03-24-2024, 03:49 PM | #1 |
Rep 80
Concerns buying a used f82
I went to inspect the car and it had oil leaking also ran it for codes. Transmission was clear but the engine had some misfires I will attached the screenshots but other than an oil leaks would it be worth it to buy it? It has about 100k miles and about to go into service (idk if they’re going to fix it)
03-24-2024, 06:04 PM | #6 |
47
Rep 111
With the misfire you could still be rolling the dice because there could be other issues that are not obvious yet. If the only issue is the misfire and the engine runes fine when warm, I’ll say go for it but just be aware, you could be buying a problem with no end in sight.
03-24-2024, 06:24 PM | #8 |
Rep 74
03-24-2024, 11:15 PM | #10 |
47
Rep 111
03-24-2024, 11:16 PM | #11 |
Rep 74
03-25-2024, 10:36 AM | #13 |
Rep 80
