05-10-2021, 10:23 PM | #1 |
Rep 15
bootmod3 flash failed - can't start car. PLEASE HELP!
I have a 2016 340i stock. I tried flashing bootmod3 stage1 91 ACN tune. I attempted this with a OBD to ENET and ENET to USB on my laptop. The flash failed and I have warnings on my idrive and can't start the vehicle. I'm freaking out.
The warnings on the iDrive say; Drivetrain malfunction Chassis stabilization I tried to flash back to stock but it failed again. Can anyone help me out? I just want to get the car back to stock. I hope I am posting in the right area but if someone can help me out or point me in the right direction I'd really really appreciate it. If you require more info I can post it. I copied the logs from the bootmod3 agent into a word file. EDIT: I am looking around online and see that I may be able to flash to stock. Would I just use the "FORCE FLASH (DIAG ONLY)" option? Last edited by suprfly; 05-10-2021 at 10:31 PM.. |
05-11-2021, 12:48 AM | #2 |
17
Rep 62
Is flash failing and not going past 3%?
05-11-2021, 12:54 AM | #3 |
17
Rep 62
If it is then it may be caused by 3 things:
#1. Faulty cable - replace the OBD2 Ethernet cable and any adapter cable that you may be using. #2. Low battery - fully charge your battery and ensure to use a battery charger that does 20-50amps. #3. Something is blocking your flash - aftermarket CarPlay, piggyback, exhaust valve controller, GPS system, aftermarket alarm system etc.. Physically disconnect them and try once more. |
05-11-2021, 01:16 AM | #4 | |
Rep 15
The flash went to 100% and started clearing codes then said it failed. I don't have any of the things you mentioned. I also made sure I turned off my firewalls. I appreciate your reply. I'm just totally stressing out. |
05-11-2021, 01:41 AM | #5 | ||
17
Rep 62
05-11-2021, 02:08 AM | #6 |
17
Rep 62
Another thing is that your DME might have the current software installed which prevents unlock and flash tuning via OBD2. PTF can confirm it for you.
05-11-2021, 09:26 AM | #7 |
Rep 15
I am working with an agent from PTF via email at the moment. I have to say it's a relief that they got back to me so quick. I'm hoping this is a relatively easy fix..
05-11-2021, 10:03 AM | #8 |
Rep 15
It's fixed!
I sent a customer support request late last night and by 6:30 this morning I had a message from Dzenan. He walked me through how to get the flash tune back on the car. I was completely freaking out and now the car is fixed thanks to the amazing support by PTF & Dzenan. Appreciate everyone who chimed in here trying to help! |
blacksapphire440i316.00 |
05-11-2021, 10:22 AM | #9 | |
Novice
316
Rep 697
05-11-2021, 05:37 PM | #10 | |
Rep 20
05-11-2021, 06:24 PM | #11 | |
17
Rep 62
Yes their customer service is superb! |
05-11-2021, 06:26 PM | #12 | ||
17
Rep 62
I don't have aftermarket carplay btw.. my issue was something else. |
05-13-2021, 08:38 AM | #13 |
24509
Rep 191,503
this needs to be sticky.
If your flash fails, flash back to stock and you will be fine.
BaconDouble61.50 |
05-13-2021, 10:34 AM | #14 |
305
Rep 2,485
Drives: 340Xi MG 2017
I saw that Enet to USB is not recommended for BM3. Could that be the culprit?
Also had a flash fail before while doing it with my phone. Car's flash was completely shot and wouldnt start. Flash back to stock and reflash using Enet and I was on my way. Never re-used my phone to flash since.
05-13-2021, 10:36 AM | #15 | |
24509
Rep 191,503
I still recommend using an adapter to your phone for the fastest and easiest flash. If you lose connection (very rare), just flash back to stock and flash it again
MaximusJ305.00 |
05-01-2024, 10:53 PM | #16 | |
Rep 2
Drivetrain malfunctio Chassis stabilization Need Help please |
05-01-2024, 11:15 PM | #17 |
Rep 1,449
Did you even read through the thread?
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
05-01-2024, 11:21 PM | #18 | |
Rep 2
05-02-2024, 09:44 AM | #19 |
Rep 1,363
Try flashing back to stock. If that does not work, contact PTF support. They’re exceptional.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
