BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > BMW X5 and X6 (F15/F16) Forum
      08-21-2017, 09:09 PM   #67
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
Originally Posted by Maverik259 View Post
Updating what? The app or the iDrive? It was just at service to have the iDrive controller replaced. I woulda hoped if a firmware update was available they would have done it. I did lose quite a bit of coding when I got it back
Just curious, what was wrong with your iDrive controller?
But, to your post, you can back up a config of the current code depending on the app/ method you're using.
I use BimmerCode and do occasional syncs to create stable backups for reverting back.
It was figity since I bought it. It would catch at one point when rotating it. "Internal failure" service dept called it. $1200 warranty bucks later.
But not sure how backing up will help menus show up that aren't showing up.
Ouch. $1200 to fix a simple knob???!
I meant backing up as in to save your ECU Coding options, especially if you made a ton of advanced changes.
      08-21-2017, 09:24 PM   #68
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Oh you were referring to the coding part. Ya I did this time. I had someone else Code for me through esys originally.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      08-29-2017, 08:27 PM   #69
BeeMdblU
BeeMdblU's Avatar
452
Drives: F86, F25, G16
I only have 6 groups with 8 layers each and when i open the first layer of Group 1 one this is what I get. Unk parameter or inactiv across all layers when I open themm up
any solution to this situation yet?
      08-29-2017, 09:42 PM   #70
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Use e-sys.
      08-31-2017, 10:03 PM   #71
BeeMdblU
BeeMdblU's Avatar
452
Originally Posted by Almaretto View Post
Use e-sys.
may you please elaborate more, i'm already using esys as far as I know
      08-31-2017, 10:08 PM   #72
Almaretto
Almaretto's Avatar
2374
Sorry, I was mixing up threads thinking people were using Bimmercode.
There should be 9 Groups. There are only six groups if coding an i8.
      09-15-2017, 07:50 PM   #73
anon1000
38
Drives: bmw
Something changed here. I just picked up my car from service, and I have the same situation. I used to see all the colors nicely listed and now I have 6 groups and hex values, cant change it back to hellrot
      09-15-2017, 07:54 PM   #74
BeeMdblU
BeeMdblU's Avatar
452
It's a bummer, I was looking forward to changing the colors to bright red and blue
      09-15-2017, 10:14 PM   #75
anon1000
38
Drives: bmw
Surely there is a way to get it back to hellrot or the nicer blue. The 6 groups that are there, changing those values does not seem to change anything
      09-15-2017, 10:22 PM   #76
anon1000
38
Drives: bmw
      09-15-2017, 10:50 PM   #77
Almaretto
Almaretto's Avatar
2374
Depending on firmware, especially older, you have to let car rest for changes to appear.
      09-16-2017, 07:51 AM   #78
anon1000
38
Drives: bmw
Never had to do that before. I no longer have integrated chassis mgmt ecu available, and looks like something else disappeared too, and the bdc 3070 is totally different, used to have 9 groups now only 6, idrive still has the 9 and they all work, but just in those basic colors I dont care for
      09-16-2017, 02:16 PM   #79
Almaretto
Almaretto's Avatar
2374
Make sure engine is running so you provide power to see all ECU's.
Not sure why you are only seeing six.
      09-16-2017, 03:19 PM   #80
anon1000
38
Drives: bmw
Once I got it back from service it has been this way. Lost some ECUs and calues are different for some now
      09-16-2017, 04:32 PM   #81
Almaretto
Almaretto's Avatar
2374
You can change CAFD_ID's, but you will not loose ECU's.
      09-16-2017, 05:31 PM   #82
anon1000
38
Drives: bmw
Meaning that I can no longer see Integrated Chassis Module available, need it to turn sport mode on by default
      09-16-2017, 06:39 PM   #83
Almaretto
Almaretto's Avatar
2374
I understand what you are writing; I just have never seen a vehicle drop an ECU.
      09-17-2017, 05:13 PM   #84
anon1000
38
Drives: bmw
I was using bimmercode, will try to see if the cable also does not show them
      09-17-2017, 05:14 PM   #85
Almaretto
Almaretto's Avatar
2374
Try with E-sys.
      09-18-2017, 12:16 PM   #86
wilho
Finland
9
Drives: BMW X5 45e -20, 225xe -16
2020 BMW X5 45e  [0.00]
2016 BMW 225xe  [0.00]
Hi,
Did you ever found a solution for this, I'd also like to get blue colors to stay also after i've opened the door. And no I haven't coded anything yet.
BR
Originally Posted by HZX540e View Post
In my F15 40e when I unlock the using the remote the interior dome (the ones above the doors, not the small light the lights up the over the center of the car) colors light up blue and when I open the doors they turn white. When I went to Group 0 ensemble 2 was weiss but I noticed that layers 1-3 were blau_F15_PHEV and as expected layers 5-8 were inaktiv. Group 0 ensemble 3 was weiss and layers 1-3 were also weiss
Any how, what I would like to do is when I unlock the door the blue dome lights come on (which already happens) ALSO when I open the doors I would like the blue lights to stay on (currently they turn white). What do I change to get the desired outcome?
      09-18-2017, 07:37 PM   #87
anon1000
38
Drives: bmw
Try with E-sys.
The developer updated the bimmercode, icm exu is back there now.
Now, just need to figure out how to get the nice red ambient lighting back.
Folks with the latest sw, do you still the 9 groups in bcm 3070?
      09-18-2017, 08:45 PM   #88
BeeMdblU
BeeMdblU's Avatar
452
yes we see them with wert values only, no more color drop downs
xbimmers
