View Poll Results: Did you experience timing chain failure on your N20 engine? | |||
Yes, my timing chain failed or required replacement. | 33 | 14.47% | |
No, I have not experienced timing chain failure. | 187 | 82.02% | |
I replaced my timing chain as a preventative measure. | 8 | 3.51% | |
Voters: 228. You may not vote on this poll |
06-09-2019, 05:46 PM | #1 |
Rep 5,460
Drives: F30
N20 / N26 Timing Chain Failure Log
The goal is to get a more accurate picture of how just common the timing chain failure is on the BMW N20 engine.
Please only vote if you currently own or have previously owned a vehicle with this engine. Based on the poll results... we can come up with a rough percentage of active forum members who experienced this failure. We know these results will be skewed as the population of this forum is not necessarily representative of the entire population of N20 owners. That's okay as the results will still be interesting and provide some insight. Plus it will give us something else to argue over and bitch about Last edited by sspade; 06-09-2019 at 05:52 PM.. |
rjd_F302000.50 fluke36.00 BettyFkinCrocker180.00 obert1783.00 stroker1562.50 CandyRedRC46242.00 Fr3sh29.50 F30BimmerChris26.50 99937.50 428iSoCal24.50 fe7565557.50 |
06-09-2019, 05:55 PM | #3 |
Rep 5,460
Drives: F30
Model: 2014 328i
Build: Munich, 05.14.14 Mileage: 75k Timing Chain Status: No problems Oil Changes: Every 5k miles since 29k Stop/Start Status: Coded off at 29k Additional Details: Bootmod3 at 72k miles Last edited by sspade; 06-09-2019 at 08:16 PM.. |
BettyFkinCrocker180.00 snbd0.00 |
06-09-2019, 05:59 PM | #4 |
45
Rep 165
2014 328 65k miles, August 2013 build date. Timing chain good so far. I check once a month for tightness and guide damage
BettyFkinCrocker180.00 |
06-09-2019, 06:04 PM | #5 |
Rep 5,460
Drives: F30
To be fair, I'll give all these guys a nudge.
Newman1 egon0119 topside844 MyEvo8u dandurante |
06-09-2019, 07:03 PM | #6 |
Rep 3,680
Model: MY 2013 328i xDrive. December 18th, 2012 build date. Regensburg Plant.
Mileage: 77k miles Timing Chain Status: No problems Oil Changes: Every 5k miles since 42k miles, not sure about PO Stop/Start Coded Status: Not coded, but always turn it off Additional Details: None sspade great thread idea.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
06-09-2019, 08:31 PM | #7 |
Rep 681
Model: MY 2016 328i xDrive. 08/2015 build date
Mileage: 50k miles and counting (43k by PO) Timing Chain Status: No issues Oil Changes: Unknown as PO was a leaser and this was a lease return Start/Stop Coded Status: Not coded but always set to off Additional Details: Purchased with 43k miles and did first change (since taking ownership of car) at 46k miles. Plan to do another one shortly at ~51k miles (5k intervals)
2016 328ix F31 - SOLD!
2006 997.1 C4S Last edited by andino; 06-18-2019 at 09:39 PM.. |
sspade2475.50 BettyFkinCrocker180.00 |
06-09-2019, 10:12 PM | #10 | |
Rep 1,641
sspade2475.50 |
06-10-2019, 02:12 AM | #12 |
46
Rep 159
Model: 6/2014 F30 320i Sport RWD
Mileage: 96,000 miles Timing Chain Status: No issues so far Oil Changes: 18K miles by PO. After 50K miles oil changed in every 9K miles by me. Stop/Start Coded Status: Coded off by me. Not sure about PO. Last edited by kobluna; 06-12-2019 at 09:07 AM.. Reason: Use suggested pattern |
sspade2475.50 |
06-10-2019, 05:06 AM | #13 |
Rep 500
528i built 3/2013. 70000 km without whining sound. ASS is coded off since day 1. As I'm going to keep my car long term, I'll bring it in next 2 days to change the timing chain, chain guide and tensioner. Will also take a peek at intake valve if that need cleaning too.
