The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding M3 cluster
      10-24-2016, 07:44 PM   #45
N54Twin
N54Twin's Avatar
413
Drives: F85
Originally Posted by J66 View Post
Originally Posted by Nitrousbird View Post
Ahh, now this is very helpful. I will try that some time over the next week. I have a feeling the gauge hijacking scaling for the JB4 isn't right with the M3 cluster, as my oil temp seems pretty close but when that gauge is hijacked for coolant temp it is way off. Probably the same with boost on fuel as well.
Hi there, i'm trying to program m3 manual e92 cluster on to my e89 z4, all gauges work except that the Fuel is reading backwards. when i fill up it goes to empty and warning, when i drive more it starts going up to full when is almost empty
Does any one know if the coding will fix this issue?
Have u try resetting kombi?
Sweet Pie
      12-18-2016, 10:07 PM   #46
Mturbo
Mturbo's Avatar
83
Drives: '07 E92, '10 SL63
I haven't cleaned it in a couple months either and this is my daily driver (excluding snow days or when I decide to drive my truck). I'm not exactly hard on the interior...you wouldn't be saying the same thing if you saw the interior of my wife's car (yuck).
I can't believe people pay $400 to have the EEPROM programmed.
How did u get your display to mirror your phone?
      01-08-2017, 08:32 PM   #47
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
Guys, I've M3 cluster here virginized and coded to car,
everything works fine but in CIC, speed limit shows KM/H
obviously units are set to US (MPG, Miles, etc)
looks like KOMBI is from Canada (?)
any ideas how to fix it?
I guess its in eeprom dump
      01-09-2017, 12:02 PM   #48
DaZuc
Drives: 335i xDrive
Set units to KM then back to Miles see if this fixes it.
I've coded cars where it would set to KM even though CCC/CIC shows Miles but you have to enable KM then go back.
      01-09-2017, 01:06 PM   #49
N54Twin
N54Twin's Avatar
413
Drives: F85
Yeah.
Same happens to me on my M5 cluster.
Sweet Pie
      01-09-2017, 04:59 PM   #50
Sensible_
529
Drives: 2008 E90
Can you show a picture of what you mean?
      01-09-2017, 05:44 PM   #51
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
Thanks
Changing units did not help
Pics:
https://www.dropbox.com/s/sasq2n23pi...%20PM.jpg?dl=0
https://www.dropbox.com/s/5svwkrb8r2...%20PM.jpg?dl=0
      01-09-2017, 06:51 PM   #52
N54Twin
N54Twin's Avatar
413
Drives: F85
So u change MLS to K and nothing?
Sweet Pie
      01-09-2017, 11:13 PM   #53
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
Yes, speed limit still shows km/h
      01-10-2017, 04:53 PM   #54
Sensible_
529
Drives: 2008 E90
Did you look at coding block for WARNUNG_GESCHW_LIMIT ?
It's in the KOMBI trace file so it's data should already be in NETTODAT.TRC when you read coding of KOMBI with NCSEXPERT.
NCSDummy has it at address 300006 for info.
Maybe worth looking around there for a MPH / KMH switch?
      01-10-2017, 11:43 PM   #55
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
its interesting
WARNUNG_GESCHW_LIMIT is not set to anything, i.e. there is no line for it in TRC
TRCs:
https://www.dropbox.com/s/3dpdtpxayk...W_FSW.txt?dl=0
https://www.dropbox.com/s/95a5ezmopn...T_TRC.txt?dl=0
      01-11-2017, 02:55 AM   #56
Sensible_
529
Drives: 2008 E90
Hmm, maybe changed in updated coding index. What coding index are you using for KOMBI?
      01-12-2017, 08:13 AM   #57
KJMotorsport
Drives: 135i DCT
Love this thread, simplified the procedure for me no end!
Looking into possibly trying this out on my E82 using a cluster from E92 M3...
In theory would it be possible to copy the hex data from my EEPROM chip on the E82 cluster and overwrite the information to the E92 cluster.... (probably the more difficult way of doing it as opposed to just 'virginizing' the E92 cluster...)
Also then how would I scale the warm-up lights from the S65 to the N55 or would that take care of itself?
Then it would just be a matter of modifying the E92 cluster to fit an E82 but ill get to that issue when the time comes
Thanks
KJ
Le Mans Blue/Lemon 10' 135i DCT - N55 - PPK Stage 1, 18" Style 269's w Michelin PS4's
      01-23-2017, 09:56 PM   #58
RS6
9
Drives: E90
Does anyone have a good EEPROM read by any chance that I can transfer into mine as I can't read the original EEPROM from the used M3 Cluster? I need one with KM/H original. TIA
      01-23-2017, 10:21 PM   #59
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
try this one and report pls
https://dl.dropboxusercontent.com/u/...VIRGINIZED.bin
      01-24-2017, 02:37 AM   #60
tropical335i
tropical335i's Avatar
Mauritius
17
Drives: 335i LCI MSPORT
Cruise control fault msg
Anyone got a cruise control fault message after an M3 cluster retrofit and coded?
Please chime in.
Thanks.
      01-24-2017, 07:18 AM   #61
RS6
9
Drives: E90
Thanks let me give it a try, but I wont' be able to do it till late next year. Will definitely report back.
      01-28-2017, 10:20 AM   #62
19E92
19E92's Avatar
35
Drives: '07 335i / '11 535i xDrive
Hey everyone, I purchased the MiniPro from eBay and an 8 pin SOP clip. I can't for the life of me get it to read the eeprom. I keep getting an "OverCurrent Protection actions! External short circuit/IC reverse or damaged!" warning.
I have the SOP clip attached to the cluster and have selected m35080 V6 (even though my eeprom is 080D0WQ)
Am I missing something?
Thank you.
Monaco Blue E92 // BMS JB4 G5 ISO // BMS Backend Flash // Dual Cone Intake // ER Chargepipe // Dual HKS SSQV BOV Setup // BMW Performance Spoiler // 19" v710 Dolphin Grey // Aero Front Lip // M3 Sideskirts // Mtech Rear Bumper // Quad Tip Diffuser // Quad Exhaust //
      02-03-2017, 12:50 AM   #63
RS6
9
Drives: E90
OK, I finally gonna have time to do the test tomorrow. Since the original IC can't be read and I have ordered a new 080D0WQ from ebay. Can I just solder the new IC onto the board and load this Bin file and things should just work after I code it VIA NCSEXPERT? (Since the BIN file is viginized? - Meaning FF on VIN and 00 on KM)
Thanks So nervous doing this coding as don't wanna mess up the original mileage.
      02-03-2017, 12:53 AM   #64
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
yes, thats right,
load bin on programmer itself before soldering eeprom on board
not all programmers can do it on circuit so just to make things safer
it will copy mileage from CAS on first power up
      02-03-2017, 01:16 AM   #65
RS6
9
Drives: E90
yes, thats right,
Thanks for the advice. Will give it a shot tomorrow. Fingers crossed
      02-04-2017, 03:58 AM   #66
RS6
9
Drives: E90
Thanks Levanime for the .BIN file and advice, it has successfully loaded into my new IC chip and soldered on the cluster this morning. All mileage has been cleared to 0.
However, my question before I plug it into my car. The temperature is now read Fahrenheit instead of Celsius, the mileage is now show in Miles instead of Kilometers.
How can I change these value back to Celsius and ‎Kilometers? (My car is a Canadian model)
Thanks
