FRM3 Resurrection Thread
04-25-2016, 02:19 PM | #45 |
529
Rep 2,503
04-25-2016, 02:36 PM | #46 |
coding BMW.....
487
Rep 874
i will do that at the end of the week when i am hope. the thing is that i was able to delete and write the EEE and then i read the p-flash without problem, then i delete the p-flash to with the new one i had from dump and since that moment i was unable to do anything else then delete (EEE and p-flash). if i try to delete it say s that it s secured. i try with the secure profile but does nothing when i try to reset security....
will be back with pics and log |
04-25-2016, 04:19 PM | #47 | |
Rep 1,191
04-27-2016, 05:57 AM | #49 |
Rep 1,191
05-21-2016, 09:26 PM | #52 |
BimECU
193
Rep 759
05-22-2016, 04:05 AM | #53 | |
529
Rep 2,503
http://s.aliexpress.com/AzEJBbmA 2016 Lastest version Xprog M 5.55 ECU Programmer Xprog-M V5.55 ECU Chip Tuning Tool with full set X prog m V5.48 |
05-22-2016, 11:34 AM | #54 | |
BimECU
193
Rep 759
06-08-2016, 06:54 PM | #55 |
BimECU
193
Rep 759
deleted
07-04-2016, 03:34 AM | #56 |
Rep 7
I found this p-flash in your collection : FRM E87 E92 E93 6135 9240528-01 SW 132001 HW 07.rar and its the same like my bad FRM. But there is only p-flash in it and not eee. is it enough to write p-flash without eee dump?
i tried to read p-flash but i am getting device is silent. |
07-04-2016, 12:27 PM | #57 |
BimECU
193
Rep 759
no, you need eeprom
07-05-2016, 01:30 AM | #58 |
Rep 7
I changed latency in driversettings from 16ms to 1ms. Then it Starts Reading p-flash but Same Problem with Device is silent. Eee i can read just Fine. Any suggestions where to get eee Dump for this frm? Will it fix the Reading error for pflash if i flash eee First?
07-05-2016, 01:37 AM | #59 |
BimECU
193
Rep 759
looks like your programmer problem,
good eee will not help P-Flash reading problem |
07-05-2016, 02:23 AM | #60 |
Rep 7
I have 5.55 clone. With Dongle Tool does not start up. So i tried with no Dongle Tool. Eee can read and it says wrong Partition Table but i can Read eee with Partition set to 16.
You have a Suggestion what to do? And which dump to take? |
07-08-2016, 02:58 AM | #62 |
Rep 7
Tried everything. Only using serial cable instead of USB solved the problem. Now its working fine. Only verification does not work and gives errors but should be no problem
07-12-2016, 04:18 PM | #63 |
BimECU
193
Rep 759
its fried,
you need good eep |
07-12-2016, 07:09 PM | #64 |
BimECU
193
Rep 759
post picture of the unit itself where numbers are written,
you need to chose by part number |
07-13-2016, 10:59 AM | #65 |
BimECU
193
Rep 759
07-13-2016, 04:12 PM | #66 |
BimECU
193
Rep 759
Just get proper eeprom so frm is responsive
You will change win number with WinKFP flash (or ista/p but its more complicated way) And then copy VO from Cas and then code it 5 minute job |
