INTRO: Camber-Toe aka Boopie Motorworks
02-19-2010, 12:55 PM | #46 |
1619
Rep 2,161
02-19-2010, 01:10 PM | #47 | |
442
Rep 18,331
I told you about the shop....that alignment machine they have is BIG! |
02-19-2010, 02:14 PM | #49 |
Vengeance is mine, I shall repay
132
Rep 4,656
YES....thats the sig of the year right dere!!!!
Project: Vengeance[ACM's King of domestics, STOCK:501whp 489wtq | 2.9L whipple stock bottom end: 706whp 688wtq] Callies Compstar motor build:NEXT
02-19-2010, 06:47 PM | #50 |
Rep 929
Drives: E90 2007 328xi
Congrats Matt and good luck!
Yep, Matt's the man. He did my V3 install and post-install adjustment.
E90 2007 / Step / Montego Blue / Black Dakota Leather / Premium / Cold Weather
MODS: Exterior: Blacklines, debadged, HO ceramic 35% tint, Hoen yellow fogs, matte black grille, OEM style splitters, Halogen-to-Xenon Interior: Alum pedals, CF wrapped trim, V1 and Nuvi hardwire, M-Tech tri-stitched wheel, SMG M5 shift knob Performance: AluFelgen CSL 19" 8.5 ET33/9.5 ET30 with 5mm rear spacers | GY Eagle F1 Asym 235/265, KW V3, BMW Perf exhaust+intake |
02-20-2010, 05:03 PM | #51 |
Air India
145
Rep 1,834
Just got back from Camber Toe Motorworks and wanted to write a small review.
I have about 21k miles on my car. To say the least, I am VERY picky about who works on my car, that being said, I usually do the work on my car, or usually have a close friend of mine help me out. I had KW V1 coilovers on my 335i xDrive for about 5k miles. I detested the ride and I wanted to go back to OEM. I did the work myself and had the car aligned at BMW. In the process, I decided to not include the lower spring pads for the rear suspension, and a minute spacer on the front shocks. Ever since the car reverted to the OEM suspension I have been a rattle snake. The car's rear end made metal to metal noise on every little bump. I decided to go to Matt because of his excellent reputation on the forum and also his knowledge from the posts I saw him make in the past. On the agenda today were 1. put the rubber lower spring pads on the control arm 2. there are 2 torx bolts that hold this coupler that holds the shock - one was cross threaded, the other was missing and I replaced it recently - so remove the shot one and put on a new one 3. double and triple check the suspension I gave the car to Matt at 10:45am and was ready to get on the road by 1:45pm. Not only did Matt do what I asked him to do, but he went above and beyond. See, I need to comment here, this is where you have the border between a good mechanic and a GREAT MECHANIC. Matt falls into the latter. He truly is a GREAT/PHENOMENAL/TREMENDOUS/MASTERFUL mechanic. Not only did he do what I asked him, but he noticed that 1. the lower nut on both rear shocks were incorrect ones - ones used for KW - guess I grabbed the wrong ones during re-install. 2. the front springs were not installed in their spring pad perch properly 3. the catch can was loose (both screws fell off) He made notes on things that he wasn't asked to - which is initiative and shows me that he truly cares about the customer and doesn't want to see them drive off w/a problematic car. I absolutely adored having Matt work on my car and would only trust him to work on my 335. Kudos to Matt and Camber Toe Motorworks. You have a lifetime customer in me and someone that will recommend you to the world.
PKumarM3 |
02-20-2010, 05:33 PM | #52 | |
Rep 6,631
E90 LCI N54 6AT
02-20-2010, 05:59 PM | #53 | |
Air India
145
Rep 1,834
your car is sooo gorgeous. i love it. hope you enjoy the DP!
PKumarM3 |
02-20-2010, 06:56 PM | #54 | |
442
Rep 18,331
Matt is definitely a great person to deal with for sure...very methodical |
02-20-2010, 10:21 PM | #55 |
Rep 6,631
lol, if I knew the xi was yours I'd have stirred up a conversation! Your dog probably smelled my dog on me; prob why he/she got so excited!
E90 LCI N54 6AT
02-20-2010, 10:22 PM | #56 |
Rep 6,631
I showed up just about when his car was getting done it seems.
E90 LCI N54 6AT
02-20-2010, 10:30 PM | #57 | |
Air India
145
Rep 1,834
yeah i was there from 1045 to 145. it was a fun 3 hrs!
PKumarM3 |
02-20-2010, 11:15 PM | #58 |
310
Rep 15,745
So how's those downpipes feel? That car was a rocket and I wasn't even really pushing it!
I don't care what people say, chalk another one up for VK downpipes. Another smooth install, fit absolutley perfect, and no problem with 02 location . I hope that new DPfix from BMS does the job as well . |
02-20-2010, 11:20 PM | #59 | |
310
Rep 15,745
I hope you get that headlight situation taken care of. Both front and rear sensors were perfectly fine so I don't know why they wouldn't adjust right... |
02-21-2010, 02:01 AM | #60 |
Rep 808
+1 for camber toe and Matt!! He did my suspension there and installed my springs and did an alignment, car has felt amazing ever since!! your a true professional matt.. goodluck with the shop , will be visiting you soon once i get my coilovers and remove the springs
02-21-2010, 02:02 AM | #61 | |
Rep 6,631
E90 LCI N54 6AT
02-21-2010, 05:25 AM | #62 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
Hey whats up Matt this is Sean! I had no idea you were on the forum as a sponser. I can vouch for thye guys @ Camber Toe. Sing, Ryan & Matt do excellent work. They installed my RCA adapters, control arms, alignment on my Lexus GS400 last summer. Here is the car below..
I've recommended friends to the shop as well & will continue to use Camber Toe as my shop of choice. You guys should check them out for sure.. See you in the spring Matt.
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
02-21-2010, 07:52 AM | #63 | |
310
Rep 15,745
Everyone has remained except Sing tho..he moved out to a Nissan Dealership. No worries tho we got the bases covered |
02-27-2010, 06:52 PM | #65 |
Rep 8,067
Ok Im the guy who had his Forgestar F14 installed by Matt on Tuesday. Great job Matt. He also mounted my new TPMS that I ordered from Tischer BMW at $315 for the 2010 models. $315 is better than the $450-$465 I was quoted everywhere else.
Today Matt did my CDV mod and installed my UUC short shift kit. Matt did a great intall with the short shift kit. The ride is amazing and the price was on the money. Im not going to start giving out Matts prices but all I can say is he is very reasonable. Not only are you getting great work your not getting ass raped without the vasoline like other shops do. He is going to be installing my sway bars and suspension in the next 3 weeks |
02-27-2010, 06:53 PM | #66 | |
310
Rep 15,745
1. pppaaannnddaaaa, 2. owwwwnnnnsss, nnnottthing |
