01-23-2016, 12:37 PM | #23 |
Rep 1,134
Well. Tried it out and was completely disappointed. I'm pretty sure I need a better pressure washer cause the foam didn't even stick long enough for me to take a picture.
01-23-2016, 02:20 PM | #24 |
Rep 1,134
Well messed with some settings and finally got better results. Problem is the soap is gone within a minute or two cause I have to keep it at the max soap setting. I just need a better power washer but honestly I'm happy with how this is for now. This was with mr pink so I'm sure with honey dew soap will be better
02-13-2016, 11:59 AM | #25 |
Rep 6,696
Drives: F30 340i
how many ounces were you adding in the bottle? you might just have to add a little more to get some thicker foam, but ultimately it is based on your pressure washer. honeydew snowfoam is a great soap for this purpose.
02-13-2016, 12:45 PM | #26 | |
Rep 1,134
03-20-2016, 10:40 PM | #27 |
41
Rep 132
Dumb question: I just bought a pressure washer and it comes with 2 "soap/detergent tanks". Can I put the car wash soap directly in the tanks and mix with water or do I have to buy a separate foam cannon? I originally bought the pressure washer for house hold use but thought I would give it a shot with the car. I am normally a hand wash person.
03-20-2016, 10:47 PM | #28 | |
Rep 1,134
03-21-2016, 08:23 PM | #29 | |
Lofty
3461
Rep 849
I recently purchased a cheap, "generic" foam cannon from eBay for $20. Going to try it out once it warms up a bit and I have some time on my hands. |
04-11-2016, 07:53 PM | #31 |
Rep 1,307
curious as to what foam gun you guys are using?
anyone purchase anything from detailers domain?
2024 BSM G80 M3 CS | Build Thread
2021 Porsche 992 C2S | Build Thread 2018 Satin Black F80 | Build Thread IG | T1M3LESS |
04-12-2016, 06:45 AM | #32 | |
Lofty
3461
Rep 849
I've got a Gilmour foam master that works great. I just got a cheap generic foam lance of eBay. Going to try that out in a few weeks
F30 335 (FBO and BM3 OG)
991.2 C2 Range Rover Sport Diesel I4 M50 (coming soon) |
04-13-2016, 06:50 AM | #34 |
Rep 1,733
Drives: 2003 M3
This is the one you want:
http://www.detailedimage.com/DI-Acce...am-Lance-P770/ |
04-27-2016, 04:08 PM | #35 |
Rep 943
Drives: 2012 328i Modern Line
What do you guys recommend for electric pressure washers?
:wave:
04-27-2016, 04:37 PM | #36 | |
Lofty
3461
Rep 849
Ryobi makes some good, affordable stuff. Karcher ain't bad. Kranzle is expensive, but really nice
04-27-2016, 09:39 PM | #38 |
Rep 943
Which one did you get? Link?
:wave:
04-27-2016, 09:44 PM | #39 | |
Rep 1,134
04-28-2016, 05:06 AM | #40 |
Rep 26
04-28-2016, 10:47 AM | #41 | |
Rep 1,101
I have made several purchases from both detailed image and detailers domain. They have both been great. Good advice and good products. have emailed them a few questions and the response was good and their recommendations were perfect. |
04-28-2016, 06:55 PM | #42 |
Rep 1,307
I ended up picking up the MTM foam lance from Amazon as well as the Honeydew soap from Chemical Guys.
Still trying to figure out the "right" mix of soap/water... Don't think I used up enough soap the first wash.
04-28-2016, 07:18 PM | #43 |
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
Unless it's a Chemical guys Foam Canon, the results may not be as you'd expect. I went and bought a cheaper one and was very dissapointed at the result. Tossed it and bought the chemical guys foam canon and couldn't be happier...
04-28-2016, 08:24 PM | #44 |
Rep 1,134
So just to make sure, for those that bought a chemical guys foam cannon, did it come with a sticker? My friend and I ordered the exact same model and his came with the chemical guys sticker whereas mine didn't. I'm hoping mine isn't a knock off
