[FIXED] Issues after new battery - Steering Lock Error, cant start car
06-01-2018, 07:35 PM | #71 |
Rep 11,903
11-09-2018, 03:49 AM | #73 |
Rep 6
Hi every one, Need help with steering lock issue.
My son 320D (2008 model) was put to smash repair due to minor accident claim. After the job was done (about 1 week) received the phone call from workshop saying that the car finished, but there was an issue, the message display that steering locked, and car unable to start, they get their mechanic to do diagostic scan and said the steering column need to be changed. And because it's not the accident related I have to pay for it, if I want to go ahead for them to do the job. However, just cut the story short, after contact my insurance regard the mater with no luck. I have to tow the car home, call my mate come over to check. The message said steering locked, turn steering to start the car, also there's the sign of the yellow steering with the the arrow on top pointing to left and right (not the one with the padlock). Try turn the steering but still can't start. Charged the battery to full as it getting low when get back from workshop. (Battery just 1 yr old and been install and registered by BMW specialist, together with the new comfort access module). try to reset the ELV using tool32, still no luck (look like inpa unable to communicate with CAS). Physical removed the steering lock (completed off), order the ELV emulator and install, still no luck. After reading fews post regarding this issue, I think may be my CAS been lock up due to too many low voltage startings (which I found out they did at the workshop to move the car in and out of the workshop)and need to be flashed and/or software update, then ELV reset. Is it anyone out there in Sydney that got the right tools to do it please PM, I'm happy to pay for the work as long as it work. Or if you know any mobile mechanic can do the job please PM me as car unable to start and I don't want to tow it to the workshop if I don't have to. Car is in Yagoona, Bankstown area. Thanks to all members with all the helpful posts. |
12-12-2018, 10:23 PM | #74 | |
Rep 1
success
Hello all, This is my very first post on this forum. I wanted to share my experience. I had the same issue with steering wheel lock warning sign appeared after I replaced old battery that died on me after being parked for a couple months. If I knew that it's a bad idea to let it be parked and not being driven for awhile, but It's my first BMW so I've learned my lesson here. I got a refurbished battery, installed it, and then tried to start, but instead I got the warning sign. I researched the possible causes. A big thanks to this forum, I purchased OBDii-USB cable, installed Mike's software pack, and plugged my laptop to the car. I used Tool32 to clear two EVL jobs and registered battery. The steering wheel lock warning sign disappeared and car started. I'm glad it worked for me. Thanks again, guys! You are awesome as well as this forum. P.S. my next job is two rear O2 sensors replacement. |
badmanners9.00 vtl1494.50 |
12-13-2018, 12:26 AM | #75 | |
Rep 11,903
12-13-2018, 11:13 AM | #76 |
1209
Rep 2,476
^agreed. Did the research, found/installed/learned/used the tool necessary to get the job done. Way to go! My only qualm would be the refurbished battery.
02-09-2019, 02:17 PM | #77 |
Rep 3
This is my first post I am having similar problems after leaving the car standing for a week went to start it and had an orange steering wheel with arrows left to right above it symbol on dash no ignition unable to start. Codes read A103 and A114 Tested battery and discovered it to be shot
Replaced the battery with BMW original and registered it with inpa and used tool 32 to reset the ELV counters cleared all codes. Still the same problem So purchased a ELV emulator removed steering lock and fitted emulator reset ELV counters again cleared codes. still the same problem If i disconnect the passive go module above the battery i can start the car and lose the fault on dash Is it the module or something else causing this? I am not that good with these things was wondering if anybody has had a similar thing happen? |
02-10-2019, 03:33 AM | #78 |
Rep 1,600
Does the Tool32 reset work if you can't get ignition on due to an ELV fault?
The ISTA ELV counter reset also only works if you can get ignition on because it won't even proceed to scan without ignition on. |
02-15-2019, 03:06 AM | #80 | |
99
Rep 237
I have had this very same problem at work. (I'm a Mechanic) Took me about 4 hours and lots of testing and scoping BUS signals, but long story short it turned out to be a short in the outer door handle sensors, (Comfort Access) If the car starts when you unplug the Comfort access module or "passive go" as it says on the module, it will be one of the front door handles i reckon. The rear ones don't have sensors in them. Try removing the door handle on the drivers side first and unplugging it, then try start the car. It's not hard to remove the handles. I know it sounds ridiculous that a door handle can stop the car from starting but trust me on this one. Here's the instructions on how to remove the handles. https://www.newtis.info/tisv2/a/en/e...-front/HoWBr0g Let us know how you get on. Very keen to hear if this is the issue Last edited by N52bigblock; 02-15-2019 at 03:14 AM.. |
04-01-2019, 10:53 AM | #83 |
Rep 3
Locked Steering Wheel Issue
So I've had the locked steering wheel issue for the past 4 months or so. Luckily I have another car to get me around.
The car will not start, the dash does power on and I can hear some type of mechanism activate when the key is inserted. When I try to start the car I get nothing (no crank or noise) and the steering wheel remains locked. I did try the emulator and still the same results. I did notice the battery drains itself if I leave the car for a few days so a lot of time I just end up unplugging the battery. I ended up taking it to the stealership just to get a professional evaluation and they of course told me I need to replace the entire steering column for only 1296.50. I don't have that kind of bread laying around so was getting close to the point of scrapping the car. But reading through this entire thread I'm going to look into ordering the OBD2-Usb cable and getting the needed software on the right computer and seeing if I can figure this thing out this weekend. I appreciate all of your post so far and would love any extra opinions before I get started this weekend. |
04-01-2019, 04:30 PM | #84 |
Rep 6,285
I actually had a flat battery over the weekend (due to a new POS ebay spec trickle charger ) and due to the low voltage i could hear the steering lock clicking unclicking constantly.
When I charged car up with my other charger it come up with the dreaded steering lock error, but alas I could start and drive my car. Apparently you can reset the ELV using winkfp software, but I had a fellow forum member code mine for me remotely. Maybe you can ask one of the guys in the coding subsection to code this for you? |
04-02-2019, 07:56 AM | #85 | |
Rep 11,903
Vince (Vtl) can help if you are in Melb Otherwise the tools to do a EVL (steering lock) reset are described above Good luck Last edited by Socket; 04-02-2019 at 08:16 AM.. |
03-08-2020, 12:07 PM | #86 |
Rep 2
I have a problem with elv.
I have the yellow warning light elv. But my car start good, and the wheel working well. The light start after i start to move the wheels. I reset in ista, in tool32 and nothing. Still same problem. |
04-12-2020, 11:58 PM | #87 | |
Rep 1
everything else is listed except those 2. Now what????? Any alternatives? |
02-20-2023, 02:16 AM | #88 |
Rep 1
Hey I need help please my car happened to have to the elv counter code i reset it using the tools you recommended in comments sections but car still doesn’t wanna start cranks but no start elv counter code is no longer there also but still doesn’t start I had a dead battery replaced the battery and got a new one.
