05-28-2014, 08:20 AM | #6645 |
General
10473
Rep 40,902
PM sent.
05-28-2014, 03:12 PM | #6647 |
Rep 718
Drives: N/A
Hi,
For the F10 M5, I tired to code the side view camera and real view camera on ALL THE TIME. can this be done or no? I read some post here said even it's coded, it wont stay on ALL THE TIME. Can anyone confirm for me? Thanks
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
05-29-2014, 01:33 AM | #6648 | |
Rep 80
TRSVC 3000 SV_Activate_Speed_Limit TRSVC 3000 SV_Deactivate_Speed And you get side view camera up to 255 KM/H (= ALL TIME :-)) I suggest to fix at much lower speed ! __________________________________________________ _____ For REAR VIEW camera you can set both to FF as new hex value: PDC 3009 D_SCHWELLE_2 PDC 3009 V_SCHWELLE_2 Max distance will be 255 MT then camera will be disabled but can be reenabled with PDC button at any speed for other 255 MT up to 255 KM/H (which ever come first :-)) __________________________________________________ _____ For TOP VIEW camera you can set both to FF as new hex value: PDC 3009 V_SCHWELLE_1 PDC 3009 D_SCHWELLE_1 Max distance will be 255 MT then camera will be disabled but can be reenabled with PDC button at any speed for other 255 MT up to 255 KM/H (which ever come first :-)) __________________________________________________ _____ Of course you can fix any HEX value for speed/distance as per your wishes. (For SIDE VIEW cameras SV_Activate_Speed_Limit <= SV_Deactivate_Speed) Last edited by abcpop; 05-29-2014 at 01:58 AM.. |
05-29-2014, 12:39 PM | #6649 |
Rep 16
Hello.
My car from the factory was without 544 and there was only LIM button on the left side. I have retrofitted controls with 3 buttons: lim, res, cruise. I've added 544 to FA and coded the car. Also I did SLD_function manually in the corresponding units to make LIM button work as it should. Now there are 249, 255, 544 in my FA. The problem is there is a error in Rheingold that MFL (wheel) doesn't correspond to my configuration. I found out the error disappears when I set FEM -> LIN_VARIANTE_MFL -> DCC_Sports_SLD. Does anyone know how to fix it throught FA? Many thanks. |
05-29-2014, 01:27 PM | #6650 |
Ma' the meatloaf....
Rep 51
Liking this thread.. I just picked up a 2014 F10 M Sport. I am sure this has been mentioned but.. would coding/changing values void the warranty?
Anyone coding in AZ? |
05-29-2014, 01:47 PM | #6651 |
16
Rep 42
Please can someone help!! Having replaced my cloth seats with leather interior after connecting battery I am now getting 'Driver Restraint System' warning in my instrument cluster. I would just like to attempt to scan and clear the code - no programming yet. I have downloaded E-Sys and have followed instructions in the OP. However i do not have an EST folder to move as per step 4 in the instructions. Can anyone help an absolute noob?
Many Thanks in advance! |
05-29-2014, 02:00 PM | #6652 | |
Rep 16
You should open Tool32 to fix your error, press F3, open acsm4.prg and double click on Steuern_verriegelung_schreiben. But be careful you can damage your car with Tool32. Other more safety way is to install Rheingold. Last edited by Tcheslavie; 05-29-2014 at 02:18 PM.. |
05-30-2014, 01:00 AM | #6653 |
Coding ECU's remotely
445
Rep 1,176
Hi,
Does anyone know which items need setting on an NBT unit to get the L7 & Equalizer menu to appear. I'm trying to help a guy with Harman Kardon fitted & we want to see if we can activate the Equalizer. I suspect it will require a change of hardware to a different amp too. TIA
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
05-30-2014, 07:02 AM | #6654 |
16
Rep 42
Thank you for your response pal : I wont risk using Tool32 and will look into Rheingold. Thanks once again.
05-30-2014, 10:16 AM | #6655 | |
Rep 28
If not, you can try AUDIO_SYSTEM= hk_surroundsound [04] HIGH_END_AUDIO_B_UND_W = kein_menue [00] HIGH_END_AUDIO_MENUE = kein_menue [00] LOGIC7_SYMBOL = aktiv [01] ... |
05-30-2014, 12:05 PM | #6656 | |
445
Rep 1,176
Thanks, I'll give that a try.
05-30-2014, 11:51 PM | #6657 |
Rep 5
I got the cable few days ago with six discks of software. Only my Mac has a dvd drive my PC laptop is driverless. I want to download the software prefferably for Mac and leave it here. Any suggestions? Thanks in advance.
05-31-2014, 02:20 AM | #6658 |
General
10473
Rep 40,902
There is no reason for an ENET Cable to some with six discs of software?
Did you order an ENET Cable or a DCAN Cable, the latter of which often comes with INPA, DIS, Progman, etc.?
05-31-2014, 10:48 AM | #6659 |
Rep 20
Please help anyone?
Today i tried to code F30 build date mid 2013 same as my car. I think i tried everything like unplug,restart win,esystem etc but that car still can not detect enet cable, but when i connect to my car esystem can see the enet cable. What's wrong? icon in the window is detect the cable but still in esystem when i connect to that car still nothing..anyone? |
05-31-2014, 11:56 AM | #6661 | |
General
10473
Rep 40,902
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good 3) Car must have proper voltage (start engine). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
05-31-2014, 11:57 AM | #6662 |
General
10473
Rep 40,902
PM sent.
05-31-2014, 12:18 PM | #6663 | |
Rep 20
2,3,4 checked ok 5 i didn't remember maybe next time i will take attention to it. 1, target connection window?do you mean connect via vin? At the same time when i connect to my car it display numbers But when i connect it to other car it's said no zgw bla2 PS I already coded some f30 cars,this is the first time the esys can't detect enet on one car but can connect to other car |
05-31-2014, 12:31 PM | #6664 |
General
10473
Rep 40,902
Yes, in the same Window where you connect via VIN, the Chassis Target Connections must be present.
Yours must be since you have connected to other cars.
05-31-2014, 12:46 PM | #6665 |
Rep 3
File Download
Hi Shawn,
Frogman helped me code my car last year, and the dealership wiped my coding out when they ran an update without my permission. Could you send me the link for e-sys and PSdZdata for a 2012 F30? Thanks! -Batinator |
05-31-2014, 12:48 PM | #6666 |
General
10473
Rep 40,902
PM sent.
