New Ytest
Sign out
Bimmerpost
Login
BMW E39 5-Series Forum | 5Post.com
Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      07-31-2023, 01:55 AM   #1
Mert335d
9
Drives: E92 335d LCI
  [0.00]
Upgraded K+DCAN Cable - Interests ?
Hello E39 Community,
i upgraded my K+DCAN Cable with the enhanced Firmware and I want to ask you, if there is any interest in buying an upgraded K+DCAN Cable.
Advantages over normal K+DCAN Cable:
- DME Flash of M3/M5/M6 without ECU corruption
- SMG Flash of M5/M6 without ECU corruption
- Gearbox TCU Flash of E9X without ECU corruption
- coding TRSVC Module in E9X when retrofitted in E9X
- read FSC directly with SWID Reader and K+DCAN (no ICOM needed)
- faster CAN Communication
- safe ECU flashes due to software fuses
Edit 1: (07/31/2023)
- MHD Flashes under 1 minute
- XHP Flashes with OTG much faster
So in general: much safer, faster and 100% reliable Cable than the normal K+DCAN cables.
This upgraded K+DCAN Cable can be easily updated with USB, no Soldering or Pins required.
The K+DCAN Cable will come with the latest FTDI Drivers.
It is still working for BMW/MINI Cars from 2000 until 2012. The switch position controls the connection before 03/2007 and after 03/2007.
If there is any interest, i would try to make a good offer !
You can PM me if so.
Thank you !
5post
