back preasure which in return "reduces" the chance of smoking like a chimney. However, you will still fail emissions unless you rig up something like a DP fix . Our turbos were designed to have some sort of back pressure and the seals on them suck azz badly.
My recommendations to the OP was to get downpipes with HighFlow catts and still pass emissions even if he decides to reduce more back pressure by removing the mid catts
downpipes
