BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Error Code discrepancy between apps
proTUNING Freaks
      04-30-2024, 12:25 PM   #1
Mooney6959
Drives: 2015 435xi Convertible
I installed a FabSpeed catted DP the other day and wanted to check to see if I had any code history today. I'm not expecting it, but also don't recall if I have BM3 clearing them automatically or not.
I installed BimmerLink and ran the code scanner, and it said I have something like 11 errors over 8 modules. Then it said I need to purchase if I want to see them (I have purchased BimmerCode, but that doesn't seem to help).
So I decided to try to see what Torque showed, and it showed 0 errors.
Then I went into BM3 and looked at the diagnostics - no codes there either.
Is BimmerLink showing I have all those errors just to bait me into buying the app and then going to tell me they're each some generic thing?
      04-30-2024, 12:28 PM   #2
LA1Z24
Drives: 2014 435i M Sport
Torque will only read codes in the DME (ecm) while bimmerlink will read codes in all modules.
      04-30-2024, 01:00 PM   #3
Mooney6959
What about Bootmod3? Doesn't that read each of the modules?
And how do you (or anybody here) think that would compare to an inspection center? If Torque doesn't see any codes, what's the likelihood it would on their end?
      04-30-2024, 03:38 PM   #4
LA1Z24
BM3 app will only read the DME.
You should probably just post your list of codes and let us tell you how it's going down instead of just throwing shit at the wall and seeing what sticks.
      05-01-2024, 01:33 PM   #5
Mooney6959
Well, the check engine light came on today, and torque provided the below.
Definitely a cat issue, considering I just changed it on Saturday.
I was half expecting this after hearing of others with the FabSpeed catted dp getting error codes, but was hopeful it was a fluke.
Now I get to see how serious FabSpeed is about their no CE claim.
      05-01-2024, 11:28 PM   #6
thejeremyman9
thejeremyman9's Avatar
4392
Drives: 2015 BMW 335i
Attachment 3446969
Does BM3 show that as an active or a shadow code? Have you completed a drive cycle?
Its possible for the fabspeed to occasionally throw that as a shadow code. Note that most new cats also usually have a coating on them that needs to burn off. Before you go trying to warranty it, drive ~100 miles and complete the drive cycle and check whether or not your catalyst monitor is complete.
I've had that shadow code before and if its not an active code it doesnt prevent your emission monitor from getting ready nor passing emissions. I've had fabspeed for almost 5 years, no issues even in CA.