sspade2475.50 |
06-10-2019, 05:40 AM | #14 |
Rep 12
Model: 2014 F30 320i Sport AWD/xDrive (Stock car only cosmetic changes made so far)
Mileage: 40,300 Timing Chain Status: Seems to be fine at the moment. Looking through the oil filler cap the chain has very light 'shiny' marks on it which i think is normal wear and tear i hope. (will try upload a pic of the chain through the oil filler cap and add it here soon - might be useful if others do the same for comparison) Oil Changes: Bought the car recently and car was following BMW maintenance schedules before i got it but now will be changing it every 5-6K Miles Stop/Start Coded Status: Coded out, never use it and never will (personal preference etc), not sure if the previous owner used it though. Additional notes: Had the car for 6 weeks putting around 700~ miles on the car so far with varied conditions (currently at 40.3k). Had no problems and to me the engine is very quiet (some people say it is loud for a petrol when reading forums because of the injectors) but i just came from a e60 520d which was crazy loud even for a diesel (N47 engine with apparently a bigger timing chain problem than the N20 but i never encountered that before selling luckily - sold with 94k miles on it had it from 50k). I've listened to countless 'timing chain' noise videos and it seems to be a distinctive sound which may help with diagnosing the problem before it happens just depends how bad the problem is with your car and if you are unlucky? I changed the oil and filter myself 1 week ago and will be making sure this is done around every 5k miles. From reading nearly every thread on this over the last 2 weeks and posts about this problem because i have this engine i wanted to do my research. Most people are having problems with build date 12/13 on the 328i so it seems and most with problem mentioned they are using ASS (i know could be a coincidence but its what i've seen while researching). Maybe more 12/13 328i's exist and a lot of people seem to say they are only following the iDrive for oil changes and people who seem to change their oil more regularly report less problems (again coincidence?). Otherwise i can't see a real 'pattern' emerging and all the timing chain/oil pump chain and guides part numbers changes discussions don't seem very conclusive with no real definitive answer to that. Not seen many people try preventative changes to the parts so not sure how effective this is? I would love to hear more from people who have carried out the preventative maintenance for the chains and guides. Good luck everyone and i hope all our N20/26 engines stay working perfectly!
2014 F30 320iX SE/Luxury: Current daily driver.
2008 E60 520d M-Sport: Retired April 2019 2004 E46 318i Compact SE: Retired June 2012 Last edited by Mike_BMW; 06-11-2019 at 10:08 AM.. Reason: Changed formatting for easier reading as suggested |
sspade2475.50 |
06-10-2019, 12:14 PM | #16 |
Rep 943
Drives: F30 328i Msport
15 328i n26. Build date 2014-11-20. 69009 miles pretty much stock.
Feels like im driving a ticking time bomb, literally lol. |
06-10-2019, 03:06 PM | #18 |
Rep 657
I'm at 105k N20 and nothing yet but I think my alternator is going out that's about it lol. PWG and 2012 not sure what my build date is exactly I believe it was 11/12.
Current: 2017 Bmw 540i M sport bluestone metallic
Previous:F30 328i 2012 PWG: FBO Vrsf 6 stepped fmic, Afe intake, Catless DP ER, FTP CP's, FTP turbo inlet, GFB DV+, Gplus oil cooler, BM3 stg 2 tune, Cary Jordan E50 tuned stock fuel system. |
sspade2475.50 |
06-11-2019, 09:40 AM | #20 |
47
Rep 25
I will join in on the fun! sspade feel free to use the template below and re-post in the first thread so all users follow same format:
Model: 2012 F30 328i Sport RWD Mileage: 107,000 miles Timing Chain Status: Failed at 107,000 Oil Changes: started doing 1/2 intervals approx 2 years ago. (6K Miles) Stop/Start Coded Status: I still has stop start enabled, but would frequently turn it off Additional Details: Purchased at Local BMW Dealer CPO with approx. 27k miles, BMW NA will nto provide assistance. Swapping motor with a used 2016 N20. 0 Issues with the car prior to this, absolutely loved it. I also recommend anyone who had timing chain issues to report to NHTSA, as it will help the class action law suite: https://www-odi.nhtsa.dot.gov/VehicleComplaint/ Last edited by MyEvo8u; 06-11-2019 at 10:03 AM.. |
sspade2475.50 |
06-12-2019, 07:12 AM | #22 | |
154
Rep 387
