ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      08-15-2015, 02:55 PM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
141
Drives: BMW Z4; BMW X5; BMW 733
INPA - ifh-0009 no response from control unit HELP!
Hello,
I have installed everything correctly and INPA recognizes when I turn on/off the car (Ignition bubble fills up and empties).
But, NCSExpert spits out IFH-0009 when I try to connect and INPA stops communicating with the car.
The light on the cable turns off as SOON as I ask NCSExpert to read from the ECU.
This is for my 2004 BMW Z4
Do I need to bridge pins?
Can someone please help?
      08-17-2015, 12:01 AM   #2
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
I have a similar cable and I needed to bridge the pins 7 and 8. You can always solder a switch if you're concerned about "permanently" bridging the pins.
2008 Z4 3.0si Coupe
      06-27-2016, 11:57 AM   #3
Reborn_
Drives: 2007 BMW Z4MC
I bridged pins 7 and 8 on my cable (verified to be from a reliable source) and still having this problem - except on mine, INPA won't even recognize battery or ignition. Any thoughts?
      06-30-2016, 08:58 PM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
141
Thank you koruptor. I've wire soldered the pins (taking apart the shroud, and will splice in a switch later) but it still doesn't work...
      07-03-2016, 07:40 PM   #5
Reborn_
Swiss Army - is your ECU stock? I've got an ESS tune which I suspect may have 'locked' me out - need to contact them and see if that's the case. But you and I are having the same problem, except in my case, INPA won't even detect battery/ignition on.
      07-03-2016, 09:26 PM   #6
SwissArmy
Why so serious?
SwissArmy's Avatar
141
Stock ECU, I'm going to try it out again this week and report what exactly happens.
      07-05-2016, 02:25 PM   #7
Reborn_
Sounds good. I'll give it another go in a few days with and without the pins bridged and report back as well.
      02-10-2023, 09:08 PM   #8
Aaron Maguire
Drives: BMW Z4 3.0
INPA Z4 issue
Did you find a solution? I have the same problem. I have the EPS light on and trying to clear it through INPA.
      02-13-2023, 09:20 AM   #9
Reborn_
My issue ended up being a bad software install. I got it sorted once I did the software correctly.
zpost
