OFFICIAL: Air Suspension Thread
02-25-2015, 10:08 AM | #67 |
Rollin' Coal
53
Rep 185
Hopefully ordering my own Airlift kit in the coming weeks (once some clients decide to pay long outstanding bills). I've everything arranged in my head and I know what wheels / tyre sizes I'll be going for along with how much drop I'm going to be seeking. All good on that front.
However, my main concern is that because my car is a daily driver, I need the boot install to be as non-invasive as possible. The boot is small enough as it is on an E90 and since my rear seats don't fold, it's going to be even tighter than some. My plan was to install a 4 gallon tank at the very back and at the base of the rear seat or upside down. Looking at some of your installs, the four gallon looks much bigger than I thought it would. Would a 4 gallon tank fit snugly or do I need to start considering a 3 gallon tank?
http://www.pmcgphotos.com/
2006 E90 M Sport | BSM | KW Variant 1 | BMW Performance | Style 95 | SSDD Motorsport | M Style | Kenwood | Lightwerkz | Hartge Japan |
02-26-2015, 02:50 PM | #68 |
Rep 27
Here is a picture of my rear bags and brackets. There is a bolt on the bottom of the bracket with a large washer. I know the top goes into the upper cup but just dont know what the bottom bolts to because the lower control arm has a large hole where the spring sits.
02-27-2015, 09:41 AM | #71 | ||
Average Car Exceeding Expectations (ACEE)
359
Rep 4,806
No I did not, these were not available when I first did my suspension
Depending...you could prob piece one together for $3k-$5k Quote:
too much to list...just know its wide and bagged |
02-27-2015, 10:45 PM | #72 |
Sparkling Graphite Metallic FTW
153
Rep 3,212
Hey guys I will be bagging my car soon, I have a donor car. I am doing the work my self so I had a few basic questions. Car has the lines ran under the car outside. Is this how you guys did it? Or did you run air lines inside? I haven't looked at my car but on donor car the air lines are ran through the trunk floor. I don't know if there was a plug and it was removed but it seems like they used a rubber hose and silicone to prevent water from coming inside.
Also any info you guys want to share? |
03-02-2015, 10:21 AM | #73 | |
359
Rep 4,806
03-02-2015, 11:27 AM | #74 | |
153
Rep 3,212
noticed the front air lines run with a power wire behind the wheel well cover. I'm pretty sure that power wire has to go into the battery so there is sometime of access into the trunk. i don't like having to make a hole through anything.
03-02-2015, 11:32 AM | #75 |
153
Rep 3,212
Here is a pic of what was done with donor I don't think I could do this with my car. Also air lines are touching the diff. Which is a big nono
03-03-2015, 10:53 PM | #76 | |
Rep 914
Question for all the other air guys, how much camber will I be able to get out of the front camber plates on my airlift struts? If it isn't enough will I be able to use shims, like e36s use, to get more camber? |
03-04-2015, 08:11 AM | #77 | |
rallyroad.net
23
Rep 113
03-05-2015, 12:14 AM | #78 |
Rep 33
Have my trunk layout done and all electrical nicely organized for easiest instal possible, working on it this Sunday, hopefully I'll have the electrical all done and then install the suspension another day, I'm itching to get this done, I'll post some pics when I finish everything. Is there anyone in the NW with a bagged e90
03-05-2015, 09:09 AM | #79 | ||
Rep 914
03-09-2015, 11:13 AM | #80 | |
Rollin' Coal
53
Rep 185
03-09-2015, 01:33 PM | #81 |
359
Rep 4,806
man I totally missed this!!! I hope you figured it out...but what I would have suggested is to put on your stock wheels and let it calibrate that way. It doesn't calibrate off your wheel height, but off the suspension travel. And with the E-level you can always go back and change it afterwards.
03-10-2015, 10:04 AM | #82 | |
Rep 914
ACEE maybe you can help me out. How much camber can we get out of our front suspension with the camber plates on the airlift struts? |
03-11-2015, 12:34 PM | #83 | |
Rollin' Coal
53
Rep 185
03-12-2015, 11:39 AM | #84 | |
Rep 914
trunk setup |
03-13-2015, 04:57 PM | #85 | |
359
Rep 4,806
this is the only pic I have of my install...and its the 5 gallon
03-13-2015, 11:27 PM | #86 |
Rep 27
Can someone please help me with the routing of lines.. Are there any passthrough holes in the front cockpit, and the back of the car? Pics or anything would help! Thanks guys!!
03-16-2015, 12:17 PM | #87 |
359
Rep 4,806
just pull back your fender lining and run it through there...run it on top of your under shield and you will have to cut some holes in the trunk to feed them through. I did my holes on the higher up portion of the plastics behind the rear diff. I drilled from the inside of the trunk to out. Sorry I don't have pics
03-16-2015, 09:41 PM | #88 |
Rep 27
Awesome thanks for the info! Sorry but anything for the front? It seems so tight up there I was looking for a rubber push through hole were the glove box is but no avail.. Thanks everyone for the input!
